respect your thoughts AC lets and consider this one first
Well the core for one, the core is a spinning magnet but what qualities could change our parameters?. A weak magnet may induce a small current in the coil however a weak magnet also has one other property. A weak magnet under the influence of a strong applied field may 1) have it's polarity flip momentarily and 2) it may retain a weak field, flip under an external influence then flip back to it's original polarity. At which point we should understand the magnet field could oscillate in itself at a frequency not the same as that of the coil. What this means to you I will leave up to you.
and look at a working example of the flipped or neutralized magnet running a COP> machine in the very simplest way I know is here
https://www.youtube.com/watch?v=tM_H...B9B16FE7BE4377
I think is was Bob Teal who got f'ukc'd up for daring to try and introduce this system
feed um rice!
will any of you?
) so I move on to another build which can charge more battery faster using single battery input to recover all my depleted battery.
