Free energy already exist
  • #76
    Originally posted by jdodson View Post
    Seems you missed ewizards point. A machine claimed to be running itself IS using an external force.
    Precisely! I'll go with the hidden wires from under the table.
    ...within days after getting my first generator I was able to get it to run by itself with almost no effort. This is proof that free energy has always existed...
    Anyone with half a brain should know perpetual motion is not eternal motion.
    Seems the two of you not only reject mainstream science but also any commonly accepted definition that doesn't suit your needs.
    • #77
      To inventionmaster
      Have you re-invented this product?
      Self Running -1000 Watt Fuel Less Generator by air2gas
      It's a 1000 watt fuel-less generator.
      • #78
        My Pleasure Inventionmaster...
        Originally posted by inventionmaster View Post
        Thanks for the info Ufopolitics.
        With enough mods I bet I could create an engine that would run in this manner (edited pic). When energized I would have some kind of super magnetic force yank down the piston (rebuilt with different material) at such a high force that it would be able to completely replace the explosion. Maybe each cylinder would act as some sort of rail gun chamber. The chambers firing sequence would be similar to the original. As a matter of fact I would build a new type of engine block that would even further aid in the firing process and downwards force. I would most likely even add an upwards force for additional power and it wouldn't stop there. I could come up with all sorts of ways to make it work
        Yes, my pleasure Inventiomaster,
        Exactly you've got the point, and many ways here to add and improve... like for instance, if you use "face to face" coils at piston-head encounter, where only the cores meet...then you could use what you have painted as a green coil surrounding cylinder chamber at head as an exciter coil for the piston coil...being the piston coil same approach as a brushless generator stator (a closed/looped coil through a Diode and a Varistor/Movistor. to maintain average current)..this way you do not need to use any internal contacts or wires at piston.
        Or...you could use it as a generating field coil , induced by piston magnetic field.
        Related the "Firing Order"... you are completely correct...using same as gas engine does creates a mechanical balance once you have equalized Forces per piston...
        That could be easily achieved by an electronic pulsing sequence per Cylinder Head/Piston following same firing order as gas engine...or the same exact thing as a Spark Plug Distributor...or an Electronic Ignition Module does in a Gas Engine.
        On a separate note:
        Inventionmaster, if at any point you consider my posts here to your thread are annoying or interfering with your work/development...please let me know and I will take off "Vertically"...like a UFO...at speeds faster than light...
        • #79
          This product is very similar to what I have built (I did not know if someone already built one similar to mine yet). There is one major problem I see with that particular machine though. It does not list the frequency of the ac current and I have doubts that the motor used in that project is powerful and fast enough to produce the needed frequency in order to run house hold things like televisions, refrigerators, ect. Plus it only provides 800 watts of continuous power which makes it far more limited.
          Some cheaper generators will give you the 120v without 60hz. By achieving 60hz (in USA & others) can you actually plug anything residential in.
          I was almost worried there for a second that it might be more efficient then mine until I saw the specs.
          • #80
            I will take any advise from anyone as it is my ultimate goal in life to take todays technology and advance it to an unimaginable level
            As a matter of fact most of the tech in my head is geared towards the most advanced space craft man has yet to build and as such free energy is just a basic thing for me because while in space you do not want to run out of anything. I've even came up with a very unique space engine design that runs off of hydrogen generated by a self production system. Kind of like a miniature earth that produces its on resources. It's a ship design for civilization in space. I've even come up with an idea that can truly achieve real faster than light speeds but I've yet too come up with a decent way to slow down. Slowing down will take a bit more thinking but one project at a time.
            • #81
              How I plan to fund most of my inventions is with a multi-player space game I'm building.
              • #82
                The number one question I have about space is does it really go on for ever or will you eventually hit some sort of field at the end and if so then what's on the other side???
                I believe that it is not space that is big but it is us that are small
                I really want to know what lies on the other side of space!
                It appears vast to us mainly because it is so much bigger than us and our planet but what's on the other side of it???????????????????????????????????????????????? ??????????????????????????????????
