Originally posted by gotoluc
Yes, due to the limit of the 20 amps circuit breaker (wall plug circuit) in my current setup, the output is also limited to 20 amps. Working on testing it on a 50 amp circuit.
The device uses the input 20 amps and outputs loads up to 20 amps, all the while only 0.02 amps (4 watts) input is actually being used to extract the +2000 watts output. Pretty amazing!
Attached 6 photos showing earlier device performance, before adding more existing ground connections to lowering the ground resistance, which is a key feature of this device.
At 1400 watts output, and 4 watts input
- the input voltage is 118.6 vac
- the output voltage is 114.6 vac
- output amps 12.29A
- input amps 12.41A
- Input ground amps 12.23A
Why they would ignore this warning is beyond me.
