Hi folks, thought to start a new thread, as this may be of value to others.
Know that others have experimented with this in the past using ignition coils and other methods of high voltage pulses.
Though, it seems very very little information is to be found on the internet about using this age old method that Tesla used, that of higher voltage impulse methods.
Going to re-post this from other thread and also another circuit a man shared on a web site.
Please feel free to share any and all information and experiments you may have relating to powering gas filled bulbs without needing to use the filaments inside of them.
Though am aware that cold cathode fluorescent bulbs still use a warm filament inside, its temperature is far less than other standard fluorescent bulbs.
Ideally though, we would want to have a device that does not need to use these filaments at all, so that a gas filled bulb can used forever, or as long as the gas remains and other phosphorescent illuminating properties remain.
Also, here is a link to the web site of the man lighting burnt filament cfl bulbs and a link to his youtube video.
http://makelifeeasy.yolasite.com/
Burnt CFL Re-Light - YouTube
Also, here is the latest transformer/circuit tested that seems to be powering a burnt filament cfl, one filament is burnt out on one side and is still lighting the cfl well.
Uploaded with ImageShack.us
peace love light
tyson
Hi folks, been focusing on lighting fluorescent hot filament bulbs with higher voltage, similar to what people have done with ignition coils and such, though in this case, not quite so high of a voltage.
Have built a few different transformers over the past few days, using the Meissner oscillator circuit to power them, as the heat and efficiency seems better.
The latest model seems to be working very well.
The core is made from two, glued together home speaker audio crossover, solid ferrite rods.
Then, 6 layers of 30awg. magnet wire, for around 1500 turns with electrical tape between each layer.
Then, on top of that, 4 layers of 16 gauge speaker wire, for 56 bifilar turns, or 28 primary turns and 28 trigger wire turns.
The bulb seen running in the image, has a blown filament on one side and is still lighting very nicely.
Not completely sure if the bulb is somehow still using the other filament to help light the bulb, or if the high voltage alone is lighting the bulb, which is the goal.
The cfl shown is a 13 watt, using 680 milliamps at 12volt input.
Share your thoughts on this, as the goal is to light these bulbs without using the filaments, or basically a blown bulb that would not work in a normal wall socket, even if the cfl electronic ballast was fine.
And feel free to share any experiments of lighting fluorescent lights that are essentially blown or like a neon glow tube or cold(warm) cathode fl.
Thanks.
Thanks.
peace love light
tyson