                • #83
                  Sorry, when Ufopolitics spoke about taking off faster then light my mind jumped into space mode
                  Sometime early this week I will go and get the wood bits I need in order to finish my generator mount. Then when my new charger comes in I'll take a video of the generator working. Sorry for going off topic.
                  • #84
                    The only reason why I'm trying to make video games is because it is a yearly multi-billion dollar industry. Just one good game can bring in millions even though I've yet too finish one. I've even seen stupid games make millions. This is the only way that I can be absolutely sure that I will get the funding I need for future projects.
                    Another thought:
                    I know a little about amplifying voltage and I also know about how the ignition coils in cars take 12 volts and amplifies it to like around 40,000 volts. I believe there is a way to store that energy into some sort of energy storage device. If that kind of power is successfully stored than I believe that it can be manipulated and converted into something usable using down-step transformers and other things to stabilize the final voltage output
                    • #85
                      Both a.king21 and I have been in contact with the guy building this motor generator. He may have something that works but he comes off with a sort of redneck mindset and does not inspire any confidence in what he may have to offer. He wants payment by cash or bank check, no guarantees at all, no returns and he wants the money then you need to wait a month at least for him to build it. If I had money to burn I'd probably give it a go but I don't. He seems to feel he wastes his time talking to people and I can see why as most people would be interested initially in this only to shy away with all his conditions of a purchase. And with no input / output measurements it seems very risky unless one can get some further verification.
                      From what I can see I don't think it is the same concept as what you have though. He says it has something to do with a Tesla switch and I believe he is using an electric motor to power the generator rather than a modified gas generator.
                      • #86
                        A tesla switch
                        Maybe he is using a step up transformer somewhere in there. Any other way there is usually more than one way to do just about anything
                        I sensed that using an already built and functioning generator was the easiest way for me to accomplish my goal. I always for years wanted a generator just so I could try something like this.
                        I have yet to test my generator on a full load but I plan to do so once everything is fully mounted on the new mount. I'm also rewiring most of it. I do love to reverse engineer things and then rebuild it into my own image.
                        I can't blame you for not buying it. Lack of specs sometimes makes me afraid to buy specific products. Besides if I was to spend that much money (which I don't have) then the generator would have to have way more then 800 watts continues available power and at 60hz because I'm after as much free energy as I can get.
                        • #87
                          He says it does output 60 hz and can be scaled up. He offered to build me a 10 kw model for the European standard - which is 50 hz and 220 - 240 volts.
                          The point is he treats it as a business, not some secret to never reveal unless he gets zillions.
                          So my advice is build your device and sell it, and get whatever patents you can. At least you'll have plenty of customers on the ou sites. You can even sell kits as long as they are D.I.Y. friendly.
                          • #88
                            That is one source of external energy. Do you not believe in any other source.
                            Do you really believe man knows everything about the universe? I am telekinetic I can make inanimate objects move at will, even while sealed off in rooms seperated from me. PLEASE explain to me the source of that energy. What LAW of man defines that.
                            Quantum Entanglement....Not everything needs wires under a table.
                            Instead of being a naysayer just let the creative people make all the great discoveries.
                            No idea what you are ranting about. I dont reject mainstream science. I simply think some theories are inadequate and will be rewritten when we gain a deepe understanding.
                            A solar toy car runs by itself using free energy.
                            That is an equivalent example of an OU machine.
                            Only difference is that one has a source we understand
                            If OU actually exists. I believe it does.
                            • #89
                              Inventionmaster you opened a new thread about running an internal combustion engine on water, if you can do that what is the point in redesigning a generator to run with a new type of power plant?
                              • #90
                                This is how I felt about doing it
                                Even though I knew that I could possible run the generator off of hydrogen converted from water there was still one major concern and that was noise. The generator's engine is just so loud. I'm sure neighbors would then file a compliant with the city if I was to run it 24/7 because it's so loud.
                                At least this way its not all that loud at all. It seems to be somewhat quieter than a regular house hold ac unit which will allow me to run it without disturbing anyone
