Tesla's Special Tri-Metal Generator
  • #16
    Attempting to characterize the property/s of aluminum versus copper...
    Originally posted by Vinyasi View Post
    I think iron is a good place to start. Also, any electrostatic properties of aluminum? It makes good lightening rods, maybe for some other good reason?
    Since chemical processes are heavily influenced by eletronegativity tending to favor one association among elements and compounds over others in their vicinity (Stanley Meyer's nitrogen favoring its combination with hydrogen over oxygen under positive ionization? - Peter Lindemann), I wonder if a time-honored recipe for cleaning silver might have some insightful bearing on any attempt to characterize the relative properties of copper versus aluminum since copper and silver are in the same column of the periodic chart of the elements along with gold and platinum, etc?
    I remember, now, a procedure for bringing back the shine of old silver dollars: pour boiling hot water over them while they sit in a pan lined with aluminum foil and dissolve salt and baking soda into the water and let it sit. So, I got still more curious and went to see if I'm correct about the details of this recipe, at...
    How To: Polish Silver in a Baking Soda & Salt Bath | 17 Apart: How To: Polish Silver in a Baking Soda & Salt Bath
    Comment about the science behind this recipe...
    Carolyn Valdez October 2, 2013 at 5:01 PM
    "Nice silverware! Are those antiques that you've collected?
    "I love little tricks like these for around the house, especially since I'm a chemist by training and can't help myself. I just looked this up, because I understand that the aluminum (Al) reduces (gives electrons to) the silver, but I was under the impression that silver tarnish was an oxide made by reacting with oxygen (Ag2O), very much like iron oxide in rust. BUT google just told me that it's actually silver sulfide, therefore you're actually forming aluminum sulfide at the end, as well as the reduced silver (Ag metal)! Science is awesome."
    I wonder what the iron is giving up (electrons?) when it is inline with my Earthing connection if it appears to be taking on any negativity (my psychological state) and what is it giving up in return? Especially since this is a subtle energy exchange based on iron's material properties?
    Maybe the iron is giving up electrons whenever it takes on whatever negativity (karma) is surrounding me. Since all pure metals take on a negative charge during their chemical purification from their oxidized state as natural ores, they have an ionic negative charge of their own with which to give up. So, one possible definition to negative karma may be stressful energy in the sense that it is energy ill defined for vague goals which may not even exist per that situation which it is attempting to address? An ill spent, ill fated failure of energetic expense leading to fatigue without success to counter-balance that fatigue? A dead-ended endeavor? Only out of ignorance could such karma be sent from an ignorant source. But its arrival is hardly veiled in ignorance. Hence, the need to find a conveniently located trash bin (in the form of an iron cored bio-Earthing device {bedsheet}) to send it to (by extracting it from myself while I sleep) in the form of a dump designed to attract 'free' (mental) energy - energy not affiliated with (free of, and unattached to) any logistically success-oriented goal/s. So, mental positivity is bound and dedicated to specific goals instead of mere cathartic venting for diverse reasons. Having such a dump could be analogized to a lamp lit nearby to attract all of the flying insects that are buzzing around my head to keep them away from me.
    And for that matter, how would these three elements of copper, aluminum and iron respond to each other in a combined setting? I guess that's what @Sputins is alluding to?
    • #17
      Aluminum as the outermost layer encasing copper windings surrounding an iron core?
      The PMH is already playing into a toroidal, iron core, copper coil winding. Add a bare aluminum foil outermost layer, maybe, to complete each coil form to act as a floating style capacitor plate?
      • #18
        Tesla's Special Tri-Metal Generator (TSG) is an application of the five pranas
        I think I have figured out what's missing in all of our other meters and what to put back in and why.
        The most significant part of the story that has remained an enigma for me is that one horsepower of output is added for every 200 pounds of iron added to Tesla's Special Generator, or TSG, system. Where does this additional iron go in the watt-hour meter if we want to enlarge upon this story's idea?
        Plus, is there anything else missing from watt-hour meters?
        Well, Mr. Lyne (in an email to me) said that there is: a secondary coil in resonance with the operation of TSG. But he suggested putting this secondary around the globe of the watt-hour meter and replacing the glass globe with a metallic one (I don't remember if Mr. Lyne specified which metal). And furthermore, he suggested that the globe's size and shape must function as a resonant cavity for whatever frequency is chosen to run the device. Without attempting to replace the core feature of Mr. Lyne's idea (size and shape), but merely shift focus away from the globe (encasement), I will propose a different idea...
        The braking magnet, so we're told, is intended to slow down the spin of the aluminum disk of a watt-hour meter to prevent it from accelerating to infinity. This tells me that this is where I should be focusing on, not the globe.
        If the braking magnet absorbs energy from the disk and stores it as a magnetic sink, then it will function similar to: Earth ground, or the battery in an EV Gray motor and be unlikely to explode when fully saturated (such being the fate of some of the earlier designs of EV Gray motors which made use of a battery as an electron sink). Thus, the braking magnet must be enlarged upon to soak up any electrostatic charge which builds up on that disk lest the excess goes to waste out into space due to:
        1. The disk reaching electrostatic saturation, and...
        2. The braking magnet reaching electromagnet saturation.
        Once the mass of the braking magnet is enlarged to whatever operational value is needed to give this more than a mere break-even COP of 1, then we can begin to wrap a secondary around it to harvest and put it to use.
        Oh, I almost forgot...
