How Electricity Is Produced
Learn The Top 7 Ways To Reduce Your Electric Bill
and Save Up To $800 Every Year.
GET The FREE Report Here!Tags: None
Fossil fuels, nuclear fission and bio fuels (human waste or otherwise) can all be lumped into one category - fueled. They all use the intermediate step of turning the fuel into heat to create steam and the turbine converts that heat energy into kinetic energy via the turbine and then to electricty.
Wind and hydro power avoids that intermediate step so are fuelless.
One of the other necessities, however, is control of the energy produced in terms of voltage and frequency.
The necessity of control is the problem with wind energy due to the inconsistency of the wind that creates the necessity of energy storage.
The energy converted in hydroelectric generation is from gravity so is consistent and does not require storage.
There is also a way to use nuclear energy to directly generate electricity. It is called nuclear batteries. These devices are used to power spacecraft like the Voyager probes that, since they are so far the sun cannot use solar power (they were recently reported to have left the solar system) and cannot be replaced, recharged, or maintained in any way. These batteries will provide power to the spacecraft for 40+ years but the output is low. These nuclear batteries have also been used on earth around the Arctic ocean to power lighthouses, again because they are not readily maintained: Radio Isotope BatteriesLast edited by thx1138; 08-22-2013, 12:39 PM.
You are very right.Originally posted by thx1138 View PostThere is also a way to use nuclear energy to directly generate electricity. It is called nuclear batteries. These devices are used to power spacecraft like the Voyager probes that, since they are so far the sun cannot use solar power (they were recently reported to have left the solar system) and cannot be replaced, recharged, or maintained in any way. These batteries will provide power to the spacecraft for 40+ years but the output is low. These nuclear batteries have also been used on earth around the Arctic ocean to power lighthouses, again because they are not readily maintained: Radio Isotope Batteries
Nuclear processes have long been exploited for generating heat and electricity for energy needs. In most of these cases, both the methods of generation and eventual applications are often associated with larger-scale structures (power plants) and distribution (national usage).
However, there are indeed much smaller scale situations involving the production of energy using nuclear processes. One of these examples is the use of radioisotope thermoelectric generators (RTGs).
RTGs are devices that convert the waste heat given off by radioactive decay processes into useable electrical energy and are often installed in space-bound objects that require energy and other remote structures/machines that cannot obtain energy efficiently by any other means. These include satellites, probes, and remote lighthouses.
Ideally, RTGs are established in systems under some of the following circumstances:
Unable to be continually maintained and serviced
Incapable of generating solar energy efficiently
Need to remain operating without human aid for long durations of time
Minimal human interaction
Based on these circumstances, the chief usage of RTGs is in fully automated systems that will not experience human contact for periods of time longer than other sources of energy, such as batteries and fuel cells, can sustain and in environmental conditions that are not conducive to generating energy by natural means (solar, wind, etc.).
We ALL got it wrong...since the very beginning...
Nice Thread,
However, We (Humankind) have being using the wrong methods to "Produce" Electricity...since the very first piece of Charcoal ever burnt...
Electricity is a completely Natural Process inherent to our entire planet...it exist the same exact way Water exist around every island...every continent...and also in the Clouds on the sky...
We have "managed" to "produce" an artificial electricity so far...based on wrong methods, however, following a purpose since the very beginning...to make it/generate it through difficult and clever methods/processes...
Still...Natural Electricity is Ten Thousand times stronger than the "strongest ever conceived" artificial method out there...just watch an Electric Storm...how a natural and powerful Lightning makes the artificial feeders transformers blink...or completely collapse burning down to ashes...creating a vast outage...No "State of the Art" artificial generation of electricity could resist such natural power discharge...however this "accidents" are part of this Electrical Generation BUSINESS...
Nikola Tesla knew We could use this Natural Electricity...not fighting it...but harnessing it...the right way.
We still don't GET IT...
A Natural Positive HV / High Amperage Discharge in the Millionths, through a Lightning ...landing in our "Negative Grounds"...will disrupt every artificial known method in nano seconds...so they "try" better porcelain insulators...
