spring loaded pivot for lever
I posted the following comment on Rohndoe's video showing his gimbal. He didn't respond, but I'll post it here.
Just the gimbal is NOT the final story. I said from the beginning the pivot mechanism is spring loaded. Even if it is not, it is similar and is not just a gimbal - here was my comment:
Rohndoe, the rod connected to the gimbal rotates elliptically - you can download my zipped file that shows this on the Skinner machine: http://www.energeticforum.com/257516-post127.html it is in that post. In the very beginning of his video, you can see the top bar oscillating back and forth. But on the end of that bar, the input lever is rotating. But since the oscillating bar changes the axis that the top of the input lever is moving around, it is elliptical.
In your video at 1:04, the input lever stays perpendicular to the pins on the left and right. The pins are at 90 degrees to the input lever and cannot move.
If you look at the original video Gravity Power! (1939) at 0:35 to 0:39, that actually doesn't happen on the Skinner machine. The input lever does not stay 90 degrees to the end plates. The plates actually lag behind the lever. At 0:37 to 0:38 when you see the lever moving back towards the right, that plate catches up and then moves right again slightly lagging behind it. That is why I suggested from the beginning that there is some spring loaded action in there possibly. I hope that helps. It should be more obvious in your slow motion segment of that.
In your slow motion segment - at 0:17 to 0:18, the lever goes to the maximum point towards the left. Right at 0:19 it starts to move towards the right. It isn't until 0:26 that they become 90 degrees to each other again. At 0:32 when it starts to go left, it is very obvious that the end plate on the right does not even move because it hasn't caught up...it is not locked to the movement of the lever. I think the whole gimbal idea makes sense like what you and Eltimple have shown but there is something more to it like some spring in between the rod your lever is inserted to and the end plate, but not solidly locked to it.
EDIT - YOUTUBE ASSUMED THOSE TIME MENTIONS IN THE COMMENTS WERE FOR HIS GIMBAL VIDEO, BUT THEY'RE FOR THIS ONE: https://www.youtube.com/watch?v=g3zs8vcBJyE
If anyone reads what I just posted and looks at the video clips, it is common sense that the lever is not moving in synchronicity or in phase with the side of the gimbal plate because before the lever starts on its way back to the other direction, the gimbal plate LAGS behind the lever meaning it is not locked to it - if you look at the way Rohndoe made his gimbal - the center round section that is locked to each end plate as the primary axis the lever is attached to - there must be some spring between that round piece and the end as a buffer or to get some spring action.
Just read my comment and look at the videos and it is undeniable that it is spring loaded or similar but is NOT simply just a gimbal - why I seem to be the only one that can see this is wackier than all get out and everyone has ignored this through this entire thread so far. The gimbal plates perpendicular to the pivot point LAGS behind the lever on each return trip.