        The braking magnet's permanent magnetized status must be eliminated and turned back into a highly magnetizable, but non-magnetized, material: iron for instance, magnetic alloys, and various other materials which are available.
        Now for the theory...
        I think I'll avoid a discussion of the five pranas - momentarily, but instead focus on another analog: our use of the so-called Tesla coil.
        John Polakowski gave a presentation this past summer on what the true design of a so-called Tesla coil is. But I will restrict myself to what I am more familiar with seeing in our pop culture: the conventional design to serve as a model for the basic concepts described in this post.
        The Tesla coil concept is a highly specialized, but only partially developed general concept of the, watt-hour meter which in turn is still not developed far enough to incorporate all five elements of a TSG. The principle components of the standard Tesla coil are...
        1. The primary.
        2. The secondary.
        3. The output terminal which sits on top and may or may not be constructed of aluminum. Included in this third phase of development are the sparks flying off into the ...
        4. Air.
        5. This stage of TSG development has remained blank for all these years because we didn't know how to develop it any further to harvest anything.
        So, our current Tesla coils are not worthless, they're just a partially baked idea. No wonder we don't have free energy!
        Now let's integrate the Tesla coil's design into that of the watt-hour meter...
        1. The primary of the Tesla coil is the current coil of the watt-hour meter.
        2. The secondary of the Tesla coil is the voltage coil of the meter.
        3. The Tesla coil's output terminal which sits on top is analogous to the spinning aluminum disk of the meter.
        4. The air surrounding the output terminal atop the Tesla coil is the braking magnet of the watt-hour meter. But in a TSG, it is a very large mass of non-magnetized, but highly magnetizable, material (iron, etc) serving as what would have been the braking magnet in a normal watt-hour meter or the iron core of another coil winding. Its analogy, by way of example, is the massive significance of the iron hulls of the Electro-U Boats of Nazi Germany during WWII described on page 285 of Mr. Lyne's "Pentagon Aliens" book.
        5. There's no analogy for this stage of development, so far as I know. A secondary coil wound around step #4. In the case of the Electro-U Boat analogy, this secondary need not be around the hull of the submarine, but merely around a portion of it extending into the center of the craft and protruding into the fourth step of TSG listed above. This is not unlike the E-shaped transformer cores (if we were to imagine using merely the 'E' part and discard the straight bar (in the image linked above) wherein a protrusion of the laminate circular core juts into the center of the watt-hour meters laminate core (upon which are wound the individual current and voltage coils), or away from the spine running down the length of the 'E' core.
        A properly designed TSG shall have...
        1. An air core primary coil, or else an iron core serving as the...
        2. Secondary coil, followed by
        3. Some sort of aluminum integrator: a hollow toroidal shaped output terminal, or a spinning disk, or?, followed by...
        4. A non-magnetic very large mass of highly magnetizable material, possibly iron or?, which has wound around it...
        5. Its own secondary feeding a load and possibly feeding the original primary coil in a closed loop? Wait a minute... You couldn't make this a closed loop perpetual motion machine, could you? But hold on a minute... What's to stop us from repetitively building on top of this design multiple sets of this composite concept like the multi-ply layers of an orgone device? In other words...
        6. Repeat steps #3, #4 and #5; or repeat steps #3, #1 and #2 (in that order) to whatever limit desired? Though maybe a properly tuned five part system is enough?
        The spark gap & capacitor of standard Tesla coils are missing from these comparisons, 'cuz: I don't know where their analogs are located within the watt-hour meter, and a TSG may need them as precursors to its operation.
        The so-called braking magnet of this proposed TSG along with its surrounding secondary coil can be considered analogous to adding another primary/secondary coil with the aluminum (spinning disk, or stationary? toroid) serving as an integrator between the two, in other words, two resonant coil systems. But unlike a system for wireless transmission of power, these two systems are not balanced with each other. The first system serves as the foundation for the second. Thus, the first doesn't even look like the second even though conceptual parallels can be drawn between the two sufficient to call them two resonant coil systems, or better still: four parts to a five part resonant system. But the analogy stops there. For the purposes of this analysis, an iron core coil (#4 & #5 in the list above) is no different (functionally speaking) than an air core primary/secondary pair of coils (#1 & #2 listed above).
        The only reasons why we would take out an iron core and replace it with a heavy guage primary is to raise the frequency of the system, and get more power out of it, since the iron has its limits of response. And the consequence to raising the frequency is shortening the length of the wire used to wind the secondary with. Not only is this a practical method for constructing a Tesla coil, but also has been the only way (up until now) to raise the output (by lack of the Tesla coil's further development).
        In order to raise the energy of the Tesla coil's output by using the opposite approach, namely: lowering the resonant frequency of this five part design, would necessitate winding a humongously long wire around an air core, metallic armature serving as the secondary (serving as steps #4 and #5). This is what Mr. Lyne suggested on page 286 of his book, Pentagon Aliens; a length of wire about 50 miles long to correspond with a wavelength of 925 miles consistent with that of the Earth's 13.5 c.p.s. used by the Navy's ELF communications. Who's going to do that? Maybe the Navy...
        Well, the braking magnet absorbing excess electrostatic energy from the spinning aluminum disk of the watt-hour meter is the clue on how to avoid doing just that!
        Not that we have to start by spinning the toroid atop every standard Tesla coil, but understand and appreciate, instead, the analogy possible to draw between a conventional Tesla coil and an electro-mechanical watt-hour meter.
        I'll finish by drawing the analogy with prana, but I won't dwell over much on it.