...Thicker Cables...more "insulated" Reinforced Concrete poles...and still Nature blows it away ...
Tom Bearden: ..."None of the shaft power input to a generator adds one watt to the power line. All the hydrocarbons burned, the dams built, the windmills erected, and the nuclear power cells consumed, does not furnish one single watt of the actual electrical power that flows along the external circuit lines, filling all space around them. None of that energy input to the generator shaft is transduced into energy output from the terminals!
Isn't it insane to (1) go to all the trouble of burning hydrocarbon to burn and heat water in a boiler, to make steam and run a steam turbine to crank the shaft of the generator, to form a source dipole which has a broken symmetry in the vacuum, and therefore establishes the system as an open dissipative system freely receiving energy from its external vacuum environment, and then (2) continually destroy that disequilibrium and extraction of vacuum energy, by destroying the dipole faster than any of the free energy from the vacuum is used to power the load?.."
"WHERE YOU TURN SCIENCE INTO DOGMA ...IS WHEN YOU 'LOCK IN' ON A GIVEN MODEL, AND YOU "ASSUME" YOUR MODEL IS PERFECT...AND THEREFORE, ANYTHING THAT DOESN'T AGREE WITH THAT MODEL CAN NOT POSSIBLE EXIST IN NATURE...SEE, THAT'S WHEN SCIENCE BECOMES DOGMA..."
Tom Bearden
UfopoliticsLast edited by Ufopolitics; 08-24-2013, 03:27 AM.Principles for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
Good post, I agree we have to create a natural flow, we have to find the right geometry
When we can make energy flow through a system in a natural pattern we will not have to pulse a system, as Lee says we will lead out energy, then power will be free to all.Half of the Answer is knowing the right Question
Awesome perspectives you guys. Basically it's like the current (water) - no pun intended - you flow with it, not against it. . .and instead redirect it to reproduce itself in degrees never thought possible in the eyes of man.Learn The Top 7 Ways To Reduce Your Electric Bill
The M.E.G. is the initial foray into that I believe
Magnetism flows in a natural pattern.Originally posted by Dave45 View PostGood post, I agree we have to create a natural flow, we have to find the right geometry
As is, a magnet is passed by coils to manually invoke a mirrored field in in the coil, prodding electrons down the wire. Misleading terms like "shielding" keep us from connecting the dots regarding the true use of aligned magnetic domains.
From what I've seen of the M.E.G. it shows.
1. Harvest-able energy comes from change.
2. A magnet releases a deluge of power that doesn't change.
3. if you give multiple paths for the magnet to complete it's circuit you can turn a particular circuit off and on with coils with less energy than you can in return harvest.
4. output is also proportional to how fast you can switch circuits as you get a certain amount of power with each switch why limit it to 60flips and 60flops per second why not crank it as high as your materials will allow for 400khz anyone?
Once we learn to think of magnets as circuits instead of dipoles or something to shield against. We will unlock power greater than nuclear and as portable as our devices.
Still based on Ancient Laws...
Hey Guys...
Have to realize, that so far...we have been ONLY following a "Unique" Ancient Law of generating electrical flow...based on an experiment of a couple of guys that far ago...
So, We have been producing electrical flow based on the same principle...like if that would be all Humankind is ever going to discover and develop...
Doesn't this sound like We have been "locked in time" by the same old model, same old discovery and related laws?...adding the fact...that it is "very convenient" for the so far only main Prime Movers around..."The Farting, Leakers and Stinking" Gas and Diesel Engines"?!
Can we all do better than this?...come on!....pleeeease!
It is "only" just a matter of a "little common sense"...
But nope...We had so many other people along all this One Hundred and Thirty Three Years of "LOCKED UP" Models and Laws...saying it...repeating it...day after day...from Tesla to Bearden...PLUS ALL the rest of a loong line of Bright Scientists and Inventors...also along that "Long and Winding Road"...that...I still, honestly...can not allow to think...there are STILL People...smart ones -as they say-...that believe ..."That's all we've got"...
