Davis-Rawls Model Analysis...
Hello Ken,
On that great book you 'gifted' to all of Us, many thanks!...excellent, superb!
I also believed this is all possible treatments and could be the future 'restoring biological machine' for human cures, just like seen on Elysium ...absolutely!
Now and first, related to their Magnetic Model shown below...do you fully agree with it?....
[IMG]
[/IMG]
They wrote (and I highlighted in yellow their main configuration, as you also did and shown in grey)...:
[IMG]
[/IMG]
Now...if We just turn that same magnet, we have:
[IMG]
[/IMG]
I see this 'classification' about North turning 'Left' as South turning 'Right'...as very "RELATIVE" (Sorry I have to use -again- your very good old friend "One Stone" words)...
No, but seriously... just look at turning that same magnet, how the whole thing "coincides" using the same 'Observer' point of view.
Now We have South turning same as North original book drawing...meaning to 'our Left'...as well as North turning now as South, or towards 'Right'...
And...if We go into "Interactions" of same Model...see what happens:
[IMG]
[/IMG]
On the first Attract Mode or Voidance picture, no needed 'twisting of magnets is required...as everything seems ok, meaning the interaction area circled in red shows N & S spinning opposite to each others...so, this way they 'attract' right?...
BUT, when we see same magnets at Counter Voidance (Repulsion) from S-S Polarization...We see that both S-S facing each others are ALSO turning opposite to each others, same as previous voidance of N-S?...Sorry, but with all due respect for this excellent book and authors work...but this explanation about turning references does not make sense at all.
I understand that South is Sourcing while North is draiN...so from the flow point of view it would be fine...
Let's try to explain this 'Relativity" of movement from the observers point of view, when applied to a Motor as an example:
Say We have a Motor that 'Spins Left' or CCW written on its Spec's Label when terminals connected as they say there...As We all understand it 'Applies' as when looking to shaft facing to our eyes from the Driving side of Shaft....However, IF we look at rear end of Motor, facing our eyes...shaft would be spinning CW, or to the Right. Meaning, opposite to 'Main Left' Rotation, however, shaft is one piece...spinning one way only.
So, going back to a 'Magnet's' dielectric plane...it 'sucks inwards' towards a virtual counter-space 'center' while also 'spinning' or 'doing it' with a 'rotation sense'...right?...Therefore if We have Polarizations 'counter-rotating' each others...then to which one the dielectric plane would 'counter' rotate?...
See where I am getting at?...there is an obvious 'error' here...
The way I can only see this whole thing, in order to make sense...is IF both polarizations rotates as the shaft of previous example motor...meaning 'one way'...then dielectric will 'counter rotate' shaft...PLUS, if we do all possible 'Interactions'...then they will also make sense...take a look:
[IMG]
[/IMG]
Now, if We 'Interact' to N-S and S-S as originally...:
[IMG]
[/IMG]
On Voidance (attract) We see both N-S interacting polarizations turning same direction , then thinking as 'Engaging' their Vortexes just like 'Two Screw type Gears' driving towards both counterspace planes, to end up making just one at their intersection.
At S-S Counter-Voidance we see them counter rotating...they will never engage into a gearing screw following a mutual attraction, but keep repelling each others.
What do you think Ken?
Thanks in advance for your answer friend!
Hello Ken,
[IMG]
[/IMG]They wrote (and I highlighted in yellow their main configuration, as you also did and shown in grey)...:
[IMG]
[/IMG]Now...if We just turn that same magnet, we have:
[IMG]
[/IMG]I see this 'classification' about North turning 'Left' as South turning 'Right'...as very "RELATIVE" (Sorry I have to use -again- your very good old friend "One Stone" words)...
[IMG]
[/IMG]On the first Attract Mode or Voidance picture, no needed 'twisting of magnets is required...as everything seems ok, meaning the interaction area circled in red shows N & S spinning opposite to each others...so, this way they 'attract' right?...
[IMG]
[/IMG]Now, if We 'Interact' to N-S and S-S as originally...:
[IMG]
[/IMG]On Voidance (attract) We see both N-S interacting polarizations turning same direction , then thinking as 'Engaging' their Vortexes just like 'Two Screw type Gears' driving towards both counterspace planes, to end up making just one at their intersection.
...so please could you be patient enough with Us?...
