Well here is a definition from Encyclopedia Britannica.
Lenz's Law definition.
Lenz's law (physics) -- Britannica Online Encyclopedia
From the page.
I think because the magnetic field has energy concentrated in it and this
energy has to dissipate, it cannot just disappear.
I think the old explanation of the inductor trying to maintain current flow is
not really entirely accurate, in my opinion because of the energy of the
magnetic field having to dissipate due to not having a current to support it's
continuation, when the current that makes it is stopped then the energy simply
looks for the easiest way to dissipate and takes the path the original current
took if it can if not it will take the next best path or just oscillate the coil
until dissipated.
I don't think it's a matter of the inductor wanting to keep the current flowing,
I think it's a matter of it's the energy of the magnetic field's best or only way
to dissipate. Effect is the same so not important.
For the simple definition of Lenz's Law to be shown as not always correct I
think an induced current would need to be caused which aids the change that caused it.
I don't think that simply showing a generator rotor accelerating under load or
a transformer's reduction in input power when loaded shows any Lenz violation,
I think it shows something else as the cause, probably more than one other reason.
P.S. I think Lenz's Law defines the effect of the transfer of energy by induction, more
energy transferred equals more Lenz effect, Less Lenz effect equals less
energy transferred. All my experiments point to this being true.
Originally Posted by Boguslaw
I still do not understand. I believe magnetic field has always two poles,right ? So you are stating that when I take a large magnet and move it's N pole to the wire, the current generated inside wire will create magnetic field of what polarity ? North ? South ? and where is the opposite pole created ?
Collapse what ? Why magnetic field do not just vanish immediately in no time ? Looks like it has a supporting "thing" inside wire ?
until dissipated.
What Lenz described is the basic inherent properties of an inductor. These are the properties that make an inductor act like an inductor. These properties exist due to the self induction that occurs in an inductor. If you don't have those properties, then you don't have an inductor. You will have something else.