        1. Apana = Elimination
        2. Vyana = Circulation
        3. Samaana = Digestion
        4. Prana = Breath
        5. Udaana = Thought
        The five stages of life...
        1. The Absorption of Youth into Values which are Greater than Itself; aka, Using a Role Model/Ideal to Mirror one's Self from...
        2. Yuppy striving to "get ahead": time to Cash In!
        3. Status quo: I/We made it! Whew! Time to enjoy...
        4. Mid-life crisis/transition...
        5. Retirement
        And the five steps of progress...
        1. Stability
        2. Adaptability
        3. Integration
        4. Purification
        5. Growth
        All of these five lists are directly mappable to the prior lists of five principles each and to each other. Consider, also...
        1. Muladhara chakra = Root
        2. Swadhisthana = Hips
        3. Manipura = Solar Plexus
        4. Anahata = Heart
        5. Vishuddha = Throat
        The five ideal conductors of Odic Life Force...
        1. Water
        2. Metal
        3. Silk
        4. Resin
        5. Glass
        And the five elementals of Nature...
        1. Earth = Gnomes
        2. Water = Undines
        3. Fire = Salamanders
        4. Air = Sylphs
        5. Space = Holy Ghost/Spirit
        And the five sheaths surrounding the soul...
        1. Physical Body
        2. Etheric Double of the Physical Body; the Life Force, or Ghost; Orgone
        3. Astral Body
        4. Concrete Mind
        5. Abstract Mind
        And the five paired organs of action and sensation...
        1. Anus = Smell
        2. Gonads = Taste
        3. Legs = Sight
        4. Hands = Touch
        5. Tongue = Hearing
        As you can imagine, these parallelisms go on, and on...
        My first draft of this post was in the form of an MP4 audio blog. It was inspired by reading the last paragraph located on page 31 (and carrying over to page 32) of Joseph Cater's book, "The Amazing Life Force". This excerpt from Mr. Cater's book is attached, below.
        An alternate version of the above is linked here.
        Last edited by Vinyasi; 01-03-2015, 06:16 PM. Reason: forgot something/s to add, plus accuracy of terms used; and changed a file link.
        • #19
          Tiny URL shortcut for this topic is...
          The tiny URL shortcut for this topic is...
          or
          • #20
            Returning the watt-hour meter to its original Tesla Special Generator design...
            1. Demagnetize the braking magnet of the electro-mechanical watt-hour meter and enlarge its mass without limit.
            2. Wind a pickup coil around a portion of the braking magnet and supply this current to a load. This load corresponds to the driving force of the Electro-U Boats of Germany during WWII having a 30K mile range.
            3. Possibly tie the two broken ends together of the braking magnet's broken circularity making it into a PMH? Normally, they're a 'C' shape; turn it into an 'O' shaped ring.
            4. Possibly replace the current and voltage coils of the electro-mechanical watt-hour meter with a standard Tesla coil, including a spark gap and capacitor and high-voltage power supply?
            5. Possibly do something with the spinning aluminum disk? Reshape it into a hollow toroid similar to the shape of a standard output terminal atop a standard Tesla coil? Does a spinning toroidal output terminal require perforations all along its sides (similar to the spinning aluminum disk of a watt-hour meter) to enhance its ability to spin? Or, should it remain stationary?
            6. An 'O' shaped braking magnet could neatly fit through the center hole of a hollowed out toroidal output terminal atop a standard Tesla coil making it look like two interwoven circular rings similar to the five interlocking circular rings of the Olympic Games logo.
            7. Add to those two interlocking rings the spiraled winding of the braking magnet's pickup coil, and now we'll practically have three interlocking rings if we concede to conceptualizing that a spiraled coil winding is semi-equivalent to a third ring? A bit of a fudge, but an interesting variation making the third ring a non-ring: a ring without its two ends tied together. Thus, replicating the original 'C' shape of the original braking magnet. So, we've extended that 'C' shape outwardly away from its origin by one ring's worth of displacement.
            • #21
              Resonance of a standing wave increases its potential energy?
              I forgot to mention what is probably the most important set of possible implied connections that were inspired from reading the quote from the last paragraph of Joseph Cater's book, "The Awesome Life Force" on page 31 and continuing on to page 32, that...
              Mr. Cater mentioned that this is the reason for the speed of light phenomenon that whenever a particle approaches the speed of light, it has maxed out its electromagnetic kinetic energy at the expense of its electrostatic potential.
              A standing, resonant, electromagnetic wave may have a characteristic of non-motion such that its electromagnetic component shrinks yielding an increase in an electrostatic field? In other words, resonance increases the potential energy of an electrical system making a Tesla coil an amplifier of sorts of whatever is possible to generate with any fixed amount of energy?
              I also thought that whenever the current and voltage coils of a watt-hour meter spin its aluminum disk using electromagnetic forces, that an electrostatic force is being depleted by the braking magnet as it soaks up this electrostatic charge by converting it into an electromagnetic one. There must be an abundant supply of potential energy in the form of electrostatic charge for the disk to have an infinite potential to accelerate without a magnet to brake it? And there must then be an abundant supply of electrostatic energy to convert to a more usable form of electromagnetic energy by the absorptive abilities of the braking magnet. And if the braking magnet is enlarged, then it could act like an electromagnetic capacitor?
              But because of the braking magnet's permanent magnetization and its small size, then it can only soak up so much before reaching saturation and discarding the excess. This then forces the disk to discard its excess when it reaches its own saturation, and there's no significant benefit obtained.
