Our planet
Hello,
It is hard to say actually how this Planets work.
The Magnetism / Gravitation seems is far beyond everyones understanding, because it attracts almost any material. The same for the magentism from the Sun, what seems is the next bigger spot, what influnece the surounding.
That common Statement "Gravity is anywhere" is only such a half truth again,
because it probatly only point again to an other Spot like another Sun, where the remaining System cirlces around it.
Our Science is anyway good with such Statements to fix her **** later again.
By understanding this kind of magnetism it would be explain more. Even that the Planets seems still keep the same Distance a long time, or at last for a long time.
At the other hand, it can even only be, that its only a blink from a Second from the universe time and its exploding, where anything turns, just our lifes are way to short, to really realize it.
Thats regarding to the Statement, that the moon moves slowly away from the earth.
But this is again such a Statement from science where noone can proove it right or wrong, because they got no others Datas as from the last 100 years or less. and they cant say it, if the moon did that again and came back or that the moon is younger then the Earth itself.
There is the next Question then, What makes the Moon and the Earth continously turning on a certain Path, but something like some Meteorites dont really care about it.
At last the Earth has a lot Iron in its core and lot other Metal what can create magentical friction and attractionTheorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
I am still puzzled why people still think about Earth as a big magnet, although it looks it is the motivating factor on compass needle's orientation. An electrostatically charged body can attract many more objects (diversity wise): paper, metals, hair, wood, water, you name it... It looks plausible that it exhibits more gravity properties than a magnet.Originally posted by Joit View PostThe Magnetism / Gravitation seems is far beyond everyones understanding, because it attracts almost any material.
As for "why compass is reaching the orientation" as we know it, it is well known the interraction between magnetic fields and electric fields. It is the basis of a working principle of a CRT. It the case of Earth vs. compass, it is a matter of mass (or charge q if one finds that's the case), Earth having one much larger mass than any bar magnet.
At Earth core's temperatures, magnetic properties fo iron are lost. Curie's studies proved it.Originally posted by Joit View PostAt last the Earth has a lot Iron in its core and lot other Metal what can create magentical friction and attraction
Regards.
You are not totally wrong
My observation is that science every scientific paper ends, more or less, with "...more research is needed."Originally posted by lokke View PostTo my surprise , science is not quite sure how the planet works. some believe that there is a nuclear reaction in the planet's core , and some have other explanations .
Yes and no. It is conductive in that it is solid iron surrounded by molten metal that is most iron and nickel. So that part is sort of conductive but as one get nearer the center the heat and pressure increase, both of which are detrimental to conduction.I think the planet's core is a large resistor.
And the soil as well. But don't forget about the van Allen belts which protects the atmosphere and the surface from most of the cosmic rays. Cosmic rays come in a wide variety of species from neutrinos to infra red and radio frequencies. And there is a difference between solar rays and cosmic rays. In fact we are bombarded by rays from all directions all the time, most of them solar but many interstellar and intergalactic also.
This is unlikely in my opinion because the earth's magentic field has all kinds of whirls and twists and anomolies all over the surface. Most drawings are made to show it as two poles only but that is a misrepresentation for the sake of simplicity.The sea is salt which lowers the frequency and creates " kontackt " between the poles by the Earth's core.
Yes and no. The Coriolis effect of the earth rotating on its axis creates whirlpools in the liquid metal outer core and these votices create the earth's magnetic field. But that field interacts with both the charged particles hitting it from space and the magentic field of the sun at the same time.and the core becomes like one big electromagnet and creates the earth 's magnetic field.
You've got a good grasp of the general fucntionality if not the particulars.I actually think that on the whole I am not totally wrong.
To understand energy you have to realise that the earth is not a stand-alone body. It is influenced by its internal structure and forces and all of the environment and forces of the entire universe.
Structure of the Earth - Wikipedia, the free encyclopedia
Earth's magnetic field - Wikipedia, the free encyclopedia
Magnetosphere - Wikipedia, the free encyclopedia
Van Allen radiation belt - Wikipedia, the free encyclopedia
Heliospheric current sheet - Wikipedia, the free encyclopedia
The Sun's Magnetic Field - Windows to the Universe
Magnetic Field Lines Tangle as Sun Rotates - Windows to the Universe
NASA's Cosmicopia -- Sun -- Sun's Magnetic Field
Source of High-Energy Cosmic Rays Nailed at Last | Science/AAAS | News
Pierre Auger Observatory
Mystery of X-ray light from black holes solved -- ScienceDaily
The list is endless but do look at the other links found in those web pages.
The point I'm trying to make in this post is that considering the planet as an isolated object will lead to incorrect conclusions.
I started this thread with the hope that we would all think a little less complicated.
I guess I can blame myself. it is of course not as simple as I described. There are many factors that come into play. but I believe that if we are ever to understand how energy. works then we must look at volts and current in a less complicated way.
we can see it like this. if I want something we can call this Volt. the more I want to do this the higher volts. but nothing happens by itself. I must have power.
if I have a lot of muscle and is terribly strong and powerful. I get nothing done anyway if I do not have the will.
I want to thank you for your attention to this thread.
Roger
continue
If I have a will but no power can I ask for help. but I have to ask in the right way.
I have to ask with the right frequency. I can not say. Help me, you stupid bastard. I should say, would you be so kind to help me.
so the word is the the frequency that carries my will, and thus creates kontackt with the power.
My will can not be seen unless I let my will appear in one way or another
