  • a repost
    centripetal energy is the basis of life whereas centrifugal energy is the basis of decay and destruction. V. Schauberger
    I think all that nature needs is three things, the North and South pole magnets and the neutral particles. Each of those three things can act differently with different speed and different combinations, and so they can accomplish different results. Edward LEEDSKALNIN
    Even some crop circles hint to the notion of a Denser Negative and Expanded Positive.
    [IMG][/IMG]
    It is all the same
    The Principle of Gender.
    "Gender is in everything; everything has its Masculine and Feminine Principles; Gender manifests on all planes." - The Kybalion.
    The Principle of Polarity.
    "Everything is Dual; everything has poles; everything has its pair of opposites; like and unlike are the same; opposites are identical in nature, but different in degree; extremes meet; all truths are but half-truths; all paradoxes may be reconciled." - The Kybalion
    To Decipher a Spiritual Universe.....Harmonic Math...no wonder Math as we know it did not work...we were using the wrong lense
    Signs and symbols -Confucius.
    • maybe time to pdf print
      • Let try our new found Dimension of Harmonic Math
        from: Matthew 27:45 From the sixth hour until the ninth hour darkness came over all the land.
        Matthew 27:45 = 9 : 9 = HM 9
        Mark 15:33 = 6 : 6 = HM 3 At the sixth hour darkness came over the whole land until the ninth hour.
        Mark 15:34 = 6 : 7 = HM 4 And at the ninth hour Jesus cried out in a loud voice, "Eloi, Eloi, lama sabachthani?"--which means, "My God, my God, why have you forsaken me?"
        Luke 23:44 = 5 : 8 = HM 4 It was now about the sixth hour, and darkness came over the whole land until the ninth hour,
        John 19:14 = 1 : 5 = HM 6 It was the day of Preparation of Passover Week, about the sixth hour. "Here is your king," Pilate said to the Jews.
        Acts 3:1 = HM 4 One day Peter and John were going up to the temple at the time of prayer--at three in the afternoon.
        • Originally posted by blackchisel97 View Post
          And some interesting points here - striking similarities between Stonehenge and Vatican (floor plan).
          V
          [B]
          Quite a ride .
          ..but interesting...you can play at reduce his numbers...looks a bit clearer...Pattern wise to understand...i mean
          ps: Thank you blackchisel97
          • also found the following image here: Page Attachments (Home of Flow) vortexspace.org/
            and
            [IMG][/IMG]
            • and also:
              and a table we discussed previously
              • A word that kept coming up especially within the esoteric realm :
                Merkabah - Wikipedia, the free encyclopedia
                The Hebrew term merkabah (Hebrew: מֶרְכַּבְ ,מרכבה, and מִרְכֶּבֶת "chariot", derived from the consonantal root r-k-b with general meaning "to ride") is the throne-chariot of God, the four-wheeled vehicle driven by four "hayyot" (Hebrew: "living creatures"), each of which has four wings (like a Dove ) [1] and the four faces of a man, lion, ox, and eagle. The word "chariot" is found 44 times in the Masoretic text of the Hebrew Bible[2] and though the concept of the Merkabah is associated with Ezekiel's vision (1:4-26), the word isn't explicitly written in Ezekiel 1
                Maimonides
                Maimonides' 12th Century work, Guide for the Perplexed is in part intended as an explanation of the passages Ma'aseh Bere**** and Ma'aseh Merkabah. In the third volume, Maimonides commences the exposition of the mystical passage of the mystic doctrines found in the merkavah passages, while justifying this "crossing of the line" from hints to direct instruction. Maimonides explains basic mystical concepts via the Biblical terms referring to Spheres, elements and Intelligences. In these chapters, however, there is still very little in terms of direct explanation.[10]
                We have frequently mentioned in this treatise the principle of our Sages " not to discuss the Maaseh Mercabhah even in the presence of one pupil, except he be wise and intelligent; and then only the headings of the chapters are to be given to him." We must, therefore, begin with teaching these subjects according to the capacity of the pupil, and on two conditions, first, that he be wise, i.e., that he should have successfully gone through the preliminary studies, and secondly that he be intelligent, talented, clear-headed, and of quick perception, that is, " have a mind of his own", as our Sages termed it. Guide for the Perplexed, ch.XXXIII
                • GENDER
                  "Gender is in everything; everything has its Masculine and Feminine Principles; Gender manifests on planes."-The Kybalion.