              But if the braking magnet were to be demagnetized and enlarged to any amount, and a pickup coil wrapped around it supplying a load, then maybe this would replicate the original intention of but one aspect of Tesla's Tri-Metal Generator.
              It doesn't vindicate all aspects, since it almost doesn't matter how the disk is spun. I just think the focus of power transfer, conversion, and magnification might be between these two elements and their mutual interaction.
              This idea is premised on the supposition that the watt-hour meter may be translating electromagnetic energy into electrostatic energy initially to drive the disk, but then does the reverse when the braking magnet slows down the RPM of the disk: it translates electrostatic energy into electromagnetic.
              And then I thought that if a Tesla coil could be the foundation for setting up a standing wave, or resonance, between all the elements -- the electromagnetic forces driving the disk and the electrostatic forces transferring from disk to braking magnet, then maybe an AC driven watt-hour meter is not the only way to attempt to replicate Tesla's Special Generator since AC may not be easy to resonate into a standing wave? But maybe a pulsed DC from a Tesla coil would be a better way to drive the spin of the aluminum disk of the watt-hour meter if compressed air is not resorted to? In which case, it becomes questionable whether the disk need spin? Because the disk starts to look like the output terminal of a Tesla coil: a hollow, possibly stationary, aluminum toroid?
              And then I thought that the only thing missing from this scenario is a magnetizable pickup material to surround a Tesla coil's output terminal to convert its electrostatic discharges into a process of electromagnetic absorption into its magnetizable material amounting to an equivalent action between disk and braking magnet of a watt-meter. And if the magnetizable pickup were to be enlarged and wound with a coil, then maybe the output current of this coil could supply a load to whatever degree is needed based on: the power of the Tesla coil and the size of this magnetizable sink.
              • #22
                clearing up some discrepancies...
                Referring to the five stages elaborated in post #18...
                WIRELESS TRANSMISSION OF POWER NOT INTENDED TO GO VERY FAR
                I was mistaken. Not all five parts to this system will be in resonance. In fact, it can't be. At least not exactly. At best, maybe in harmonic resonance. Because the iron of the fourth stage will tend to slow down the frequency which it receives generated by the first two stages, #1 and #2, transferred to it by stage #3.
                This means that stage #3, the output terminal of a Tesla coil, has to be split up into two non-identical harmonically resonant shapes: one remains on top of stages #1 and #2 - the Tesla coil transmitter - while the other is strung out on a wire long enough to take it out of the magnetic field of stages #1 and #2 so that the magnetic field of stages #4 and #5 do not interact with #1 and #2. Stage #3 has to be adjacent, or cuddled up, along side both stage #2 and stage #4 to receive from stage #2 and be able to transfer its static field to stage #4. So, a longish wire could be employed to separate the transmitter from its receiver?
                As you can see, this configuration creates problems involving non-resonance and inefficiency, so...
                Why not shield the perimeter of a Tesla coil with a (magnetizable, non-permanent magnet) {iron?} magnetic shielding? This shield would be a stage #4 wireless pickup reception from stage #3. Surround the shield with a copper coil, stage #5, fed to a load; and possibly line the inner surface of this stage #4 shielding with an electrostatic pickup identical to the stage #3 (aluminum?) material sitting on top of the Tesla coil transmitter.
                Conceptualizations of the design described above...
                1. The appearance of this arrangement makes it look as though this idea is a modification of Tesla's wireless transmission of power in which the gap between the broadcast of stage pairs #1/#2 and the reception of stage pairs #4/#5 is the transmission from stage #3 to stage #4.
                2. The image on the left is a Tesla coil with extra output terminals on top to completely fill up the length of the interior of stage #4. When stage #4 is placed around these multi-output terminals and charged up (depicted by the image in the center), it could then be removed (right-most image) because it may now be functioning as a load up to whatever limit the charged condition of stage #4 can accommodate without "stalling" the load. The PMH condition of stage #4 should never stall itself, in theory, despite the possibility of stage #5 stalling if the load exceeds the stored capacity of stage #4.
                3. But if it is expected that the load will frequently - or always - stall (as in the circumstance of driving an electric motor under heavy torque demand, such as: a submarine), then stages #1, #2 & #3 might always have to be charging up stages #4 & #5? This may explain the apparent discrepancy between William Lyne's story that Tesla's Special Generator powering the German Electro-U Boats of WWII were continually run with compressed air driving a reciprocating shaft in an electromagnetic field (which vibrated no more than 1/16"; and the compressed air was stored in liquified air tanks), while the story of my electrician friend was that his co-worker's TSG was no bigger than the dimensions of a spiral bound notebook powering a medium sized motor (which may not have been under any torque-limiting load?). So, I suspect that his friend's TSG was already fully charged to power a load up to a limit without the test condition stalling the idling load. Hence, his friend kept his demonstration tailored to accommodate the predetermined limitation of his particular device.
                4. The difference to Tesla's wireless analogy breaks down, because stage #4 slows down the frequency put out by the broadcast station of stages #1 and #2 which is OK since a Tesla coil is running at an impractical frequency, as it is, for a home appliance to power off of. The massive iron of what would have constituted the braking magnet in a watt-hour meter is "braking" the frequency received, plus soaks up the excess power not immediately used (if it's large enough) not unlike that of a capacitor except that this is an electromagnetic storage.
