Mbrowwn says this in another thread about Imhotep's device:
Originally posted by mbrownn
Hi velacreations
I don't know what this whole debate has been about, didn't anyone tell you about the fan?
All they had to do was show you that because it is scalable like this http://www.modvid.com/bedini/images/bedini_monopole.jpg or even bigger like this http://www.cheniere.org/images/peopl...ni/Image12.jpg They are even available in kit form to make the build easier like this http://projectavalon.net/Bill_Ryan_J...enerator_1.jpg
OK this does need batteries and noone has successfully looped one back to itself as far as I know but they do work.
Now go on, build a fan and test it, you know you want to.
The instructions are here Imhoteps Labs select Imhotep-Bedini-SSG
To show the overunity you will need two cheap lead acid batteries, in good condition, whose amp hour rating is around 10 to 20 times the amp drain of the fan. The hardest part is measuring the mechanical power of the fan as it is so small.
You will get a charging efficiency in excess of 90%
The mechanical efficiency is around 20 to 40%
If you don't get these results just ask any of us for help, I think most could help you get there.
If you add generator coils to the fan, this is difficult because it is so small, their output will be about half the mechanical power giving a total electrical output of 100 to 120%. My tests showed that combining the outputs was inconclusive but if they go to two separate batteries the efficiency was more evident.
It is not a good idea to loop it back to the supply as batteries do not like to be charged and discharged at the same time, It shortens their life and the pulse output of the fan would short on the source.
This is a proof of concept type of device and not practical to run your house, but once you understand that there must be an input from another source, ie an open system then that leaves lots of other possibilities for building open systems. This explanation is the only thing mainstream science has had to say on it but will not, as far as I know, confirm the results. No conspiracy, its just they haven't tested it.
The conspiracy theory is why haven't they tested it?
Good luck with your build, I hope you get it right first time
