  • Fourty Eight Seconds...
    Originally posted by machinealive View Post
    micro-controlled rotating magnetic field.
    Spinning toroidal field - YouTube
    Hey...
    Starting the WAR?...dropping bombs?
    Just like that?...Like the "Fast Delivery Post Man"...
    I told you you will get that Compass Needle spinning like a Fan ...now in "Low Mode"...Does needle rotates on Bearings?...if not I see it Popping out of glass...just like Alice in Wonderland's... Rabbit's Clock...
    Nice...I like how you are applying the Quad Pulsing Signals for other Applications...useful Uh?
    Am sure You know very well what you are showing in 48 Seconds...
    1-A Columbus Egg rotating in Stepped Pulsed DC...or could We please... call it "A Progressive Shifting"?
    2-The Principle behind an Asymmetric Brush Less DC Motor...
    3-A Self Rotating Figuera's Drum Generator...
    4- Imagine You get Two Identical Toroids...but invert the Four Channel Order and set two independently rotated Discs in the Outer periphery...could We get off ground?
    Love it!
    Kind regards
    • Tesla Diametrical Rotor...Postcard
      TESLA DIAMETRICAL WOUND ROTOR:
      [IMG][/IMG]
      ONE COIL STEPS (PART 1)
      [IMG][/IMG]
      Ok, this Post is "Machine's Style" dropping Bombs ...
        [IMG][/IMG]
        [IMG][/IMG]
        Suggestion....use two coils instead of one. Wire them together so that you generate square a square wave when you load them. Spin magnets, instead of spinning the coils, this simply means that your inner runner commutated DC motor will be treated as if it were an out-runner.
        • help identify this part
          UFO, team. et al,
          Had a bit of an extended absence and have been away from my lab, we are about a week away from being able to play again, doing work for a friend on his project and this brings up the reason for the post.
          So the question is; Has anybody ever seen anything like this in anything they have scraped? , it would be easier to get these from a manufacture rather than take this to a machinist and ask them to duplicate the piece.
          In these pictures the unit is on a ratchet handle just to hold it in place, it is made to slip onto a 3/4 inch shaft and the unit is about 3.3 inchs OD.
          https://www.dropbox.com/s/n0tuhhfq09...3%5E4body3.png
          https://www.dropbox.com/s/ebnuroppwu...3%5E4body3.png
          The sooner we can ID this part, the quicker I can get back to my lab and work on the UFO motor. Please help me identify this part.
          Many Thanks to everyone for all the fine help you have provided.
          Hitby13kw
          • reverse image search
            Hitby13kw,
            Google has an Image Search Feature that may help:
            Search by Image – Inside Search – Google
            How to search by image
            Use Google Lens to learn more about an image or the objects around you. For example, you can take a photo of a plant and use it to search for information or other similar images. Search with an image
            Search by image allows you to do a reverse image search and discover all sorts of content that's related to a specific image. For example, search using a picture of your favorite band and see search results that might include similar images, webpages about the band, and even sites that include the same picture.
            How to search
            IndianaBoys
            Originally posted by Hitby13kw View Post
            UFO, team. et al,
            Hitby13kw
            • Image - What is it?
              Hitby, seems it might be a 'swash-plate'. It would have cylinders-pistons
              parallel to the shaft. I think the old WW II torpedoes used compressed air
              to drive the propeller with one. Also similar to a GM air-conditioner compressor.
              • About Tesla Wound Coils...
                • I will try...for sure.
                  UFO, team. et al,
                  Hitby13kw
                  Hello Hitby13kw!
                  Man...I will go to the FBI and the CIA...if I have to...in order to get you back here working on your Imperials!!...
                  Like Jeffy said...it does looks like a Swash Plate...but then again I see the Ring to be uneven or elliptical...
                  Does it has a center Pivot Point at Inner Ring?...like a ball joint?...or is it a Fixed piece?
                  Looks like the Cam for a Pump or for "something" that uses the "uneven" ring shape to spread or close a valve, a spring joint...or a gate.
                  Nice to hear from You!
                  • Last edited by hanon1492; 11-06-2013, 10:59 PM. Reason: Adding the modified schematics
                    https://figueragenerator.wordpress.com/
                    • [/IMG]
                      On the above Diagram We have the Full Set Up...with the Two Inducing Coils...However, in order to start from the simplest form, I have chosen to just review One Coil in our first analysis...
                      [IMG]
                      • Ufopolitics,
                        Looks real good!
                        Help us with construction plans in building this in it's simplest form!
                        Good man,
                        IndianaBoys
                        • Spin Torsion Fields...
                          Originally posted by SERG V.
                          Привет machinealive !!
                          Nice experiment. Kind of Steve Mark TPU stuff !!
                          Be carefull with that kind of toys !!. I don't know the strenght of Magnetic field in your device but you should know that after running it continuously 15-20 minutes, Spin-Torsion Magnetic field make unresearched kind of Magnetic Phantoms which continue existence up to two weeks after you have turned off device. Turning on again you will prolonged their life time. Problem is - that kind of Magnetic Phantoms can interact with living creatures on unknown horror ways. Be sure it is a way to twilight zone.
                          The Spin-Torsion fields make terrible structural demages at all organic and nonorganic structures like for example gamma rays but much harder. Torsion Physic is very dangerous discipline. That fields can't be shielded for now. Nobody knows how to protect from them. I know for many physicists in Russia and America {probaly anywhere} which have payed down the biggest price - with their lifes. Depend from strenght of Spin-Torsion field and Angular speed of Magnetic Mass the cut-off life process can be momentarily like in well known US Navy philadelphia experiment when they had lost complete crew - half disappeared from our dimension - other half get out of mind after return. I know Tesla explicitely had forbid that kins of experiments with humans but US Gov. didnt want to listen him. In final account - people had payed for Gov. ignorance, and soon after that, Tesla had been killed.
                          As in Russia says: Warned - Armed !!
                          Reg.
                          Сергей В.
                          • Originally posted by IndianaBoys View Post
                            Ufopolitics,
                            Looks real good!
                            Good man,
                            IndianaBoys
                            Hello Indiana Boys!
                            I am sorry...but can NOT say "no more"...it is due... that I have recently signed an NDA Contract with Machine Alive...and Cornboy555
                            • I like it...
                              Hello Mi Querido Amigo Hannon,
                              I like this approach, as far as the "8" shaped Induced coil, rotating at center of square hole, it is A Possibility.
                              What I find that it may not work...would be to have all inner exciters projecting North towards all outer projecting South towards Inner space...why?
                              Picture Induced Electricity as a water flow...and by running the conductor through same fields in the whole circumference would not generate a "push-pull" force to that "water flow"...therefore, electrical flow will be induced eventually...but flow will not "move" forward or backward...it will remain on same area of conductor length at induction...
                              Maybe am wrong...check it out...
                                Hello Indiana Boys!
                                Talk about split your sides,