                5. The power stored in stages #4/#5 could be bled off to supply a load, or else stages #4/#5 could directly serve as a bank of electromagnet stators driving a motor since they'll already be iron-core wound coils. All that is needed is to add some more electromagnets, or permanent magnets, onto a rotor.
                Last edited by Vinyasi; 01-01-2015, 04:27 PM. Reason: correction for stage #3 and its gap with stage #4
                • #23
                  Structure of Stages #4 & #5
                  I've been doing all of my initial proof of concept experimentation using my body as my instrumentation of choice to better discern the essential nature of this topic by sleeping on it. Or more precisely, sleeping on an Earthing device - a bed pad - on top of a silk sheet, which is on top of a disconnected Earthing bedsheetexperiment #2; 7 watts for experiment #3.
                  I used these galvanized floor flanges from the plumbing department of a hardware store, with a 1 & 1/2" ID, to save money instead of using a laminated toroidal core from eBay (although I would have preferred to not use a galvanized piece, but I didn't know then what I know now: they also come as "black malleable iron floor flanges", as well as in larger sizes up to 4 inches inside diameter).
                  But for my very first test, I did not use floor flanges, but used iron nails and green enameled floral wire, #24 gauge, single layer, wound onto the two legs of eight bare iron nails doubled as two nails per side of a square shape. It would have been a true AC transformer in the sense that one leg of the transformer was one coil leading to Earth ground and the other coiled leg went to my Earthing bed pad had not one lead of each coil not been left free to go no where! Later on, I reunited the two coils for improved performance - in a strongly coupled sense, but was also worse because it was only one coil wound in only one direction. Since I was using the grounding port of the electrical wall outlet (not a grounding rod separate from the house wiring), the AC hum bled into this grounded line and the transformer boosted that hum depositing it into my body as a soft vibration which eventually became annoying. So, I substituted with a separate ground leading to a grounding rod outside my bedroom window independent of the house wiring's ground to the AC's neutral.
                  It should be noted that up until the very end of these series of experiments, I did not know that my Earthing bedsheet was not conductive anymore except on the edges of the mattress if I firmly gripped the edge with my hand. Yet, I was still getting some influence or else I wouldn't have noticed the AC hum which also, and not so incidentally, created a condition not unlike that of an overly-caffeinated condition in which I could not fall asleep. In fact, I'd shoot out of bed after a mere five seconds or less of attempting to fall asleep with a tremendous surge of energy and creativity, but along with a mild headache. Once I substituted a brand new Earthing bed pad in place of my connection to a faulty Earthing bedsheet, the benefits which I was experiencing using my Earth-boosting device attached inline with my Earthing bed pad to boost my nightly sleep was nothing short of WOW. Geez! What I'll do for science...
                  My second test used galvanized floor flanges wound with green enameled floral wire, #24 gauge, single layer with a zig-zag winding of one half of the floor flange wound clockwise (CW) and the other half wound counter-clockwise (CCW), 69 turns each half. The adjacent ends of each coil were connected together creating another PMH: a copper wire PMH. At these two points of connection on either side of this toroidal winding, I connected one lead from Earth ground and the other to the Earthing bed pad. This was nice, but I feared that the zig-zag winding on the same iron core might be neutralizing itself in more ways then the mere attempt to cancel out any AC hum from my environment, let alone "balance" the signals interacting between my body and the Earth (not unlike the use of a balanced audio signal to cancel AC hum from electric guitars, and amplifiers experiencing the same bleed-over of AC signal from adjacent live house wiring).
                  So for my third experiment, I split the zig and the zag onto two separate, but identically wound, floor flanges different only in direction of winding: one was CW and the other was CCW. Again, I connected them in a circular manner making the wiring into another PMH of sorts. But this time, I used #16 gauge, insulated, copper wire. Each toroidal winding used 39 turns of a single layer, although it could have accommodated 42 turns. So, I tried to keep my number of turns and length of wire matched for the winding of each of this pair as well as matching the length of all four leads coming off of each winding. Each winding was covered with aluminum foil: one had the foil going into the center hole and covering the hole's inside surface, while the other winding I didn't bother to go inside the hole but merely enclosed the entirety of the winding as one piece. Using terminal connectors, I connected one side of one toroidal winding with one side of the other toroidal winding. But I didn't push these terminal connectors into each other all the way. I left a little space for clipping on alligator clips: one going to the Earth grounding rod outside my bedroom window, and the other leading to the Earthing bed pad. I arranged these two toroids on the floor separated from each other by several inches. A few nights later (last night), I decided to stack one winding on top of the other which had been my initial intention. Then, I had a dream this morning, immediately before waking up... Although I wasn't immediately sure whether or not stacking the toroidal windings was any better than separating them. Yet, the dream may be demonstrating that it was an improvement after all?
                  I was told in the dream that because of what I had done, dogs had obtained the legal right to vote and smoke pot. This was supposed to be something good! I've got all kinds of guesses what that could mean, but still don't know and am not worrying about it.
                  1. Dog could be God spelled, backwards?
                  2. Dog could be any under-dog, gadfly, etc.
                  3. Dog could be the innocent, such as: children, or unsung heroes, etc.
                  4. Obtaining the legal right to vote could be: having a voice, a socially recognized presence, or access to a more well-developed intellect (what a doggy or child might otherwise not possess much of), etc.
