Hey Gerard
Good video talk. Looking forward to your next video when
you get more time. Don't let the trolls drive you over the edge
to where you keep wasting time addressing them.
Did the cap on the HV system improve OU? I assume so.
We don't have any 25kva units or 50 kva but we have
some 5kva and some 10kva cans. Our McCulloch is a 3300 watt.
We did not use a cap yet we can not get OU from our 10kva.
Can you get OU from a small HV transformer? I assume you
have smaller ones?
Okay that is where me and Hitby are, big can's plenty of
money tied up in transformers for the pole and no OU.
I think we have a cap but have not tried that yet.
Thank you for your efforts. It is good to see somebody
who is not wandering around in the world, shell shocked
worried around being filmed or who is going to get them.
You are the man for this job.
The amplifier has 2 channels for stereo so if your 2 phase
motor gets channel one directly and channel 2 is connected
to the second phase of the motor through a cap to delay
the RF, the motor might run. The motor should run if it is
a 2 phase motor being fed 2 signals.
You just have to play with the cap values to get the delay
timing for THAT frequency.
Also add a ground fault contactor for your HV systems, so if a HV
short to ground occurs the system will have it's own safety
shut down mechanism. This way if you start the HV can's with
an improper short the systems shuts off as soon as it is started.
Maybe this one is to small, but if all you
are sending into the prime mover transformer from the McCulloch
is 1200 watts then this basic unit from Lowes or Home depot
will automatically shut off the LV side and thus the HV side.
Hook this one to the GENSET. If the HV leaks anywhere that
it should not, the switch inside will stop the input power.
Think of it as your guardian Angel
You will note the GREEN wire that is common ground for can 1 and
can 2 and GENSET. Any trickle of 14,000 volts, throws the breaker.
Hot tubs use extra safety switches also because your are sitting
in water and some of those elements run on 240vac.
Gerard Morin RF Update and discussion with tests - Part 2
Gerard Morin
Gerard Morin
6,161
Published on Aug 8, 2015
We are receiving confirmation of this new understanding of what energy is.. from outside sources, and experiences emailed to us everyday. As soon as I mentioned RF, the emails started to come in with thanks for speaking the truth, and encouragement that we are going in the right direction.
We have shown Over Unity before and proven it. We have done it again, but this time not every experiment was captured with the camera. I was leaving the province when I finally got ready to capture the footage.. and the generator as I explained will need replaced. It will have to wait until I return. But I will post the video showing the lighting up of 6000 watt worth of bulbs in an upcoming video. I made these videos to show a few tests with frequency and sound, to get peoples understanding of where we are going with this.. to best answer the enormous amount of emails we receive daily.
These experiments were put together last minute... It's a shame about the Generator, but that is an easy fix when I return. We had our results confirmed by eye witness industry workers, with Jaws on the floor. We are releasing these 2 part videos to keep the subscribers in the loop, and progress is still nearing completion with the self loop generator. Which is the ultimate goal.. to free people.
have smaller ones?
Gerard Morin
Gerard Morin
6,161
