Any time you have acceleration you are opening a connection between the dimensions allowing an access to energy sources beyond the physical. This is true of linear acceleration, rotational acceleration, mass acceleration. The rate of change and the change of the rate of change, first and second derivatives in calculus access higher dimensional properties. This is true in electricity with waveforms, change of voltage. Once you open the doorway you can access the energy beyond through resonant tuning or focused intention. You are created in Gods image and therefore you are a God and the physical world will bow unto you if you know who you are and use it. If you open the door, command the energy to move, and have the faith that it will, as you believe so it will be done unto you by our father in Heaven. The energy here is in fixed form due to our collective will but as you go up the dimensions through these derivatives it is less mass, more energy, and more fluid. All reality molds to our will. It is the inventors will that sets the purpose, and the faith that gives him the means to achieve the purpose. Going into free energy is easier if you understand some basic metaphysics because the free energy comes from a metaphysical realm not a physical one.
I really want to thank you all for the good work you are doing! God Bless you and may everyone bringing forth this knowledge be protected and safe.