                  5. Obtaining the legal right to smoke marijuana could be: full access to pleasurable vices. Since a little bit of God is in the sexual orgasm (to prevent us from becoming extinct from lack of interest in sex), the recognition of God in the sexual act is a precondition to the recognition of what constitutes a human apart from a mere animal. Thus, are dolphins not recognized for what they are, while chimpanzees (proto-human) have a ways to go, yet. Obtaining this 'grace' may be total access to becoming a human. Charlie Lutes would sometimes remind us - those of us who went to listen to his weekly lectures in Los Angeles - that the angels are waiting in line to become human, but are in no great hurry on account of the rank materialism that each would immediately be caught up into should they enter the Earth at that time (over two decades ago).
                  6. What did I do to deserve this dream? I don't know...
                  Continuing with the discussion...
                  I'm pondering whether or not the iron pickup of stage #4 should be two separate windings, not merely one, matched CW vs CCW, and stacked in pairs (could be multiple sets of pairs)? In other words, has my Earthing experiments been merely an examination of stages #4 & #5 (and possibly a little examination of stage #3 as well)? And leaving me little choice but to speculate on how to charge up stage #4 so that stage #5 could run a load? {I'm referring to the use of a Tesla coil in the previous post #22}
                  Sandwiched together, one coil laying on top of the other, is the best configuration.
                  Although two of each, wound clockwise and counter-clockwise, are a minimum configuration, multiple sets of two could be stacked up and charged with a Tesla coil secondary inserted through the center of the stack, and then removed.
                  Spread out apart may look nice and neat, but is not as good as sandwiching the two coils together - one on top of the other.
                  Last edited by Vinyasi; 01-05-2015, 01:49 AM. Reason: added some photographs; made a minor correction
                  • #24
                    Redesigning Stages #3, #4 and #5
                    I did not see this right away, but the efficiency of the graphic above can be improved upon. Here is my redesign concept for improving efficiency of transfer between stages #3 and #4.
                    Take the cylindrical shape of stage #4 and place it inside of stage #3 as an iron PMH and wrap/wind stage #5 copper pickup coil around stage #4. In other words...
                    Using these YouTube instructions as a model from which to begin...
                    world's easiest fastest toroid for tesla coil
                    Following the directions of the above video from YouTube, if we took an aluminum ducting from the hardware store (probably used for dryer venting) and inserted into it a bundle of iron rebar (the rebar having first been wound with heavy copper wire), then both could be shaped into a circular shape with the copper coiled rebar suspended in the center of the aluminum ducting. Then the ducting could be sealed around the circular rebar cored copper coil and the ducting outfitted with its two Marie Calendar pie pans and then the aluminum duct plus pie pans could be hooked up to the single wire coming off the top of the secondary of the Tesla coil. And the two copper wires (coming out of the aluminum ducting from their winding around the circularly bound rebar) can go to a permanent small load, such as a small light bulb, and continue onward in parallel to a switch and two terminals for connecting to any number of intermittent loads. To prevent any hazard of internal arcs frying off the insulation from the copper wire on the inside of the aluminum duct / output terminal, maybe iron mesh in the form of steel wool has to be stuffed into the space surrounding the copper wire wound rebar between it and the interior of the aluminum duct?
                    • #25
                      Redesigning Stages #3, #4 and #5, v.2
                      Take the cylindrical shape of stage #4 and place it inside of stage #3. In other words...
                      ...snip...
                      Another design is to allow the topload on a Tesla coil to spin pivoted onto a ball bearing, such as from a skateboard wheel, rather than using a jeweled bearing, or something similar, from a watt-hour meter. The watt-hour meter uses a white sapphire or diamond on the bottom of a vertical bronze axle (the spinning disk, itself, being made of aluminum).
                      With a spinning topload - or output terminal - of a Tesla coil, the demagnetized braking magnet can definitely be a 'C' shape surrounding the cross-sectional circularity of the toroidally shaped topload.
                      The buildup of charge on the topload should get it to spin just like the spin of an aluminum disk in a watt-hour meter.
                      But I'm still not clear why it spins one way versus the other. All I remember is the definition of the operation of a homopolar generator of Tesla: the disk wants to throw off its buildup of charge by spinning itself. So, its voltage diminishes from its center to its periphery.
                      The explanation in the handbooks on the subject of watt-hour meters say that spin is imparted to the disk as the result of eddy currents. That doesn't help me understand. I'm still spin-clueless.
                      • #26
                        Anything is possible with a clear, clean, crisp electrostatic signal.
                        Tesla's Special AC Electrostatic Generator
                        At its heart, Tesla's Special Generator is an electrostatic AC device. We make the mistake of basing our "modern" generators on Tesla's prior art: an electromagnetic design which creates a fuzzy signal of unsuitable quality for boosting into a more powerful output. So, we have to accept an electromagnetic generator's meager output for whatever it's worth and leave it at that - a very inefficient setup.
                        But with electrostatic generation of power, it's as if we dress a beast with two layers of electromagnetic clothing after first creating this perfect animal out of electrostatic AC signals. The first layer of clothing is a magnetic conversion of the beast's naked body, followed by a second layer of clothing composed of an electric current emanating from the prior layer of magnetic clothing. This final layer of clothing supplies the load/s.
                        The fundamental flaw in our investigation of whatever makes anything so very, very powerfully special is not some secret source of energy, but an extremely clear, clean, crisp audio-like signal - in this case, an AC signal coming from Tesla's Special AC Generator. Once a crisp signal of high fidelity is first created - no matter how weak, it will produce another crisp signal upon its amplification. In this case, amplification is achieved using the analog method of incorporating non-magnetic, but highly magnetizable iron as the pickup material of choice for imparting a magnetic field to a crisp electrostatic AC signal. The signal itself is created by an aluminum something or other alternating its movement/s to create this AC signal. The copper coiled wiring surrounding the iron pickup then carries a current away to supply a load.