                  The great Seventh Hermetic Principle-the Principle of Gender-embodies the truth that there is Gender manifested in everything-that the Masculine and Feminine principles are ever present and active in all phases of phenomena, on each and every plane of life. At this point we think it well to call your attention to the fact that Gender, in its Hermetic sense, and Sex in the ordinarily accepted use of the term, are not the same.
                  The word "Gender" is derived from the Latin root meaning "to beget; to procreate; to generate; to create; to produce." A moment's consideration will show you that the word has a much broader and more general meaning than the term "Sex," the latter referring to the physical distinctions between male and female living things. Sex is merely a manifestation of Gender on a certain plane of the Great Physical Plane-the plane of organic life. We wish to impress this distinction upon your minds, for the reason that certain writers, who have acquired a smattering of the Hermetic Philosophy, have sought to identify this Seventh Hermetic Principle with wild and fanciful, and often reprehensible, theories and teachings regarding Sex.
                  The office of Gender is solely that of creating, producing, generating, etc., and its manifestations are visible on every plane of phenomena. It is somewhat difficult to produce proofs of this along scientific lines, for the reason that science has not as yet recognized this Principle as of universal application
                  Day is the Sun ie the Male Pole and Night is the Moon ie Female Pole
                  read the following:
                  "Eureka!" Moments More Likely at Night Study Finds
                  The research also found that 4.33pm, presumable an average time garnered from the surveyed, was the period of the day when people felt the least inspired. A total of 92% of people found that they felt uninspired in the afternoons; another nail in the coffin for the stereotypical 9-5 working day.
                  ps: Alchemist, Inventors and Artists work during the night (most of them )
                  • In relations to the last Posts on the Spiritual Gold and Harmonic Math :
                    from: Fulcanelli - The Mystery Of The Cathedrals book
                    • ♥ ♫ ♪ Gary Wright: Dream Weaver, Album/Studio Version HQ ♥ ♫ ♪ - YouTube enjoy
                      think of it as another expression of Ishtar (some call her the Muses )
                      Dream Weaver lyrics
                      I've just closed my eyes again
                      Climbed aboard the dream weaver train
                      Driver take away my worries of today
                      And leave tomorrow behind
                      (chorus)
                      Ooh dream weaver
                      I believe you can get me through the night
                      Ooh dream weaver
                      I believe we can reach the morning light
                      Fly me high through the starry skies
                      Maybe to an astral plane
                      Cross the highways of fantasy
                      Help me to forget todays pain
                      (chorus again)
                      Though the dawn may be coming soon
                      There still may be some time
                      Fly me away to the bright side of the moon
                      And meet me on the other side
                      (chorus again, then fade out with the following
                      Repeated several times...)
                      Dream weaver
                      Think of her (see the codex ) when you sing along...she'll dance with you ...sort of a modern calling spell for those that are into spells
                      remember Fractal Universe....and you being an antenna
                      Muse - Wikipedia, the free encyclopedia
                      The Muses (Ancient Greek αἱ μοῦσαι, hai moũsai:[1] perhaps from the o-grade of the Proto-Indo-European root *men- "think"[2]) in Greek mythology, poetry, and literature, are the goddesses who inspire the creation of literature and the arts. They were considered the source of the knowledge, related orally for centuries in the ancient culture, that was contained in poetic lyrics and myths. The compliment to a real woman who inspires creative endeavor is a later idea.
