Jetijs
Very impressive data
Your scope shots are between collector and emitter and also than show the high voltage drop over the transistors. 6 to 7 volts.
With a voltmeter I also measure about 7v over the transistors although that is an average voltage. I will pulse the optos by hand and measure again. I am under the impression that if the transistors switch on real hard, that the voltage drop over them will be lower and give us more voltage to work with.
I add a battery in my circuit to 24v. That give me more available voltage for the load as I do not have a 6v motor, but I found that the voltage drop over the C-E also rise
That spikes can be the answer as it was stated that you have to use an inductive load. How did you connect the motor to get dc to it and still get the spikes to the circuit?
