Tesla's Wireless Power Transmission
The coils are matched and tuned. My reference to non-tuned detectors is to point out the fact that energy can be received from the earth itself around the transmitter earth terminal in a similar way to how people use the high voltage end.Originally posted by Ben2503 View PostHi.
I agree with you that Meyl's claim is bogus, in order to see the 'shielding effect' the 'shield' needs to be much larger than the length of the applied wave. The wavelength at 1.8 MHz is 211 meters!
With the two towers so close to each other, i don't think you can eliminate the RF air part. Also, I believe that Tesla's idea was to make the coupling between the two towers resonant as well. So perhaps you have to adjust your frequency slightly?
While it may be true that the coils are quite close (about 2.8 metres apart), there is not enough power available (in the air) at that point to light LEDs in any way, shape or form, the receiver must be connected to earth to receive anything.
Also the "through the air" hypothesis doesn't account for the fact that the amount of received energy can be varied through adjusting the distance between the earth terminals alone, the coils remain precisely the same distance apart in space therefore according to that hypothesis the received energy should be identical in all tests. But the graph shows that it is not the case. If it was through the air then the earth terminal positioning would make no difference.http://www.teslascientific.com/
wow, did you manage to get about 50 meters of wire on the model.Originally posted by dR-Green View PostThe coils are matched and tuned. My reference to non-tuned detectors is to point out the fact that energy can be received from the earth itself around the transmitter earth terminal in a similar way to how people use the high voltage end.
The air part cannot explain the power received. My point is that you cannot ignore that coupling either. It is basically determined by the 'antenna gains'
According to Tesla's theory, this change in power vs distance should not happen. On the other hand, we should keep in mind that at these frequencies, small changes in the configuration (like placing your hand close to the tower top) may have significant impact.
I am not convinced that the coupling between the two towers is resonant in all your test cases.
Perhaps Ernst has some ideas on this?
Best regards,
Ben
It's for the 160 metre band so about 40 metres total.Originally posted by Ben2503 View Postwow, did you manage to get about 50 meters of wire on the model.
Best regards,
Ben
What do you mean by "I am not convinced that the coupling between the two towers is resonant"? Each coil is considered as a "standalone" unit, that is, they are independently tuned to the same frequency, as a radio transmitter goes online at the station's pre-determined frequency and the only consideration for the engineers is the transmitter. The receiver plays no role in the transmitter's tuning or setup. The receiver is independently tuned to the same frequency in order to receive the signal. That's why by placing your hand close to it you detune the coil and the signal goes away. This happens whether it's done at the transmitter or the receiver, likewise tuning the transmitter (or receiver) to a different frequency has the same effect. Therefore if they were not resonant then it wouldn't be working at all.
[edit] As for power over distance, we will discover more on that in the near future. But what can be seen with the basic setup so far is even though the power drops off with distance, there's a lot more available energy at any given point than there "should" be according to conventional calculations of energy at a distance from a radiating source.Last edited by dR-Green; 04-23-2014, 12:44 AM.http://www.teslascientific.com/
Do you really think there should be more power at *any* point? Methinks the distance to power relationship should be sinusoidal IF we are thinking in terms of standing waves. That means that there are points where power is zero.Originally posted by dR-Green View Post[edit] As for power over distance, we will discover more on that in the near future. But what can be seen with the basic setup so far is even though the power drops off with distance, there's a lot more available energy at any given point than there "should" be according to conventional calculations of energy at a distance from a radiating source.
In fact in certain VHF situations, the power should drop off very close to the transmitter if standing waves are formed with the receiver, while there is a gain in amplitude farther out, and then a drop, etc... Sinusoidally.
This, of course, is thinking in terms of transmitting via earth-conduction, or perhaps single-wire power.
Hi Dr Green.Originally posted by dR-Green View PostWhat do you mean by "I am not convinced that the coupling between the two towers is resonant"? Each coil is considered as a "standalone" unit, that is, they are independently tuned to the same frequency, as a radio transmitter goes online at the station's pre-determined frequency and the only consideration for the engineers is the transmitter. The receiver plays no role in the transmitter's tuning or setup. The receiver is independently tuned to the same frequency in order to receive the signal. That's why by placing your hand close to it you detune the coil and the signal goes away. This happens whether it's done at the transmitter or the receiver, likewise tuning the transmitter (or receiver) to a different frequency has the same effect. Therefore if they were not resonant then it wouldn't be working at all.
In one of the articles, Tesla compares the earth to a giant copper sheet or ball. In other instances he compares it to a water filled balloon. That brought me to the idea that the ground coupling is that of a parallel LCR circuit. The R is determined by the ratio length / area of the ground path.
Additionally he stated that:
1. The frequency used should be low 30,000 to 35,000 Hz max
2. the voltage as high as possible.
3. Large self inductance.
4. Low Capacitance.
5. a good ground connection is required.
I noticed in one of the vid's that Meyl adjusted the frequency after changing the distance between the towers and from that I assumed that perhaps the transmission path, acts as a parallel LC circuit with capacitive coupling provided by the antenna's and inductive by the 'ground' wire.
Perhaps you already know this article http http://www.free-energy-info.tuks.nl/...ueWireless.pdf
Best regards,
Ben
