Produce gold
  • #31
    Below: Close up of the crystals in the bowl. These are not as dense as with the beaker because the electrolyte is less concentrated than with the saturated solution with the beaker. (Still 600g of silver dissolved in 4L of the electrolyte alone)! Thus a weaker current passes. This forms smaller crystals. Nevertheless they are still pure.
    • #32
      Microscopic
      On a micro-scale this is exactly what's happening:
      https://www.youtube.com/watch?v=fnyBldC4Ra4
      Yeah, its cool photography! It looks to me as some of the crystals take on almost an electrical discharge like formation...
      • #33
        Biological Transmutation
        Alchemy is fairly simple besides the last step .
        First all the above post are not actually refereing to Johns work .
        I will quote him
        " First you chew your food , the it fals in hydrocloric where its broken down further "
        Here we come to Russells work which is corroberated by Telsa his friend .
        Below the actual minarals or above Hydrogen rather is a energy form which is in all our food ( beside refined foods or artificial) in all life and even mater .
        Now he makes reference to the frequencies of the ovens when transmuating on ogyxygenless copper .
        What frequencies ? ehh , the heat frequency .
        So only the colling down period & frequency are relevant to then change "the present energy form " into another material ....
        Ormes video ( rather spectography of russia & later US by Ormus rediscoverer ) does the same BUT they don't stop the process where they want .
        So if you burn Ormes powder you will burn the powder first then after a minute or so ( when everyone switched off device already but russians kept going ) you will see Ormes jump through the Periodic table ... never all at once as is usual for spectography but 1 by 1 jumping to the next element .
        John told us how to make Gold in transmutatiom .
        Prof Kervran wrote it all in his book and Japanese made Gold for sure as they eluded to the fact that they could make gold the same way that sodium was transmutated to magnesium .
        By the way Alchemy is this for example .
        2 carbon rods arcing at + 50 volt ( i see many different methds )
        I did it with a capacitance charger which is more fun as you can pull it appart and vary the power dynamically .
        and it goes like c+c +o+o = Ni but 2 electrons r dropped in proccess & fals to FE which weight matches c+c+o+o
        LOOK take any element on the periodic table and try and match it to either Oxygen or Hydrogen ( oxydation or reduction ) and you will fnd transmutation potentials .
        If I had a clever mathmatician @hand i would lay out gold for you as well .
        3 elements to Nuclear , 3 elements also apply to LENR aka alchemy
        Use something compressed to start with and you remove 1
        the 2 others are high instant power and heat .
        High spiking voltage is one way as above or heat , Brownsgas for instance .
        Now with brownsgas you get Hydrgen and H2O , it heats up from inside to max potential .
        You can do alchemy simply by using a Brick or roof tile and heating it with brownsgas .
