Originally posted by Ernst
My first suggestion is to use plentiful decoupling capacitors very near to the supply pins of the TC4421 (1uF, 470nF, 47nF, all in directly parallel with the supply pins if you have not done so. I say this I suspect the nearfield of the
coil(s) may induce unwanted voltages in the driver circuit. Also try place a 1 kOhm or so 'terminating' resistor directly across the input pin and the neg. supply pin of the TC4421 to prevent it becoming high impedance for any moment, to be able to pick-up any nearfield induction, this will not affect the TTL drive level at all.
If these are of no help, then it may be about duty cycle, you wrote all the voltages and currents are within spec, the MOSFET dissipation simply exceeds the power level which could be allowed for free air cooling without using any amount of heat sink. At 12V supply voltage and at the same ON time for the MOSFET the self-dissipation is many times higher than at 5V, just consider the FBT's drain coil's DC + AC impedances: how much peak current can flow when the FET is ON, that current heats the FET.
What you wrote on the driver's high speed switching and due to this the flyback pulse may approach or exceed in amplitude the limit of the MOSFET drain-source max voltage rating, well this could surely increase the FET's dissipation too. An oscilloscope test on the drain peak pulse voltage is in order of course.
So maybe using a normal heat sink for the MOSFET is the solution, if the peak drain voltage is also ok, that is all, once you are satisfied with the currents and voltages. ?
rgds, Gyula
) gets so hot in seconds, that I burned my finger on its heatsink.
) dream.
