"Basic" Principals of Wireless Energy Transmission
  • "Basic" Principals of Wireless Energy Transmission
    On reading Tesla's Colorado Springs Notes I see that Tesla says for power
    transmission the transformation ratio is most important and is the method that
    must prevail.
    As far as I can tell the basic principal is that a resonant ground
    connected transformer with an aerial capacitance will cause currents to flow
    through the ground and if another resonant ground connected receiver is
    tuned to the same vibration depending on the strength and frequency of the
    currents being sufficient it can receive and transform the ground currents into
    an output at a distance with no solid connection except the earth.
    The voltage achieved at the Air terminal capacitance, it's capacitance and
    the resistance the currents are met with determine the strength and
    magnitude of the currents. The frequency used has an effect also, the higher
    the frequency that is used relatively reduces the effective distance, or
    increases the losses over distance.
    For the power transmission side to work well, I think only a full sized system
    would be efficient. ie, one that was tuned to the size of the planet and was
    powerful enough to impress the required vibrations.
    I don't see any reason to believe that any of us will be able to achieve more
    than "signal strength" transmissions over a distance or quite lossy
    transmission of "some usable" energy over a relatively short distance while
    using frequencies that are too high.
    We can see the results Tesla got lighting some incandescent bulbs from a
    fairly short distance with his multi million volt oscillator at less than 100 kHz
    less than 50 kHz actually I think.. I don't think any of us will do better than that.
    "ground" wire transmissions like Meyl shows are a piece of cake. The lower the
    voltage and frequency the less energy escapes, Meyl uses HF but low voltage
    and only short distance and he uses a (WIRE). for pete's sake.
    This is just my uneducated take on the whole saga.
    Eventually I intend to do more experiments with fairly low frequencies 2 kHz-20 kHz
    and moderately high voltage and resonance while using only the ground as a
    conductor over reasonably short distances and using moderate power levels.
    Tesla uses a voltage as high as possible so that the elevated capacitance could store as much charge as possible. He wants to set as much charge as possible in motion so to get the largest possible disturbance in the earth.
    Calculating with the speed of light, the electric impulses need 84.88 ms to travel through the earth, to the opposite side and back. So if you are using a frequency that is a multiple of 11.78 Hz, you can re-use the echo. (saves energy )
    Higher frequencies are easier to use but result in greater radiation losses.
    Lower frequencies have less radiation loss but suffer from solar interference.
    Tesla found that a frequency between 20KHz and 30Khz is most economical.
    I would suggest to use a 3 coil system, saves a lot of expenses on copper wire but is very difficult to tune for a 'first timer' (?). I can try to help you with the calculations on that one.
    I am currently also building one for my Wardenclyffe 'proof of concept'.
    (excluding the transmission part, though)