                      Calling All Angels- Train - YouTube
                      I need a sign, to let me know you're here
                      All of these lines are being crossed over the atmosphere
                      I need to know, that things are gonna look up
                      'Cause I feel us drowning in a sea spilled from a cup
                      When there is no place safe and no safe place to put my head
                      When you can feel the world shake from the words that are said
                      And I'm, calling all Angels
                      And I'm, calling all you Angels
                      And I won't give up, if you don't give up
                      I need a sign to let me know you're here
                      'Cause my TV set just keeps it all from being clear
                      I want a reason for the way things have to be
                      I need a hand to help build up some kind of hope inside of me
                      [ From: CALLING ALL ANGELS Lyrics - TRAIN ]
                      When children have to play inside, so they don't disappear
                      While private eyes solve marriage lies 'cause we don't talk for years
                      And football teams are kissing queens and losing sight of having dreams
                      In a world where what we want is only what we want until it's ours
                      (I won't give up, if you don't give up)
                      Calling all you Angels
                      the art of music has been specially considered divine, because it is the exact miniature of the law working through the whole universe. For instance, if we study ourselves we shall find that the beats of the pulse and the heart, the inhaling and exhaling of the breath are all the work of rhythm. Life depends upon the rhythmic working of the whole mechanism of the body. Breath manifests as voice , as word, as sound; and the sound is continually audible, the sound without and the sound within ourselves. That is music; it show that there is music both outside and within ourselves.
                      a fractal construct has an 'efficient function', it has a fractal ergonomy to them, they function on multiple levels and in multiple dimensions:
                      • Train - Drops Of Jupiter (Lyrics) - YouTube
                        Drops Of Jupiter lyrics
                        Songwriters: Hotchkiss, Robert S; Monahan, Pat; Stafford, James W; Underwood, Scott Michael; Colin, Charlie;
                        Now that she's back in the atmosphere
                        With drops of Jupiter in her hair, hey
                        She acts like summer and walks like rain
                        Reminds me that there's a time to change, hey
                        Since the return from her stay on the moon
                        She listens like spring and she talks like June, hey, hey
                        But tell me, did you sail across the sun?
                        Did you make it to the Milky Way
                        To see the lights all faded
                        And that heaven is overrated?
                        Tell me, did you fall for a shooting star?
                        One without a permanent scar
                        And then you missed me
                        While you were looking for yourself out there?
                        Now that she's back from that soul vacation
                        Tracing her way through the constellation, hey
                        She checks out Mozart while she does Tae-Bo
                        Reminds me that there's room to grow, hey
                        I'm afraid that she might think of me as
                        Plain ol' Jane told a story about a man
                        Who was too afraid to fly so he never did land
                        But tell me, did the wind sweep you off your feet?
                        Did you finally get the chance
                        To dance along the light of day
                        And head back to the Milky Way?
                        And tell me, did Venus blow your mind?
                        Was it everything you wanted to find?
                        Can you imagine no love, pride, deep-fried chicken
                        Your best friend always sticking up for you
                        Even when I know you're wrong?
                        Can you imagine no first dance, freeze-dried romance
                        Five-hour phone conversation
                        The best soy latte that you ever had, and me?
                        And head back toward the Milky Way?
                        And tell me, did you fall for a shooting star?
                        While you were looking for yourself?
                        And did you finally get the chance
                        To dance along the light of day?
                        And did you fall for a shooting star?
                        Fall for a shooting star?
                        And now you're lonely looking for yourself out there
                        Train is an American pop rock band from San Francisco, California, formed in 1994. The band currently comprises a core trio of Patrick Monahan (vocals), Jimmy Stafford (guitar, vocals) and Scott Underwood (drums, percussion).
