Bashar on Time Travel
Dear all,
I sometimes find Bashar's explanations astonishing, so here is one on Time Travel:
*Time Travel*
Bashar: Sharing!
Questioner: Hello.
B: Hello!
Q: When you create your isolation field around your craft and redefine the
space/time coordinates to relocate to another space / time coordinate, yes.
B: Very good, right.
Q: Can you define the space / time coordinates in such a way as to
transport back to what we call our past or our future? That is, can you
move to planet Earth in 15th century?
B: Yes. Space / time is one thing. Traveling in space is traveling in
time; traveling in time is traveling in space; it is one thing. However,
recognize that everything will still fit in place, even from the apparent
linear point of view. And that any so-called changes that may appear to
take place within any previous time track that you came from, will actually
not be taking place in that literal time track, but in one parallel to it.
You follow me?
Q: So exactly what do you experience?
B: The same thing that you would ... the effect is basically the same. In
other words, you could step into your craft, go back in time, do something
-- if you are assuming that you wish to, quote/unquote, change the way
something happened. Then when you make that change, if you go back to the
exact same time track where you left off, there will be no apparent change,
because the change that was made was not in your time track, by definition,
because that's not what happened in your time track.
The change, so to speak, is not a change. It is a part of the normal
history of a parallel time track, a parallel universe. So, if you wish to
see the effect of the so-called change, you must go to the future or go
back to the present of the parallel time track that you made the change in.
You follow me? Is this making any sense?
Q: Somewhat. I will have to listen to this tape.
B: You have time track A, time track B. Time track A is your time track,
let us say. All right? Your history, all right? Yes, no, maybe?
Q: Yes.
B: All right. Time track B is another history altogether; everything is
occurring simultaneously. Therefore, let us say, time track A and time
track B are very similar, very similar, the idea, in this way, is that if
you -- leaving this point in your time track A -- go back to the supposed
past, you are actually going into the idea of another time track, and being
a part of its history in a natural progressive way.
You cannot actually literally change your own past in the same linear
coordinate system. When you, quote/unquote, change your past, you are
simply shifting gears into another time that contains that ability to
change, so you will have the experience of that change in your new present.
You cannot change history. You alter yourself to another history that is
appropriately representative of the change you desired to make -- more
correctly.
Q: And the same applies to moving to the future.
B: Yes.
Q: How exactly do you create the isolation field?
B: It is a microwave energy effect that is an alteration of light, stepped
up many magnitudes above what you typically think of as an electrical
discharge. It is dispersed through the hull of the craft, through various
devices, after the light is stepped up by other various devices -- one of
which we call the flash matrix -- which incorporates many different
elements.
The isolation field will be seen to be a microwave effect. Microwave
generation, at that high rate of speed, will disconnect any object within
the bubble from the universe in which it existed. Because you, in that
sense, match the vibration frequency -- in a very highly condensed way --
of the speed of light itself, the speed of light being the barrier limit
that represents physical dimensionality.
When you create around your craft a wall, a shell, made of the very
substance of the physical universe -- light -- then you, within that shell,
have created a bubble, a hole in that universe. You follow me? You are
redirecting the light, out of which everything is made, around you rather
than through you. You are now sustained by the primal template universe,
which exists on a completely different frequency, far above and beyond the
frequency of light. Therefore, in that universe, you literally are
everything at once. So you can be anywhere and anywhen you want to be.
Q: Can this be done with our technology now?
B: Yes.
Q: How do you do it? Have a piece of matter bombarded with microwaves?
B: No. You will find that many individuals are working on this idea now.
Listen to your media; listen to your literature. Many individuals are
beginning to explore and experiment and they will come out with what you
call public notification of many of these ideas.
Basically, it involves the idea of counter-rotational masses that are
highly magnetically charged -- that will generate the field, of which we
are speaking, in a fundamental way. Fundamental enough to allow the
isolation to take place. More sophisticated control will came from the
generation of these fields through more highly conductive materials.
Q: Thank you.
B: Thank you! There will be but a few moments remaining for these
interactions, this evening of your time....
Dear all,
*Time Travel*
Bashar: Sharing!
Questioner: Hello.
B: Hello!
You follow me?
Q: Yes.
correctly.
B: Yes.
elements.
B: Yes.
Q: Thank you.
Keoi
