Turion
Turion:
[IMG]
[/IMG]
If the Upper Comm Motor Input brushes are Positive, then The Generator Brushes for upper comm are Negative, never Positive. Generation is always "dependent" of Input.
However the connections are not wrong though, so I will try:
1) Trying to adjust Generator Brushes (if possible, without messing up your Motor Brushes.
2) Try swapping the Jumper between Gen (-) and Gen(+) as also the Output of Generator, direction of rotation affects which is a better set up.
I have explained about this Issue on the best Gen Angles for brushes depending on rotation...
Ufopolitcs
Turion:
[IMG]
[/IMG]If the Upper Comm Motor Input brushes are Positive, then The Generator Brushes for upper comm are Negative, never Positive. Generation is always "dependent" of Input.
Ufopolitcs
[/IMG]
