Hi Boguslaw,
I don't think that the Hendershot generator runs at the sort of frequencies associated with spark gap technologies, and it is possible the longitudinal resonance induced within the core could be 30 to 60kHz, so although I suggested a modulated RF generator, it would need to be one running at low RF frequencies, or even be an audio generator having extended HF range. Besides, the TV frame output transformers would still be useful at this sort of frequency, whereas the cores used in mains transformers would be much more lossy.
Also whilst lamps would still run at that frequency your question about other equipment is most valid, because 'no' - a 50-60Hz modulated carrier is quite unlike 50-60Hz mains, and coiled wire heaters might have a self inductance which would effectively reduce their dissipation.
The Thomas Edison observations related to vibration are new to me and likely require further investigation, especially if this related to the vibration of 'magnetic domains'.
Hi Chris.
You know what, I have mused so much about this I find it difficult to find any starting point.
I have not heard of any works by Joseph Cater either, so obviously my studies must continue.
Re the magnet keeper; obviously to maintain maximum field when not in use, for the gap could not have been completely closed during operation.
Also yes, I believe the mass resonance would have been at a carrier frequency, with the those 40uF capacitors able to introduce phase change at such frequency.
Another reason why I think a travelling wave is longitudinally induced within the core is due to the twice phase shifted low impedance outputs of T1/2 being fed to L3 windings with respect to L2 and the single phase shifted drive to L4.
Anyone have an original Hendershot generator I can get my hands on, or even if I might directly question any owner of same to fill in some of the blanks ?
Is Mark Hendershot still alive and amenable to open source questions, for there is no way I would be willing to do this in a non-public way ?
If yes, does Mark communicate via the internet ?
Cheers ............. Graham.
Hi Chris.
