$3.00 magnet-battery copper-coil "train" Build one.
  • #16
    Originally posted by nathan97 View Post
    Anything to do with the fact that copper is a dielectric reflector ?
    Now, you have to ask yourself if the "train" is not technically being PUSHED or PULLED thru the coil,
    ....then how/why/etc. is it "falling" thru the coil.
    • #17
      I tried this right after posting my question yesterday with a coil I had laying around which was enameled. It didn't work at all. I might have had too large or heavy of magnets though. N52's that were 1/2" thick by 3/4" diameter. Two on each end. I'll try again with some smaller ones but I think the enamel is more of a problem than the magnets I used. I tried sloshing it back and forth also to see if there was any less resistance in one direction but none was detected. I'm sure this will work better with bare wire. Too cool not to try
      • #18
        N52's that were 1/2" thick by 3/4" diameter.:
        ouch, waaay too big and heavy.
        • #19
          Nice Train...
          Nice Model T.A.!
          It's just as Wayne described...
          Wire can NOT be enameled...and so magnets MUST have conductive material as outer coating.
          Magnets act also as conductors from the battery energy...transmitted to JUST segments of the whole coil where Train is at...this energized segment creates the thrusting effect...and so on to next segment...
          Just like the EM Projectile Launcher...but "in series".
          I spoke about this on a previous Thread...and about the train as well.
          If We set an outer and bigger ENAMELED Coil, following the same path as the Inner bare wire coil...inner inside outer...and we measure output while "train is traveling"...we will have energy at both ends of outer coil...
          Right T.A.?
          Nice to see you back friend!
          • #20
            Originally posted by wayne.ct View Post
            No, it is not obvious.
            But it is really, really obvious how it works. If you didn't figure out how it works within a few seconds you probably don't even have the most basic education in electricity/magnetism.
            • #21
              few people have rubber or silicone coated neodymiums, but yes.
              most neos are nickle or chrome plated from China.
              the video is not my video, its from a chinese website.
              I however was going to make a likewise video with a twist when i found this video.
              Im out of country right now and will make some stuff when I get home.
              • #22
                Original source:
                For those that care about that sort of thing.
                • #23
                  • #24
                    Faraday Homopolar Motor
                    It's a basic Faraday motor or "homopolar motor".
                    Instead of the wire moving around the magnet, the wire is still and the magnet moves.
                    It should be bare wire so the contact to the magnet can happen. It's using the same principle.
                    If we can see it in enough detail, the magnet/battery assembly should be rotating as it moves even if it is is slight.
                    So the magnets should only have to be on one end of the battery - so the other end of the battery just needs some conductive contact to hit the wire to complete the circuit. If it needs more umph to get it going, then put the magnets on both ends.
                    This is really a very cool little demo and is a great out of the box application of the Faraday homopolar motor concept!
                    • #25
                      How about connecting a Voltmeter to the 2 ends of the Coil to see how much voltage is being generated during operation.
                      • #26
                        The $64,000 question:
                        Does the battery run down?
                        • #27
                          why not use button cells instead of 1.5v battery more speed.
                          • #28
                            Yes. Nobody claimed otherwise.
                            • #29
                              those batteries are pricy
                              • #30
                                does a bear poo in the woods?