                        If we wanted to create a powerful AC generator and all we managed to do was create a fuzzy signal with lots of distortion, then when that signal got boosted, it would be even more fuzzy than before. So much so, that it would be a mess and useless to even consider utilizing much less expect it to be a powerful signal. It doesn't matter how faint the initial signal is when it get's created; it's the clarity of the signal that counts. Power is easy enough to add; anybody can do that. But cleaning up a fuzzy signal once it's been made fuzzy to begin with isn't easy and doesn't get any easier once it's been amplified. So why go to all that wasteful trouble? Why not do it right from the start?
                        I think that Tesla's Special Generator was an outgrowth of Tesla's investigation into developing further his synchronous motor and generator designs. Because I think there are two types of crisp signals which can be generated by his Special Generator and they're both an AC signal generated by a synchronous method.
                        One type of signal is a spike excellent for radio broadcast communications.
                        The other type of signal is a sinusoidal wave form which was probably used for powering the electric motor-driven propulsion and various other loads on board Germany's WWII Electro-U Boats. This is the signal of choice for all of our power generation, but we don't use this method of producing power in today's society - or do we? At least to some extent, we know we do. But whether or not our synchronous generators are special generators - well, only imagination or the whistleblowing of an insider could ever clear up this mystery.
                        The spiked signal is probably created using William Lyne's supposition in the back of his, "Pentagon Aliens", book: a reciprocating piston moving no more than a sixteenth of an inch. But I bet that piston rotated as well as reciprocated. And I'll bet it alternated its direction of rotation for every half of its production of an AC cycle. It probably had squirrel cage style grooves cut into its sides to act as baffles and there may have even been matching grooves on the interior surface of the tube in which the piston reciprocated. These spiraling grooves would make the piston rotate as it moved in either one direction or its opposite up and down the length of its 1/16th inch movements.
                        Any movement of a piece of metal, if performed fast enough, will generate an appreciable electrostatic charge upon that metal. This is known as the Searle effect and is briefly described in Joseph Cater's book, "The Awesome Life Force".
                        So, distance of reciprocation is not the issue here just as William Lyne suggests; but speed does matter. So in all likelihood, the frequency chosen to operate Tesla's Special Generator is probably a very high one.
                        In any event, the signal generated by an electrostatically reciprocating charge will be a very clean, crisp signal of an AC characteristic. And because of the sudden and drastic reversals occurring using this Special Generator's cylindrically shaped piston, the signal will be suitably a spike - and not a sinusoidal wave - good for radio communication (possibly employing Tesla's Wireless technology).
                        This is where I digress from presumed notions of how to generate an AC reversal of electrical sign with a huge sharp increase, or decrease, in between each half phase of an AC cycle. Since this is an analog method employing no digital methods we have come to depend on, a novel method had to be used to effectively and simply do a hundred years ago what we'd probably use solid state integrated circuits to perform today.
                        But this merely takes care of the need for communication between land and sea.
                        I believe that power generation was created on board these Electro-U Boats using a toroidal shaped non-reciprocating rotor in a toroidal shaped shaft to generate a sinusoidal AC electrostatic signal. And these toroidal pistons were probably positioned surrounding each cylindrical piston with each piston at right angles to each toroidal piston paired with it. In other words, the axis of rotation for each toroidal rotor was congruent with the axis of reciprocation for each cylindrical piston. The centering of each cylindrical piston along the axis of rotation for each toroidal rotor would greatly enhance the sharp spikes generated by each cylindrical piston. It would also cause the cylindrical piston to act as a master and each toroidal rotor paired with each cylindrical piston to act as its slave. So, the cylindrical piston set a very sharp beat (just like a metronome), while the toroidal rotor further magnified this electrostatic field occurring all along its axial center wherein is conveniently positioned each cylindrical piston to take advantage of this electrostatic amplification. The whole process, as you can imagine, is mutual synergistic encouragement.
                        I also presume there are eight total piston/rotors in all...
                        1. Four toroidal rotors.
                        2. Four cylindrical pistons.
                        3. And four phases of compressed air moving each of these eight signal generators.
                        4. This requires four signal generators of each of these two shapes to sustain the production of an unbroken AC signal of each of these two types: one spiked and one sinusoidal.
                        The rough first draft of this post, in the form of an audio recording, is located here.
                        Postscript--
                        Even a UFO technology, as William Lyne describes it in any one of his three books -- "Occult Ether Physics" being one of them, is made more apparent with a clear and concise electrostatic premise. Once boosted with magnetics and electrics, levitation is made more doable.
                        So, it would appear that electrostatics is efficient, not because it is the be-all of technology, but because it's a firm foundation upon which to build up a magneto-electric super-structure in that order.
                        HINT: We've been programmed to think backwards on this subject by using the term: EM for electromagnetic as if electric fields were more crucial than magnetic. Well, the electric is more important than the magnetic but only as a consumer-oriented enhancement of the magnetic utilization of electrostatic forces. This is only possible by ignoring the electrostatic a priori to the magnetic/electric (magneto-electric) as well as ignoring the magnetic a priori to the electric. Hmmmmm. Is this why Eric Dollard calls electrostatic the magneto-dielectric? Hmmmm. Sounds like longitudinal is not a complimentary opposite to transverse, but is a balanced composite of transverse since the transverse has two aspects: the magnetic and the electric. So, magneto-dielectric implies a two-ness within a oneness: a magnetic/electric within an electrostatic.
