Lets start the new year with a bang!
  • #31
    Duncan , don't laugh at this but while sitting on the crapper i thought of video tape
    Mike
    • #32
      Originally posted by GSM View Post
      Hi Mario.
      You obviously know what you are writing about - but NOT about what Duncan is writing about !
      What is happening within the TPU segments is quite different to the electromagnetics taught in colleges and universities.
      Duncan is right, he DOES know, and he is attempting to help others understand, the problem being trying to write in a 'conventional' manner which others might follow.
      Mario: Duncan is not wrong, and although interpretations of his words might be, he is trying hard to clarify.
      What must be understood here is that subsection core fields can series-parallel reverse in ways NOT calculatable via conventional scientific experience.
      Cheers ........... Graham.
      Hi Graham,
      all I wanted to do was to test the setup shown in his drawing since I was working on other stuff and had a toroid that had 4 coils on it coils anyway, the only thing I got wrong is that it's not supposed to be a closed core according to Duncan. For this I even apologized!
      Of course I know that a series resonant setup is not per definition a short, but if you hook a cap and a coil to the output of an amp, at resonance what the amp sees is pretty damn close to a short if the Q of the coils is high enough!
      It also depends from what perspective you look at a resonant circuit. Say you have an AC source feeding a tank circuit. The source sees a parallel resonant setup which at resonance has very high impedance, thus the source is consuming very little even though inside the tank circuit high amps are flowing back and forth, depending mostly on voltage, the Q of the coil and its wire resistance and cap specs. If you put a very low impedance/resistance load between the coil and cap it will find itself inside a series resonant network, even though the same network is seen as a parallel setup, from the source point of view.
      This for instance is what people on Luc's thread are working on, and myself. Basically reactive power.
      Duncan, there is absolutely no need to raise your voice and get rude, one never goes far with that. Hope you'll find what you're looking for. I'm out of here.
      Mario
      • #33
        Hi Duncan,
        Thanks for everything you have shared with us. I just want to clarify a few things first though they may seem like silly questions.
        First when you mention an air gap between the electromagnet coils do you mean an actual air gap between the core material or simply the wound coils on the same toroid?
        Also are there 2 toroids stacked together or just 1 toroid?
        This mention of a voice coil is really interesting, I have never heard of it until now as well.
        Would my best bet be in buying a subwoofer and salvaging the voice coil or building the iron toroid?
        I do have a hydrogen torch so it will melt the iron quite nicely!
        I really want to try and build this, It sounds very promising!
        Thanks again!
        • #34
          Electric Power Multiplier: The PWM Inverters in Electrical Cars and Renewable Energies
          About the soft magnetic material for the core, I explored (for my Figuera experiments) on welding rods alloys with very small amount of carbon, say 0.02 %. Used to weld casting iron. Cheap and available at hardware shops. easy to bend, and joining some together,may handle eddies. (just a tiny contribution here)
          Have you thought about any physical setup instead of the H bridge ? (I mean some sort of commutator ?)
          thanks for your share
          regards
          Alvaro
          • #35
            I've recently recieved another order of Steel shot for further core construction experiments.
            To prepare:
            Spray the shot (placed in a large tray) with clear acrylic paint ensuring a thin even coat around EACH piece of shot (eddy control).
            Whilst drying, prepare your (segmented?) core forms per your specs.
            Mix up your resin, poor into the forms and add your coated steel shot to your resin!
            Salt to taste (a dash of Orgone maybe?).
            Circular frames, rods, etc can be crafted in just a few hours using this method.
            Resonance to all !
            • #36
              Mmm this speaker core stuff doesn't seem to be magnetic at all .. back to the drawing board with that bit of brilliance!
              • #37
                regards
                Alvaro
                Just so .. if you you back on that thread you'll see I posted the configeration
                but perhaps not well enough . I couldn't make myself understood . obviously if this is the right theory then it becomes possible to work out how every other machine works ,, apart from red herrings of course its a big if though isn't it ? I'm just getting ragged off waiting for material !
                • #38
                  Mike
                  wow .. thats a thought mike .. I'll have to let that perculate a bit!
