Earth Grounding Energy Extraction
  • #16
    It's simple to see solutions in a complicated form, it's far more complicated to see the same thing in its simplest form. Follow nature itself.... so simple in its elegant ability to maintain balance - alter that balance in a natural way and it allows us the use of it.
    Now this is what we need. I never saw this diagram. This has me thinking
    about the potential difference of the to waves.
    • #17
      I will never give up finding the extra, I follow my own music gentlemen.
      Let's take a look at the grid.
      How To Do Grounding System Testing
      • #18
        That sounds better than every thing around I heard. Where does this all come from? Is there a website?
        Hi Mike
        The link's in the little square with the arrow inside at the top of the post. It's from a thread on this site. Here it is:
        Have a good day.
        Bob
        • #19
          ground energy and how radiant energy behaves with high resistances
          Hello Again Mikey,
          Again its a pleasure to speak on the subject of your posts here at EF. Since 2011 I've been experimenting with ground currents, voltage and other phenomenon, however until I found so many uses to the avramenko plug, it's addition to energy from the ground gives all of my devices exactly what they needed.
          I certainly wished to open source Pelex, but now since the latest discovery, the video I posted showing my OU charge results has eliminated the need to speak of pelex at all.
          please watch my latest videos.. third from newest labeled Dezeinstein tech shows the discovery. This allows a charge in the output with any sized load and doesn't reflect back on its source no matter the load size.
          this is free for all to experiment with, i decided to donate this to my friends at Energeticforum and I hope Aaron gets a chance to show this to my unmet friend, Mr. Dollard since he is the foremost wizard in the field... probably the smartest ever to set foot in this arena. I wouldn't mind meeting them both or be interviewed by aanybody in the industry either because it is time to get to tesla tech conferences for me to explain how Don's missing components have finally been discovered!
          I'd like Eric and Aaron to use the circuit as proof to Tesla's phase conjugate mirror theory and maybe take a moment to explain in detail what exactly is happening.
          I of course would love to get credit for the discovery of this since I thought of trying it and found that there's a new achievement that answers an absolute doubt free method of elimination of the lenz effect between the input and output. I found this happened after trying to add ground directly to the input with results on the positive which increased the output and input amperage, but, this wasn't the effect i was looking for.
          i touched the 820 ohm resistor on the low side and the same effect happened. i then added a resistor to the ground and touched it to the output and a small increase happened in the output as a pulse. i added the avramenko plug to allow the radiant energy's oscillating output to go to ground via the resistor and receive the inverse wave of amplified energy from ground to charge the cap in the opposite diode from the current pulse while not increasing the circuit's input power. infact, in most instances it relieves the load by .2 to .4 amps.
          the next videos display my doubling of the output with an additional 60F of caps in parallel and this reduces the input more giving the same output effect. I added the comparison of an ac 2 amp battery charger in the videos to the folks who questioned me about this. the amplified radiant enrgy converts back within the caps from the ambient and totally leaves me baffled, but, i think this, and another avramenko plug added to an inductive aerial may be the missing circuitry in smith's devices, and may even be the true answer to Dr. Moray's device. Once i recover from surgery i will finish my smith build to prove it.. i also think i deciphered the rest of smith's unknown circuitry and his unorthodox use of components, which I'd love to publicly expose in a tesla symposium.
          If we look at the circuits, we'd think he was mad to add the hv radiant enrgy to the low voltage caps, invrter and other components. I've been trying to tell folks for years that high resistances are needed for radiant energy flow nd that radiant energy is a smart energy thats knows what to heat up and burn, as well, what it shouldn't, almost as if it were intelligently controlled. I have literally found 3 or 4 instances of unique energies and they all have overunity amplification using separate components, they have different colored arcs and they have different qualities that all come from different sources.
          they all derive from either magnetic waves or gravitational pulses that has a purposely broken symmetry, with the likes of mumetal, or other similarly structured metals. They all will share one thing in common. they have unique mathematics which are that they function in their own special way. some allow induced charge from energized inductors via flux, some do so by capacitance via the ambient, some only via an arc. There are so many different species that they are mistaken by their similar traits using high frequncies to manifest them in different ways.
          the other uniquity is that they all differ from conventional electricity and it's physical qualities.
          I hope you follow this find and share it for others to see. I'd love this community to be able to prove this to science and the only way possible is to have hundreds of thousands of us to build the simple devices, make cap dump circuitry and reveal what is finally possible by just powering homes, campers and even tool shed/barns, etc.
          I'd like this technology to remain only in residentiaal settings to help people. the businesses that scrape hard earned cash from us could forever pay for all im concerned. we deserve the right for this product's use. Tesla intended his findings to go public and this is a modern form of his discovery, rediscovered by myself days ago!
          Cheers and thanks for reading my extensive mail and comments, your support has been astounding!
          thank you!
          • #20
            Hey Marc
            Thanks for the beginners lesson. I think you let out a lot and I don't
            expect you to stop and explain everything with your current schedule.
            I realize that not so i am not going to be hard on you for not dropping
            everything to answer all questions.
            1) The oscillator must be a certain freq which needs to be something
            people explore for their area.
            2) I have a huge copper truck radiator?
            3) Judging from your experiment do you think the 8 watts going into
            the cap bank thru the oscillator is charging them at a much slower rate
            that the 200 watt charger? Or do you think the 8 watts thru the radiant
            charger is charging the 2 cap banks just as fast as one? How do you know?
            4) So you take off the ground and the caps don't charge?
            • #21
              anything new with earth ground extraction ?
              A link to Tesla document where he does telegraphy twenty miles
              using earth:
              "The Tesla Collection" - "Wireless Telegraphy". SCIENTIFIC AMERICAN, June 19, 1897
              • #22
                I have a layout
                I have a layout from zona ?? Well she left a drawing she call the easiest free energy device
                It was a hivoltage coil and cap like a Tesla coil with a spark gap and a earth ground the energy was positive sparking .going to another coil a short distance away with a coil and I think a another cap with earth ground ..I assumed the two systems were tuned to resonance ..I'll try to find it and post it if I can figure that out ..Jim
                • #23
                  similar
                  It's similar to the low watt Tesla set up but with spark gap and no particular special signal generator .
                  • #24
                    Pic
                    Here's a pic.I think?
                    • #25
                      plasma globe brings electricity out ?
                      or does a plasma globe attract ions ?
                      • #26
                        Video demonstration shows how to make an enclosure with zinc sheeting, there are 2 main aspects to that box one safety.
                        Next shows measurement with an inexpensive Gauss meter (ebay ghost meter) on The Big plasma globe using only 10 watts putting out absolutely crazy large magnetic field.
                        notice the quote about what DS calls gamma,
                        • #27
                          Self Running Bedini Oscillator
                          Charges itself back up from a ground connection.
                          [VIDEO]https://www.youtube.com/watch?v=yDtXR_1Ubs8[/VIDEO]
                          • #28
                            Thanks Aaron, OK you have my support. link?
                            Consider bringing him back now
                            • #29
                              self running oscillator
                              [ATTACH]20514[/ATTACH]
                              What link?
                              And what does Rick Friedrich the sociopath have to do with this? lol
                              • #30
                                What link?
