wow johnstone!
Thank you for all your hard work, it looks very professional and will be a huge help in replicating these motors. Ive found with my asymmetric RS motor (dual pentagons) that the radiant output is much better if I pulse it...to put it into other terms i have 2 capacitors across the input...now my motor was not centered perfectly so when i turn it on it jolts to one side and will sometimes take some of the wires off the brush and lower in RPM. Ive found that when the capacitors are charged, and there is a spark discharge into the next coil when i turn it by hand....the radiant output is still there bright and clear even when the motor doesn't turn. I think this is because the coils on the generator side are in the proximity of the coil being pulsed. I also think this must mean there is more radiant to be tapped into, as the other coils are probably also producing it as well. Timing is very important on both input and output side. SO is pulsing. Learning a lot first hand and I really appreciate all you contributing. I constantly keep up with the forum, you guys are great teachers and experimenters!
Warren
Warren
[/IMG]
