I've built a basic Tate power module and am drawing small amounts of voltage, depending on the antenna and grounds used. Right now, I've got a sheet of aluminum foil covered in plastic lamination on both sides as an antenna. Ground connection runs outside to steel rod in earth outside the house.
I'm going to try different configurations for scaling up the voltage using germanium diodes and capacitors, perhaps similar to a Cockroft-Walton voltage multiplier. I realize there's probably no current in this, and pulling less than 100 millivolts (which can be tweaked and improved).
If anyone has any thoughts, feel free to chime in. I'll try a few things and report back.
Bob
Bob
from an acorn giant oaks grow perhaps from a crystal set too
this is where my interest in electrical phenomenon began.It was 30+ years later when I started to experiment again and built the Tate module. It would take a day or two to build up 2 or 3 volts in a 63uf capacitor but during a thunder storm it would rise to 50+ volts in minutes.