                        Last edited by Vinyasi; 01-05-2015, 07:01 AM. Reason: additional opening paragraphs...
                        • #27
                          Could a Crystal Oscillator Replace the Reciprocating Piston?
                          Could a crystal oscillator replace the pneumatically driven, reciprocating piston of Tesla's original design (circa, 1895) and still produce a clean, crisp electrostatic signal for magnification and transformation into an electromagnetic output supplying a load?
                          To illustrate, I'll make an analogy between Tesla's Special Generator and an Earthing amplification device which uses an iron cored, toroidal, copper wound coil with a piezoelectric crystal at the center of the toroidal coil and the entirety wrapped with aluminum foil in the photo below...
                          Following the lead of posts #24 and #26 and using an excerpt from the following text's page 3-19 (PDF, pg. 69) ...
                          A TUTORIAL ON QUARTZ CRYSTAL RESONATORS AND OSCILLATORS, BY JOHN R. VIG
                          Notice how the right-hand "Equivalent Circuit" looks like the receiver on a Tesla coil minus the primary (plus driving circuit) in which the red dot is the addition of a piezoelectric oscillator representing the streamers coming off of a Tesla coil's topload, 'C' is the aluminum topload, 'L' is the secondary, and 'R' is the air core of the secondary plus the distance between the topload and the primary?
                          I had previously supposed that glass was the unsung hero in this circuit. And not knowing what to do with it or with the aluminum ingredient of Tesla's Special Generator, I inserted a capacitor into this circuit made of both ...
                          ... but then opted to exclude it as being superfluous (right intentions; poor execution). But I hadn't considered the use of a vibrating crystal as a substitute for Tesla's reciprocating piston. So, I guess my hunch of glass was a lukewarm hunch after all since glass is somewhat of an amorphous melt of quartz.
                          Plus, I had no idea I was inadvertently using the symbol for a crystal oscillator for what I thought was a more detailed drawing of a glass plate capacitor... !
                          Audio / Video blogs ...
                          PiezoElectric Oscillators.
                          Placing an Amethyst Arrowhead in the Center of a Transformer's Aluminum Foil Wrapping as an Earthing Appliance's Very Vague Example of a Piezoelectrically Driven Special Generator of Nikola Tesla.
                          Last edited by Vinyasi; 01-08-2015, 07:03 PM. Reason: additional audio/visuals plus remove some text at the end...
                          • #28
                            Remarkably similar...
                            Remarkably similar to Mark McKay's diagram of his guess-estimate schematic of an EV Gray Motor...
                            • #29
                              Maybe the Germans were using outdated Tesla technology during WWII?
                              Maybe the only reason the Germans had to rely on a reciprocating piston to power their implementation of Tesla's Special Generator - rather than anything better - was on account of their having stolen, in 1899, Tesla's patent on the liquefaction of air (patented by a Mr. Linde in Germany immediately after Tesla's lab caught fire)? Thus by theft, they had ostracized themselves from any further contact with Tesla on the development of his Special Generator. Tesla may not have been using this older version of a reciprocating piston anymore by the time the Germans implemented it during WWII? But the Germans made up for their lack of contact with Tesla by thieving yet again from the man who had worked with Tesla to develop this generator, a Mr. Dort (according to Mr. Lyne in his "Pentagon Aliens" book).
                              I'm hard put to think that Tesla would have been restricted to pneumatically driven reciprocating pistons by the start of WWII as the only way to drive his Special Generator. How could an innovator in his field ignore the development of piezo-oscillators as indicated by this excerpted page 3-32 (PDF pg. 82) from out of ...
                              • #30
                                Version two: a homopolar tri-metal generator...
                                Ok, so reciprocating pistons might be one version. But what about the story of my electrician's coworker? His version of a tri-metal generator was the size and dimension of a spiral bound notebook.
                                One thing about the study of the watt-hour meter that I have not described is the vague similarity between the jeweled bearing (of white sapphire or diamond) on the bottom of the bronze vertical axle (to which the spinning aluminum disk of the watt-hour meter is attached) and a piezoelectric oscillator. The jeweled bearing may be thought of as a crystal oscillator in as much as the bearing will vibrate as the disk of the watt-hour meter spins. Or, it may not vibrate until "center of load" is reached (in which the load equals supply, as described by Mr. Dort via William Lyne).
                                So, I'll assume that the jeweled bearing is serving as a memory component, not unlike an EPROM retaining a state of memory whenever a computer is switched off.
                                So, let's see...
                                1. Two aluminum disks are set to counter-rotate in close proximity to one another, suspended on two congruent axles separated by a jeweled bearing between them. These disks represent stage #3 of post #18.
                                2. On either side of this pair of disks are a sandwich of flat circular permanent magnets of weak strength (ceramic?) with their north poles facing inwardly towards this pair of aluminum disks. These magnets represent stages #1 and #2 of post #18.
                                3. Completely surrounding these two aluminum disks is an iron core, toroidal winding of copper wire intended to pickup whatever charge is being thrown off by this homopolar generator. This toroidal winding replaces the braking magnet of the watt-hour meter and represents stages #4 and #5 of post #18.
                                4. There's probably a need for one or two diodes embedded in the copper wire leading off of the toroidal winding to maintain a unidirectional flow which implies that this is a DC device.
