New permanent magnet motor video
  • #46
    Motor Gen
    Extra fun with free energy motor.
    • #47
      Amigo's search for Magnet Motor
      Free energy all around
      Over 3000 watts 24/7
      https://www.youtube.com/watch?v=C0IbppxPdHc
      • #48
        Amigo your motor is here
        Magnet motor non linear magnetic forces. Pole reversal at TDC. Key phrases take the cake. Free energy comin up.
        https://www.youtube.com/watch?v=c2qjF8x-HA8
        • #49
          Not sure I believe that specific rendition, only because I spent days trying to do the same thing, but I will say, I know a PhD that personally saw the Yildiz magnet motor run and he is convinced it's possible. He's still working out the mathematics to prove it.
          Ken understands this stuff probably better than anyone. I'm guessing it won't be long until he slaps something together to prove one of his theories and bingo, you'll have a video. It's only a matter of time. Dielectric inertia baby. You get that whipped and you'll be all set.
          • #50
            North South switching
            Hey Dog
            Good to know the path is well beaten. Thanks-A-Million Maybe it will be worth a shot.
            Now here is a mechanically switched magnet pole. John Bedini says we can do the same thing with a stack of various magnets without them rotating.
            Two words, Howard Johnson. Non linear magnets that can reverse poles at the trigger point. That is the way John Bedini's BIG MACHINE works.
            I am sure you know what I am going to say but for the sake of others, I will repeat it again. The moving magnet is pulled in to the stationary magnet and when it reached the fully locked position the pole reverses pushing the rotating magnet away. BINGO!!! Free energy!!
            John Bedini showed his 16 pole (Looks like a red ribbon) Ferris Wheel in PART 22. This machine puts out gigantic amounts of power due the the magnet stacks made to reserve polarity.
            A solar panel is quicker but only works when the sun is out
            Remember Howy stacked magnets using neo, ceramic, rubber, steel and aluminum shielding, triangular cuts. This video shows the mechanical version.
            https://www.youtube.com/watch?v=vBRDvwrFwVo
            • #51
              Unidirectional Magnet
              This one works but does not push, it only pulls. Half as good but it works.
              Self Runner
              https://www.youtube.com/watch?v=QLufUUpqNgU
              • #52
                Nice video. I have, over the years built many magnetic motor configurations. Some were very close to being self running. The greatest obstacle to overcome in a self running magnetic motor is size. In simple terms, you need a wheel large enough to have sufficient distance between each magnet or magnetic section. It needs to assume a neutral position after it has engaged the stator section before engaging another magnet on the rotor. Here a some examples of working magnetic motors. Some more are the Bowman motor, Hampster Cage motor. Good Luck. stealth
                • #53
                  Magnet Motor Man
                  Hi Stealth
                  Talk to me about Bowman, Hampster cage? Magnet motors? You have these?
                  I understand what you said about spaces. I never built one.
                  What did you think about the self runner using a scooter motor to generate?
                  The one I am thinking about uses simple ring magnets spaced out nicely and a single ring magnet over head rotates?
                  I have scene a half dozen of these fully operational all from people who do not know one another.
                  The mechanical pole switching can be replaced with stationary pole flipping using Howard Johnson's magnetic gate shaping experiments.
                  Mikey
                  • #54
                    Non Rotating Motor
                    Here is a magnetic Vortex motor conversion experiment. The picture shows us what John Bedini showed us years and years ago how magnets offer free energy. The Video is the same thing? I think? Amigo your motor is in
                    https://www.youtube.com/watch?v=2qJP4rGfv7o
                    • #55
                      Howard Johnson Gates
                      Ladies and gentlemen boys and girls, I give you a serious replicator of Howard Johnson's work. All of Howy's hidden magnets. Got to protect the patent, you know.
                      Free energy is all around. This is a great adventure. John Bedini did it, so can we.
                      https://www.youtube.com/watch?v=zavp87bKgnQ
                      • #56
                        The ring magnet(s) is a gate magnet. It works exactly like a row of magnets in a linear configuration in that it pulls in one directions and pushes in the opposite. Once you can overcome the initial repulsion of the like poles, then it will repel through with great force and speed. If you are going to use that configuration, you will have to split the case and make a section for a wheel to travel through. This configuration has a strong magnetic pull and repulsion because of the combined strength of the magnets. The Bowman motor is three wheels, 1 is large and the other 2 are 1/2 size and they are all geared together. As the large on turns, the two smaller one rotate in the opposite direction. All north faces on the large one and like on one small one, and opposite on the other. This sets up a push-pull relationship with the large wheel. An offset magnet then keeps the wheels unbalanced to keep it in motion. More later. Good Luck. stealth
                        • #57
                          Motor Talk
                          Sounds good. I got alot of catching up to do I see.
                          For all the Amigo's here is a V-Gate with mechanical reset.
                          Many possibilities exist. This is a test for a possible functioning OVER UNITY DEVICE.
                          Move over world. I want thank everyone for sharing in the other thread. Sharing makes you a winner.
                          https://www.youtube.com/watch?v=gtm4BwfIvUs
                          https://www.youtube.com/watch?v=JL6iAf0WEmA
                          • #58
                            V-Gate Motor
                            This V-Gate has a double acting mechanical pole reversing switching.
                            Still incomplete. I find very few V-Gate motors that are complete.
                            This one looks better than all I have found so far. This one needs a timing belt.
                            https://www.youtube.com/watch?v=A7Zepnqrux4
                            • #59
                              Howard J. Talk
                              In these videos we find some good points to retain. From close observation of the picture we can see that many combinations are possible. Many designs work just as good as the next. Not all.
                              HOWARD JOHNSON Linear Magnetic Motor
                              https://www.youtube.com/watch?v=618k46W3kNY
                              https://www.youtube.com/watch?v=-u3fOwkiM7U
                              Have fun anyone can do it.
                              • #60
                                MyLow Magnet Motor
                                Mylow experimenting and making progress.
                                https://www.youtube.com/watch?v=NSyMPrVUDm4
                                https://www.youtube.com/watch?v=Z9bYfc3xLq8