                        See Venus, Jupiter & Moon Align This Weekend in Celestial Show | Jupiter, Venus & Moon Observing Tips | Skywatching & Amateur Astronomy | Space.com
                        What's up in the sky? - Holland, MI - The Holland Sentinel
                        As March the Goddess of love and the King of the Gods!
                        Of course, they are not really close together. They just happen to line up from our point of view, like taking a photo of a person standing in front of a distant mountain. Jupiter is actuallty about seven times farther away from us as Venus,
                        • one last ...the song is great
                          Spirit In The Sky lyrics
                          When I die and they lay me to rest
                          Gonna go to the place that's the best
                          When I lay me down to die
                          Goin' up to the spirit in the sky
                          That's where I'm gonna go when I die
                          I'm gonna go to the place that's the best.
                          Prepare yourself you know it's a must
                          Gotta have a friend in Jesus
                          So you know that when you die
                          He's gonna recommend you
                          To the spirit in the sky
                          Never been a sinner I never sinned
                          I got a friend in Jesus
                          [ From: SPIRIT IN THE SKY Lyrics - GARETH GATES ]
                          So you know that when I die
                          He's gonna set me up with
                          The spirit in the sky
                          Oh set me up with the spirit in the sky
                          Oh
                          Set me up to the Spirit in the Sky
                          Goin' on up to the Spirit in the Sky
                          Go to the place that's the best
                          Go to the place that's the best.
                          One of my favorite Expression (usually to when you have arons to run...call them missions ) : Let's Rock and Roll....
                          ps: FYI used to kick ass in Call of Duty 1...2....3 (when they still had Private Servers ) went by the name MadDawg....we may have met.......not much interested now...Reality is so much more Fascinating
                          also
                          Train - Free (with lyrics) - YouTube
                          Free lyrics
                          Staring at the dark again, you left your silhouette upon my pillow - hey, hey
                          Right inside the night, I'm waiting for the light, seems like I'm in the middle - hey, hey
                          Workin for something that I can't touch and sometimes can't even believe in - woh, woh
                          Cradled by the hands of fate the faith that sometimes wraps around too tight - so tight
                          They call me free
                          But I call me a fool - hey, hey
                          They call me free
                          Well I look back at April, but she won't look back at me - Oh, no, no, no
                          So I pray in May for June to stay, but she just came to wash into the sea - away
                          And they call me free
                          They call me free
                          But I call me a fool - heyah, heyah, heyah, heyah, heyah, heyah, hey
                          1 - Slipped down to Mexico, started messin with her yellow afro
                          2 - Slipped down behind the sheets, started talkin bout Pistol Pete, well
                          3 - Slipped down to the African, started talkin bout what she can do
                          4 - Well here we are again, back where we started
                          5 - Slipped down to the dark again, you left your silhouette on my pillow - yeah, yeah
                          6 - Well I'm right inside the night, I'm waitin for the light
                          7 - Seems like I'm in the, seems like I'm always in the middle
                          They call me free
                          They call me free
                          Free
                          But I call me a...
                          • from: http://www.energeticforum.com/genera...tml#post182195
                            I highly encourage everyone to watch the socionomics doc, knowing that nature is fractal (see http://www.energeticforum.com/psychi...tml#post147589 )
                            it talks about self similarities and more.....
                            If you read this article ...you will understand they are using the above knowledge to set the trends.....
                            The Light Bulb Conspiracy - English Subtitles - YouTube
                            Pyramides of waste (the light bulb consperacy)
                            A docu about planned obsolescence the dirty littele secret in almost evrey modern product you buy witch makes sure it breaks ASAP and you buy a new one whitout complaining.
                            The motor of our economy but the most distructive spoiling of our planets resources!
                            • learn about Magic
                              Michael Tsarion. Sorcery and Magic. Red Ice Creations - YouTube
                              William Blake - Wikipedia, the free encyclopedia
                              The ancient Poets animated all sensible objects with Gods or Geniuses, calling them by the names and adorning them with the properties of woods, rivers, mountains, lakes, cities, nations, and whatever their enlarged & numerous senses could perceive.