Seriously speaking
UfopoliticsPrinciples for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
Ufopolitics Generator
Good thread here.Originally posted by Ufopolitics View PostNice Thread,
Can you help us better understand the Ufopolitics Generator side of producing electricity?
I know a lot of work is being done on the prime mover side in your other threads, how about more info on the generator side.
How about a grid chart showing different variables to help us choose the best fit for a Ufopolitics generator?
That way, if some already have a prime mover, they can hook a Ufopolitics type generator to it and start generating electricity as well as feedback for others to learn from.
Torque required
RPM
Type of output (AC/DC, single phase, 3 phase, etc)
Poles
Type of winding
Wire gauge
Thanks Ufopolitics,
IndianaBoys
No doubt about that. It's the "harnessing" that gets tricky. The grid provides the constancy and control needed to make electricity useable. The continuous production of useable energy adjusted to the load at the time is what is difficult to achieve with lightning.Originally posted by Ufopolitics View PostNice Thread,
The universe is constantly bombarding the earth with energy from all directions at all times and it's the geophysical attributes of our planet that prevent is from being like Mercury or Mars.
Still looking...
I agree wholeheartedly with your observations, and if we want to find a way thru this, I think we need to take a serious look at the magamp. Here are a few links for reference:Originally posted by Hrothgar View PostMagnetism flows in a natural pattern.
George Trinkaus' Magamp page:
magamp.html
Nyle Steiner's Magamp page:
Homemade Magnetic Amplifiers.
There are also a couple of old digitized books from the 1950s era about magamps on Google books (posted by GarretM4 on the Eric Dollard Forum thread at http://www.energeticforum.com/eric-d...tml#post203097
Note: I added easier to access URLs for the 2 above books.For some more fun reads on the subject (via HathiTrust) check out:
Self-Saturating Magnetic Amplifiers 1960 by Gordon E. Lynn
Self-saturating Magnetic Amplifiers - Gordon E. Lynn - Google Books
Magnetic Amplifiers, Theory and Application 1958 by Sidney Platt
http://www.scribd.com/doc/124240426/...plication-1958 or Magnetic amplifiers: theory and application - Sidney Platt - Google Books
And again by Garrettm4 (2 posts below the one above):
Respectfully,Lamare found a couple of interesting books on magnetic amplifiers, one of which gave a brief account of the Alexanderson transatlantic telegraph transmitter installation. Which is still intact in Grimenton Sweden. I thought I would put up a few pages from the book to complement the recent T-trex transmission "Law of Electro-Magnetic Induction".
On Magnetic Amplifiers in Aircraft Applications 2007 by Lars Austrin
Bob
Edit: Re-reading Hrothgar's words, I think I jumped away from the point he was making about magnets and into saturable cores as found in the magamp. I'll leave the post as-is, as I do think the magamp's principles need to be considered in the quest for an alternative source of energy involving magnetism, coils and changing flux.
Visualization
"...prodding electrons down the wire." may also be misleading. I think the electrons don't change position but change their spin and/or their orbit gets distorted in response to a magnetic field. For the electrons to move they would have to either leave their orbit which would lead to transmutation of the conductor or their associated nucleus would also have to move which I think does not occur.Originally posted by Hrothgar View PostAs is, a magnet is passed by coils to manually invoke a mirrored field in in the coil, prodding electrons down the wire. Misleading terms like "shielding" keep us from connecting the dots regarding the true use of aligned magnetic domains.
The spins of the electrons at one position in the wire respond to the magnetic field and at the same time in another position on the wire the spins are unaffected and the result is voltage - a difference in potential between two points. The "voltage" is the potential of electrons to return to their previous state of spin. Current being the movement not of the electrons but of the spin positions or orbit distortion moving from one portion of the wire to the another by transmitting the changed spin position from one atom to the next. The medium of spin transmission being being the aether. Visualize two floating disks in a tub of water. Imparting rotation to one disk will eventually cause the other to move as well, the disks being the electrons and the water being the aether.
Just thinking out loud here. But I think we need to accurately visualize what's going on to make progress.
