Change water into tea?
  • Change water into tea?
    I saw a Japanese tv show that included a man who took water in a clear glass teakettle and swirled an empty tea bottle over it in a single handed fashion clockwise, not touching the water with the bottle, and after a few seconds the water turned brown and he took a sip. The whole show lasted a minute and the commercials before and afterwards were much longer then the little snip, and he was sandwiched in between show segments of people making silly faces and ghost stories... So I cant make heads or tails of it... Lots of Oooooh and AAaaah that whole tv show... The water remained clear for a short period of time and then it almost all at once turned brown.
    But I do remember reading somewhere that someone was able to swirl their hands over water and change its properties, also making wine less bitter or alcoholic, and all that Emoto research... So I'm thinking that theres the power of sugguestion that the guy is using to imply that the water turn to tea and the water follows suit.
    I was just wondering if anyone has seen that before or know where I can find out more about that.
    Thanks!
    water to wine
    That's interesting - any other info on the name of the program or channel
    in Japan?
    In some Qigong studies, it has been recorded on multiple occasions starting
    with water in a sealed container and then with the potential coupled with
    intention, small amounts of alcohol molecules manifested in the water.
    That is "turning water to wine." It was trace amounts of alcohol but
    still alcohol from nothing but water.
      I think it was on 24hr tv but that is just a guess. I'm not the television commander, to me its more like a moving painting that someone else owns... I just observe it sometimes... This time was interesting though...
      I dont think he was using acid/base dyes because those are usually a shade of red or blue, and this was clearly brown tea. Do you think it might have been slight of hand with a time delay powder or something? Or maybe he did use a Ph dye and change its ph with suggestion??? I remember reading about the essence that if you dilute something 100x then it still has the same effect (like bacteria or antibiotics)
      What other references can you dig up about people changing water into something? (of course theres ol' JC making wine)... but what else can water do?
      Also Aaron can you put a link for me to read about changing the water into alcohol?
        changing water
        Anything can be slight of hand of course.
        Would be interesting to see the one you talk about.
        Diluting things as you mention is homeopathics and
        homeopathics work. (homeopathic remedies).
        The references I talk about were from my personal
        friends. One medical doctor I worked with went to China
        quite a few times and so did one of my mentors that
        was a natural born Qigong master. They had access to
        many high level labs that were researching Qigong
        and recording measurable emissions from my mentor's
        palms, etc...
        This book may have references to that - I can't remember
        but the doctor I worked with wrote this a while back:
        Amazon.com: Miracle Healing from China-Qigong (9780963697950): Charles McGee, Effie Poy Yew Chow: Books
        There also might be references in this book:
        Amazon.com: China's Super Psychics (9781569247150): Paul Dong, Thomas Raffill: Books
        That is written by Paul Dong, a Qigong master in California.
        I spoke to him years ago about some of this. I have a copy
        and some of the stories are very fantastic and are hard to
        believe - but I know some people that were involved with
        documenting and testing some of the claims in that book
        and found some to be authentic - I trust my friends
        that told me this - but I haven't seen it myself.
        Not sure if there is the water/alcohol example in that book,
        but if there is a reference to it, that book would have it.
        There has to be some references to this online somewhere.
        I'll look thru some of my books if I get a chance and will
        post here. Been a while since I thought about any of this.
        You might like this:
        Seeing a Letter G manifest in a nutrient solution by intending the Letter G
        to manifest. I was promised more details about the solution that was used
        but haven't gotten it yet. They were going to give me all the protocols
        for this test.
        "The change of the Raman spectroscopy of water molecules. "
        Just found that - Yan Xin is authentic
        I don't know if that is the alcohol manifestation or not but he
        has documented changes in water from emitting Qi into the water.
        He has changed the half life decay rate of radioactive substances
        and can cause it in radioactive material at any distance - thousands
        of kilometers away or right in front of him. It either speeds up, maintains a faster
        rate for a period of time and then it goes down to normal over a certain
        rate of time. Can also have it slow down, maintain and then go back up
        to normal. Anyway, this one has been absolutely documented over and
        over. He is one of the few operating at this level.
        Anyway, I'll see if I can dig up the alcohol references.
          The only thing ive ever seen concering water is the interview with david sereda. They have proof of the mind affecting the molecule structure of water. It didnt change the substance but it changed the patterns.
          YouTube - Revolutionary New Discoveries about Water! part 1 of 12
          From my own experiences i absolutly believe the mind could possibly change the substance, structure and shape of any liquid. I know for certain when i make objects move through telekinesis that the motion is derived internally. I've seen people use their hands to make the objects move but i can do it with just my mind. To control the direction of movement i simply imagine a clock with the hands spinning in the direction that i want the object to spin in.
          What i have encountered is that every object will mimic what my mind is thinking. If the water really did turn into tea it would make perfect sense for the water to mimic what the man was thinking.
            Water into milk
            Video of Amma as a young girl supposedly turning water into milk pudding. Not sure which "Amma" this is as there are / has been more than one. The title generally means Mother in several countries.
            There have been many other examples of indian mystics/gurus manifesting things which would seem unlikely, if not impossible to the western world. There are of course, also a lot of fakes.
            Another example in this video:
            "His Holiness Sri Swamiji takes a garland of betel leaves and creates Vibhuti ash for healing."
            Love & Blessings,
            Sharyn
            Theta Healing
            Paths 2 Potential
            "We are the one's we've been waiting for"
              Nice ! Thank you all for your awesome and thought provoking posts.
              to manifest.
              @Aaron - Is that anything like putting a number 2 in the middle of the eye of a hurricane?
              It seems water is a very valuable and sensitive resource that was put here for our use, and the proper manipulation of water can cure almost anything... yet it is depressing to see all the industry turn the worlds water into waste...
              Thanks again for the replies!
                Some people say that the boiling water cooled, makes the tea taste better than water that has not been boiled. I found no difference in taste, but it is easier to boil fresh water in an attempt to measure the water temperature without a thermometer.
                translation services