                  • #39
                    To prepare:
                    I'm in the UK Beam .... wont even let us toy plastic guns here never mind steel shot and as for a pen knife
                    • #40
                      Hi Duncan.
                      In the past there were home made energy generators due to Wesley Gary and Lester Hendershot.
                      Wesley's final design was independently demonstrated as reported in a newspaper, and he was granted a full Patent for it.
                      Anyone could successfully build one of these devices just by following Wesley's 1878 notes and drawings.
                      Lester's constructions were reported operating in various forms, but when in the Patent office he was said to have been electrocuted by his own equipment, whereafter he is reported to have been paid the sum of $25k in order to do no more with it.
                      In spite of original circuits and drawings, none of his surviving constructions will run (likely missing essential magnets)
                      and therefore any copy constructions will behave exactly the same.
                      Do we know anything about Steven Marks, then or now ?
                      Are original TPU drawings-plans available ?
                      Do any originals or copies of his generator still exist today ?
                      Given the physical alignment criticalities necessary with Wesley's device, and the tuning criticalities of Lester's constructions (esp overheating of the Mk3), then any TPU combining all aspects of these prior generators must be very difficult to complete as a finished product.
                      Cheers .......... Graham.
                      • #41
                        I found these for sale - Fe2O3 ,softmagnetism ferrite core, not sure if it is the correct material though:
                        High Quality Material For Voice Coil For Sale - Buy Material For Gasket,Powerful Material For Voice Coil,Soft Magnetism Material For Voice Coil Product on Alibaba.com
                        • #42
                          Hi Duncan, Is silicon steel for induction motor laminae any good it is quite soft.
                          I've got a four transformer toroid made with the stuff and about 4 inches of
                          the core stack still left, also another entire motor minus squirrel cage and end housings.
                          Anyway I am wondering also about the core gaps, I can do it either way, it's
                          easy enough to cut a core stack into four segments.
                          To make a donut I just use a pair of sharp metal shears and neatly cut the
                          pole projections off around the inside of each plate, (no heat cutting) then
                          bolt them together and smooth the inside of the ring a bit then paint it with
                          red oxide paint.
                          Actually cutting the core in four segments would make the winding so much easier.
                          I read it as four separate core segments.
                          • #43
                            Legg Brothers - Specialist Hot Rollers of Small Steel Sections - Wolverhampton West Midlands
                            • #44
                              Ok Duncan I understand, si-steel might not work so well. I also understand it is not tried.
                              I like to experiment and your arrangement looks like even if it does not work
                              for me I will learn something and have useful things left over to play with.
                              I don't have any soft Iron to bend.
                              I was under the impression that steel was quicker to respond than iron to change magnetically.
                              As stated by Tesla on page 14 of this book - https://ia700302.us.archive.org/16/i...00martiala.pdf
                              When placed symmetrically
                              to the ring, the pull on the opposite sides of the disc being equal,
                              no rotation results. The action is based on the magnetic inertia
                              of iron ; for this reason a disc of hard steel is much more affected
                              than a disc of soft iron, the latter being capable of very
                              rapid variations of magnetism
                              I would say a steel core would work better for a higher frequency square
                              "pulse" transformer than soft Iron, just based on Tesla's words there.
                              I don't have any Iron so I cannot compare performance myself.
                              • #45
                                Can I ask a question here please ? I have build a 1:1 transformer from two ordinary ones (I used it to check JackNoskills user claims on overunity.com).
                                Now the couple of questions are : each of windings when checked by meter has around 9H inductance, but if you join them in one way they cancel each other and give only milliHenries while in other connection (like in Tesla bifilar probably) they got me 42H. Is that because of mutual inductance ?
                                I want to use them in series as a choke for 230V AC or DC current like in attached picture.
                                In picture XMM1 is inductance meter showing 42H and X1 is just a load lamp.
                                Simple question : can I trust meter showing me 42H or just add two 9H inductances in series ? What inductance value will load see ?
                                You woull help me if you know, then we could compare the results with experiment when I will be prepared for it...
