ufo technology made in SPAIN
in English?
Can you post it in English?Sincerely,
This is a mechanic translation from uncle Goo...
Hello Friends, I will try to explain again the concept of propulsion that has been my invention, pictured on the left are observed strokes painted orange and red which emulate PLASMA paths which follow the PERMANENT MAGNETIC FIELD lines GENERATED BY A CURRENT through the coil which is inside the hood of ceramic, plasma is created between two ring electrodes heated at high temperatures which are connected to a source of medium voltage AC , high frequency and good amperage, a priming system unexposed ion is responsible for initiating the plasma, the essence of this experimental propulsion system is based not yet tried to create a torus ROTATING PLASMA which strikes the surface FUSELAGE EXTERNAL PRODUCT AND IS PUSHING THROUGH THE ACTION AND REACTION OF PLASMA ACCELERATOR FROM OUTSIDE WALLS OF BELL CERAMICS ... in the illustration the orange line corresponds for example to the trajectory of plasma in the 1st half cycle which bulge out, then the red line corresponds to the trajectory of plasma in the 2nd half-cycle (with opposite polarity to the first current) that camber inward due to the static magnetic field polarity of the coil.