                              And particularly they studied the genius of each city & country, placing it under its mental deity;
                              Till a system was formed, which some took advantage of & enslav'd the vulgar by attempting to realize or abstract the mental deities from their objects: thus began Priesthood;
                              Choosing forms of worship from poetic tales.
                              And at length they pronounc'd that the Gods had order'd such things.
                              Thus men forgot that All deities reside in the human breast.
                              In the most famous part of the book, Blake reveals the Proverbs of Hell. These display a very different kind of wisdom from the Biblical Book of Proverbs. The diabolical proverbs are provocative and paradoxical. Their purpose is to energise thought. Several of Blake's proverbs have become famous:
                              "The road of excess leads to the palace of wisdom."
                              "The tigers of wrath are wiser than the horses of instruction"
                              Blake explains that,
                              "Without Contraries is no progression. Attraction and Repulsion,
                              Reason and Energy, Love and Hate, are necessary to Human existence.
                              From these contraries spring what the religious call Good & Evil.
                              Good is the passive that obeys Reason. Evil is the active springing
                              from Energy. Good is Heaven. Evil is Hell.
                              "If the doors of perception were cleansed every thing would appear to man as it is, infinite. For man has closed himself up, till he sees all things through narrow *****s of his cavern."
                              [QUOTE=MonsieurM;147613]
                              Blake claimed to experience visions throughout his life. They were often associated with beautiful religious themes and imagery, and therefore may have inspired him further with spiritual works and pursuits.
                              Apprenticeship to Basire
                              After two years, Basire sent his apprentice to copy images from the Gothic churches in London (perhaps to settle a quarrel between Blake and James Parker, his fellow apprentice). His experiences in Westminster Abbey helped form his artistic style and ideas. The Abbey of his day was decorated with suits of armour, painted funeral effigies, and varicoloured waxworks. Ackroyd notes that "...the most immediate [impression] would have been of faded brightness and colour".[16] In the long afternoons Blake spent sketching in the Abbey, he was occasionally interrupted by the boys of Westminster School, one of whom "tormented" Blake so much one afternoon that he knocked the boy off a scaffold to the ground, "upon which he fell with terrific Violence".[17] Blake beheld more visions in the Abbey, of a great procession of monks and priests, while he heard "the chant of plain-song and chorale."
                              • Rock and roll - Wikipedia, the free encyclopedia
                                The origins of rock and roll have been fiercely debated by commentators and historians of music.[15] There is general agreement that it arose in the Southern United States - a region which would produce most of the major early rock and roll acts
                                Rock and roll arrived at a time of considerable technological change, soon after the development of the electric guitar, amplifier and microphone, and the 45 rpm record.[15] There were also changes in the record industry, with the rise of independent labels like Atlantic, Sun and Chess servicing niche audiences and a similar rise of radio stations that played their music.[15] It was the realization that relatively affluent white teenagers were listening to this music that led to the development of what was to be defined as rock and roll as a distinct genre.
                                Let us go to Memphis...sounds egyptian in a way
                                Memphis was founded in 1819 by John Overton, James Winchester and Andrew Jackson.[8][9] The city was named after the ancient capital of Egypt on the Nile River.[citation needed] Memphis developed as a transportation center in the 19th century because of its flood-free location, high above the Mississippi River.
                                During the 1960s, the city was at the center of civil rights issues, notably a sanitation workers' strike. The Lorraine Motel in the city was also the venue of the assassination of Martin Luther King, Jr. on April 4, 1968, the day after giving his prophetic I've Been to the Mountaintop speech at the Mason Temple.
                                side note: Everything can be Male pole and Female Pole...It is all in the perspective....take the example shown earlier, the region of Memphis is the Male pole in that case :
                                Philosophically speaking : Each Element in the Universe is the Male Pole or Female Pole relative to Another Pole
