Making some progress on Baldor commutators
Sorry pics soon. At intermediate state, 75% of wires on commutator successfully brazed. Put the commutator in a pan of water so it would not overheat. used an acetylene torch. Micro butane not up to the task with wired attached to big-heat sink comm.
Stripping all insulation a slow job on the 80 wires. To be absolutely sure it was all gone on a wire I ended up tinning them with the verbotten (forbidden, by UFO!!) solder. I found that it acted like flux during the higher temp brazing process, and alloyed to probably make a slightly lower temp melting point so I have less of a chance to burn my commutator hopefully. I did not want to chance carbonized insulation interfering with the weld process. After I apply connectors next, that will be the last time heat will have to be applied to the commutator as it becomes completely reusable (Waiting for when I convert the Baldor into a 4 stator, or build a double long generator,
I had to develop a technique for inserting new wires as one commutator segment that had lost its wires during my haphazard removal process when I thought I was going to dremmel out all wires and redo the slots. I doubled up on the 19ga original wire about 1", brazed it together to make it a little wider and flatter to completely fill the slot after the last manufacturer's piece was removed. I left the wide rounded tip stick out on the surface on the slot. and then I hit it with a flat nosed punch to simulate the manufacturer's process. The protruding copper head of the new doubled wire compressed tightly on one end and the gaps closed up nicely the entire length. Victory!
back to nursing my hips
big snow storm coming New Jersey
)I had to develop a technique for inserting new wires as one commutator segment that had lost its wires during my haphazard removal process when I thought I was going to dremmel out all wires and redo the slots. I doubled up on the 19ga original wire about 1", brazed it together to make it a little wider and flatter to completely fill the slot after the last manufacturer's piece was removed. I left the wide rounded tip stick out on the surface on the slot. and then I hit it with a flat nosed punch to simulate the manufacturer's process. The protruding copper head of the new doubled wire compressed tightly on one end and the gaps closed up nicely the entire length. Victory!
Meaning, they can upgrade any motor; neodymium magnets, aluminum case, redesigned brush housing...etc.
The amazing thing is that they actually worked and were much stronger than the original motors. Take what you have and work with it. If you have woodworking tools don't be afraid to use them for metal working, I have found that they can be used very well. If you have metal working tools use those. You can do this work with hand tools but it will be easier with power tools. But if you just want to prove the concept and make an inexpensive project use hand tools if that is all you have. It can be done that way. It has been said before, if I can do it anyone can. Just work safe and enjoy the path. You will learn a lot and have fun too.
It would be clearly understood then, the Original would draw much less amps (Duh!)...
