Plasma Containment
Courtesy of RMCYBERNETICS.COM More Electromagnetism - Coils - RMCybernetics
I think I have the solution to plasma containment: called a Penning Trap (Not Tested Yet).
A Penning trap is a set of electromagnets or coils that will create a controlled non-uniform magnetic field. The diagram shows how the magnetic field is slightly less intense in the centre of the trap. This 'bubble' in the field lines is where anon neutral plasma can be contained. A non neutral plasma is simply a plasma that has an overall positive or negative charge, such as a collection of electrons. A charged 'particle' such as an electron would require an accelerating force to move it across the magnetic field lines. Without this external force the electrons in a penning trap will tend to spiral back and forth within the area of weakest field. The converging field lines at each end act like a 'magnetic mirror' allowing the plasma to remain contained.
I don't know if the magnetic field can be pulsed or has to remain stable.
