strong evidence ( mathematic + physics ) we can build perpetum ?
  • strong evidence ( mathematic + physics ) we can build perpetum ?
    Dears All
    Below real discovery physics not pseudophysics
    ( I WILL GET NOBEL - TRUTH NEED TIME BUT NEVER DIE )
    we have huge Gap in classical and modern physics
    This what You have here = argument for all people who like fight with universities. They are blind ( only people who try can win and will win )
    Br to all inventors my own patents /ideas
    MAROSZ'S PATENTS
    The principle of conservation of energy
    ...........................VS ................................
    The principle of conservation of momentum
    The principle of conservation of energy VS The principle of conservation of momentum - YouTube
    Thank You for support all good people !
    important pdf ( main drawing from Yotube)
    Please imangine balon inside rocket
    ONE PIPE + PERFECT DYNAMITE E [J]
    TWO IDEAL THE SAME MASS "m"
    or One balon and two mass m
    Water always go from mountains to sea ( not from sea to Mountains )
    Mountain = high energy level
    Sea = Lower Energy Level
    m=m but mL = m R ?
    ( inertia - in one polish book - author used word resistance"
    Other polish inventor Lucjan Łagiewka "
    Mr Lucjan bumper ( 54 sec ) - Project EPAR Lagiewka Bumper small test - YouTube
    How it work how to stop car 50 kg own mass ... so short distance
    without Inertia problem Glass
    Mr Lucjan live close to my Home
    " Maciej - Energy always go more easy there where feel lower resistance
    - my bumper = lightning rod !!!
    mL= sea
    mR = mountains
    HOW TO EASY EVALUATE ( Inventor = simple idea ) ?
    Stationary point A in the Universe and mass m = 1 kg
    A . m ------> Vo = 1m/s
    1.> What mean one pipe and dynamit ?
    2.> Energy. where is Sea level where is Mountain
    - where is neutral line ?
    3. > How to easy confirm on Earth different ( Left - Right )
    ..... - How to recognize direction mountains - sea = -------> Vo
    point 1 > One pipe inside pipe we have one preasure !!!
    fact a) the same forces
    fact the same time ( work time )
    Fact a ) AND Fact = > Force F time t (perfect symetric condition )
    point 2 >
    Ek= m*Vo*Vo/2 = 1kg * 1m/s *1m/s /2 = 1/2 [J]
    question 1
    How many energy I need to stop mass m ( respect to A point )?
    Ek2 = 0 Ek1 = 1/2 [J]
    1/2 [J] - to stop mass m I need 1/2 [J]
    guestion 2
    I have 1m/s I want to have 2m/s
    how many energy I need to accelerate mass m from 1m/s to 2m/s
    Ek2 =? Ek2= 1kg * 2m/s *2m/s /2 = 2[J] !!!
    2[J] - 0,5 [J] = 1,5[J]
    DO YOU SEE 1,5 [J] different ( Sea - mountains )
    point 3 >
    TWO OPPOSITE ROPES TEST
    "*"- star shows hit direction
    rope A *[-----------------]
    -----------> (Vo Earth's speed in the universe)
    rope B [-----------------]*
    please use perfect twins hammers and hit at one time rope A and rope B
    You will see that Hz A not equal Hz B ?
    Bell's Telephone can be new GPS - YouTube
    more info >>> Internal doppler
    PHOTOCAMERA AND BULB TEST
    more info http://tesla2.blogspot.com/ - YouTube
    more info You Love Life | You Deserve the Best
    ONE LASER TEST
    >>> One laser - TEST
    CLASSICAL MECHANIC Foucault pendulums
    >>> Rope + mass = New GPS
    The steps you take are too big, therefor you miss some important details.
    Let us look at the pipe at the moment of the explosion.
    The pressure inside the pipe rises. Pressure inside a closed container is uniform, hence the pressure against all sides will be equal. The pressure against both masses will therefor be equal as well. If the area closed by mass M(left) equals the area closed by mass M(right) that means that the forces on M(left) and M(right) are equal.
    Given that the forces and the masses are equal, then the acceleration for both masses is equal and in opposite direction as seen from the center of the tube.
    Let us stay with low speeds so we do not have to consider relativity.
    Say the rocket travels 100 m/s and the masses get a 10 m/s2 acceleration and are 1Kg.
    Before the explosion, the combined energy of the masses is
    E(kin) = 0.5 x 2 x 100 x 100 = 10000 Joule, that is 5000 Joule for each.
    1 second after the explosion (supposing uniform and constant acceleration):
    M(left): E(kin) = 0.5 x 1 x 90 x 90 = 4050 Joule
    M(right) E(kin) = 0.5 x 1 x 110 x 110 = 6050 Joule
    They (combined) have gained 100 Joule from the explosion.
    Considering their momentum:
    Before: each one 1 x 100 = 100 Kgm/s so 200 Kgm/s combined
    After: M(left): 1 x 90 = 90 Kgm/s, M(right): 1 x 110 = 110 Kgm/s, so 200 Kgm/s combined.
    You see we do have preservation of momentum, and without taking the chemical energy in consideration we do not have preservation of energy.
    But of course the seemingly extra energy comes from the energy that is contained in the chemical bounds that hold the dynamite together. When the dynamite explodes this energy is released.
    Sorry, but this will not get you a Nobel prize.
    Now if you would like to make a perpetual motion machine, consider the last 7 US patents from Tesla. The speed indicator for example, based on a bladeless turbine.
    If we were moving in a ship, we could drop this specially designed bladeless turbine in the water and it would start moving, because of the force from the water.
    Simple, isn't it? The turbine would move as long as the ship does.
    Now then....
    Replace the ship with planet Earth, the sea with the ether and the turbine with a flat spiral coil. We only need to design something to create an unequal flow on the left and the right side of the coil and the energy would flow through the coil forever (as long as the Earth moves through the ether).
    Work on this and your chances at a Nobel prize get significantly better.
    Ernst.
      In addition to my previous comment an example:
      Suppose I have a gun that shoots a 5 g bullet with a 450 m/s speed.
      (this speed is relative to the Earth)
      The kinetic energy in this bullet is:
      E(kin) = 0.5 x 0.005 x 450 x 450 = 506.25 Joule
      This energy must have come from the explosion of the gun powder.
      If we do the same calculation relative to the sun, so we add 30000 m/s to all speeds.
      The initial kinetic energy of the bullet then is:
      E(kin)(0) = 0.5 x 0.005 x 30000 x 30000 = 2,250,000 Joule
      After being fired this changes to
      E(kin) = 0.5 x 0.005 x 30450 x 30450 = 2,318,006 Joule
      an increase of 68,006 Joule
      So...
      Does moving gun powder explode more violently than gun powder at rest?
      Think about this and you will find the key to your error.
      Ernst.
