Law of attraction and subliminal messages
  • Law of attraction and subliminal messages
    Just an idea, what if I combine my Law of Attraction "Dreamboard" with the subliminal messaging software? Would it work?
    I mean, saying, that if I create a jpg image file, that displays all my desires- money, healthy body, smiling beautiful women ... etc, etc.
    And after that I'm going to insert this image into any of subliminal messaging software programs, saying Subliminal Images.
    As I know, subliminal messages go directly to the subconscious mind and are imprinted there (as they're displaying around the screen very quickly, and conscious mind is not able to critically filter them). And all these positive images shoould be imprinted into subconscious, am I wrong? Any ideas about that?
    Well,
    Just to share my experince. Yesterday I have downloaded free trial of the subliminal software, created the "dreamboard" image to display as a subliminal message and started subliminal session. Duration of the session was 45 minutes.
    Today I feel my self-confidence and "emotional intelligence" improved, so I'm going to continue with this.
      Well you have one desire that is not vain. Do I need to point it out?
        When I have made subliminal messages, my experience is that there are certain elements that make them more effective. Not all of the below at once, in one recording. These can easily be accomplished on Goldwave, Audacity or other audio editing softwares.
        * record them in your own voice
        * reverse the recording
        * modulating them onto ultrasound carrier wave (10 to 20 KHz). Look up "silent sound subliminals").
        * Adding broadband pink noise (pink noise, or 1/f noise, is a universal constant in aall things ntural and artificial. There are patents for incorporating pink noise into appliances, which seems to make them work better). There is no formula for pink noise, but there are samples and generator softwares online. Most pink noie is made by filtering white noise.
        * Record the subliminals, reverse the recording, then change the speed to 1/2 and save. take the original recording and change the speed to double, 4 x and 8x, copying and pasting each time it is speeded up an appropriate number of times so all recordings are the same length as the half-speed . Mix them all together. You will hear the suggestions many times in a short time.
        * modulate infrared or ultraviolet LED arrays with the audio recording. be careful not to get to much eye exposure. Both can damage the eyes, at sufficient power. A single audio-modulated 850 nm LED, mounted to a headband, will carry the signal deep into the brain. Avoid using this over the sides of the head.
        * Modulate a telephone pickup coil with the audio suggestions, while it is held by a headband over the cerebellum or the brow (never the sides of the head).
        * Try to forget, as much as possible, what the recordings specifically say, so as not to involve the analytical mind.
        * Modulate two LEDs mounted in sunglass frames.
        * Add sounds such as a fetal heartbeat, a baby nursing, a woman in the throes of orgasm to the recording.
        * Add natural audio VLF radio recordings.
        * record the suggestions in two formats: One as commands, and one as "I am allowed to.." or "I am permitted to..."
        The following I haven't done yet, but they are on my to-do list. Perhaps you should wait until I've tried them.
        * Apply the signal electrically, just below the level of sensation. This is accomplished by using a headphone amplifier and a mini audio output transformer wired in reverse, to step up the voltage. Only use this just below the threshold of sensation. use reusable conductive rubber gel electrodes such as are used with TENS or electro-muscle stimulators. It is very important that you do not use too much power. Very carefully find the level of sensation, then turn the volume control down until you just can't feel it. the most effective electrode placement for this is fronto-lumbar: One electrode on the forehead and one at the base of the spine. Only use a small, low power, battery-operated mini audio amp. Here is a pic of a radio Shack mini audio output transformer:
        http://images.buzzillions.com/images...324725_175.jpg
        One side is 8 ohms and the other is 1 kOhm.
        I have used fronto-lumbar electrical stimulation with a low-power ac stimulator, and the effects are very powerful physiologically and mentally. Humans have a small dc flow that goes from the base of the spine to the head, like Kundalini.
        * Modulate a mini spark-gap transmitter or a small carbon arc with the subliminals
        * Modulate a low-power plasma tube with the audio suggestions, such as a cold-cathode tube. This could be accomplished by placing an 8 ohm coil around the tube, sso the tube is the coil's "core". A sufficient power level must be used to "pinch" the pasma somewhat and thus modulate it.
        High UV output tubes are known to have more mental effects. Again, shield your eyes from UV, and make provisions to prevent the buildup of ozone.
