Anyone tried to build a Perendev motor?
  • #46
    help
    i'm sorry, i'm newbie in here
    I've make a replication about perendev, but without shielding.
    I use NdFeB with 6mm diameters and 3mm height
    I think, with a small sized magnet, it is'nt need a shielding
    but it does't work
    but, maybe, movable stator can make this motor run, without shielding. but, how make this stator movable? I think we must use a spring or piston
    this is my video about my motor
    YouTube - Perendev Movable without Shielding
    • #47
      dead video link
      Hey aljhoa, the vid has been removed, can you post another link please?
      • #48
        Please contact the inventor and keep us informed.
        • #49
          Soo.....has anyone made a working model of the motor, or is this a dead end project?
          • #50
            IMHO it is a waste of money, magnets cost very much these days and the machining will also cost much and thae a long time. As far as I know, no one has replicated this with any success, even those who spent much time and money and followed the patent exactly failed. So I would not bother with this. There are many more promising projects to pursue.
            • #51
              so i figured.....im interested in making a small desktop model to keep the cost down. Are there any specific plans or the documentation of the patent that i'm missing? Also...where to get those stator magnets, that are polarized on the sides and not on the top or bottom?
              • #52
                The principle of operation of the motor is a magnetic force in the mutual repulsion of magnets in the rotor from the stator magnets. This repulsion occurs at an angle, so there is reaction torque of the rotor. Torque of the rotor regulate change angle and the distance between the magnets. We are looking for partners, investors and associates to zaverscheniya research and development and joint development of mass production.
                video embedded in website
                more vids to come... (russian translation )
                i'd recommend you translate this page, very interesting info, it even talks about the Serbian inventor B. Milkovich's oscillator;and this "GENERATORS with excess energy (TORS TT) a NEW DIRECTION IN THE CREATION OF FREE ENERGY GENERATOR (The famous diagram of the device based on the invention of Edwin Gray')"
                Signs and symbols -Confucius.
                • #53
                  hi
                  i see a lot of video of these motor, but i have not seen one hooked up to a home yet. i would like to build own but can't find out how mush power they put out like 5AMP on 120volts.?
                  • #54
                    kristov
                    Originally posted by rickoff View Post
                    Yes, I will help you, but let's take care of your problems one step at a time. Here's a photo of your rotors. I have drawn a line in yellow across the 3 rotors that is parallel to the center shaft axis. Currently, as you can see, you are offset only about 1/4 magnet diameter per rotor.
                    To correctly offset the rotor magnets, you must rotate the center and right rotors upwards so that the blue lines align with the yellow line. Then you will be offset 1/2 magnet diameter per rotor.
                    But before you do this, you must remove all the rotor magnets, install shielding around each magnet, and rebore the rotors to accommodate the larger magnet/shielding assemblies. And before you install the magnets in the rotors, let me know and I will explain how to obtain the best magnetic balance. Each of these steps is very important if you want the PMM to work well.
                    Rick
                    Hello, I am a new user in this foro.I want, please, someone to show me the exact picture of all sides of the magnets of the rotor and stator, also the number of magnets in the rotor and the stator,the distance betwean each one,what Gaus must have each one .How the magnets are oriented between itself.Where exactly is situated the axis north and south of the magnets and stator respectively -in the rotor.What material can use for make isolation of each one magnet.Generally I need some real dates, because it seems to me that the dates are false - I mean the Perendev Reversible Magnetic Motor from the Internet and each experiment with these dates have 0 result, there is a real purpose - not achieved any success.
                    Thank you very much everyone, I hope there will be someone who knows all this dates, but they are real...
                    Sorry for my English Gramatic - I am bulgarian man and my English is regular...
                    • #55
                      Looks like Yildiz,,, acts like Perendev,,, works like slo-mo-gen
