CapCoil calculations
I started on that document to compare the different documentation on the Hendershot device and immediately ran into discrepancies other than connections. The doc in the Mar-Apr 1989 JBR,Pg25 drawn in 1963 by Edward O'Brian RE the Aho build shows the inner can as 3" tall. Going by Fritz Lowenstein's work on capacitances, the smaller of the plates has the most affect upon capacitance. The second plate can be very much larger without adding even 1% to the capacitance value. The innermost cylinder must, by definition, be the smaller of the plates if it is connected. I used the calculator you linked to above with the parameters given but changed the 2.75" to 3" as stated in Edward O'Brian's work and the result was 0.007788uF. which would be 7.788nF. That's not to deny that the wrapped foils are 2.75" wide but the wrapped foils being so much longer means that they don't have as much affect on the capacitance as the innermost cylinder.
Now that I have most of my materials list together I found another reason to justify using 3" rather than 2.75". In all of the photos I've seen the inner cylinder extends above the coils somewhat and if you add up the number of turns of each coil and the thickness of the wire used in each coil there is no way that the L1, L2, and L3 coils would be less than 2.87" which would cpmpletely cover all of the inner cylinder if it were 2.75" and none of the photos show that. In fact they all show the inner cylinder extending above the uppermost coil.
I also found out that PVC was first used as wire insulation around 1950 so it seems I've been chasing my tail searching for the 0.100" O.D. wire. That 2.87" height above comes from using PVC jacketed 20 AWG solid with an O.D. of 0.066" for the top 2 coils at 12 turns each.
All of that also depends on the assumption there is indeed a connection to the inner cylinder since it would have to be the smaller plate of the capacitor part of the CapCoil.
I'm wondering how you came up with the dielectric constant of 3.5 and the 5.25" diameter in your calculation.
I also found notes in the From The Archives of Lester J. Hendershot document by Mark Hendershot that are hand written by Lester J. that say ".0078 MFD or posibly 1.3 MFD (see notes Orig.)" Emphasis added. Page 45 of the PDF document.
One other thing on the CapCoil: I don't think it said anywhere that the foils were taken from a Pyramid 80/40 cap. The statement was a Pyramid TM58, but that might just be the the part number for the 80/40 cap. I'm not sure.
I did find a Pyramid 40/10 cap and it is on its way. Its not for use in this project but it can give us the thickness of the foil and paper when I disassemble it. That brings me to another thought - the electrolyte in the old capacitors was basically a salt solution and failing to completely remove the electrolyte may be what led to the rusting of the coffee cans. It could have leached through the 3/4" inch gap in the shorter foils to the inner paper around the inner cylinder.
More to come on materials list.
In the mean time here's an article you may find interesting: Magnetic vortex oscillator driven by dc spin-polarized current
