TinMan's true energy amplification device
  • TinMan's true energy amplification device
    TinMan is working on a bigger sealed vessel power gain project where this is playing a part.
    here he shares an interesting experiment .
    TinMan
    quote
    Is the venturi really an energy amplifying device?
    Here in this test,the air flow is regulated at 5psi,and flow restricted by the 1.6mm jet. The extra force produced to spin the generator faster to produce more power is coming only from the environment
    BE that change !!
    Hi Chet, Wouldn't opening the valve reduce the pressure the blades are seeing, since the tip 1.6mm is restricting the airflow and opening the valve would be a path of least resistance?
    Maybe the design of the blade is better suited to less pressure?
    Just asking.
    Thanks artv
      Art
      Is it pulling in Cold air [pressure drop] ?? or letting air out ? its running at 5 PSI [I think]
      perhaps the Blade is in a "stall" condition and designed for a specific flow ..which appears when the venturi is opened??
      interesting take Art.
      the fan drives a linear load...and yet the power out doubles with a metering valve in place ??
      It twists my mind for sure .perhaps the fan has some design specific attribute
      thanks for looking and commenting.
      Chet K
      PS
      TinMan is working on something like this
      Gaia-Energy demonstrating 5 kW home power Rosch KPP prototype in Germany; taking orders
      BE that change !!
        Very interesting demo - well done Tinman I wonder if it is the air mass being increased (air sucked in and added to main air stream) that is responsible for the gain?
          Cop 1.33
          Here is another Vid From Brad ,as stated this is part of another developing system
          where he is harvesting energy from the environment and has a COP of 1.33
          Chet
          BE that change !!
            So by adding that T piece added ~3lpm more thrust?
            Can you keep adding more in line to keep increasing the pressure?
            Great experiment I like his videos
            Thanks Tinnman and Chet for posting.
            artv
              Good to see some tinkering but there is no free energy. The venturi effect slows the speed of the air out of the orifice by the vacuum it creates. Opening the valve removes this vacuum and the flow speeds up. Try exactly the same jet but out of the venturi , the fan will speed up. Thats why carbs were more restrictive than fuel injection.
                Pomodoro
                So to understand your point, the 1.6mm orifice TinMan uses to restrict the flow
                develops a vacuum/restriction to flow on the inlet side which is removed when the second venturi valve is opened
                thus the increase in speed ?
                seems he could place a few gauges to measure this,
                thanks for your input.
                Chet K
                BE that change !!
                  A Problem with that.....
                  Pomodoro
                  I was reminded that there are flow gauges in the circuit already....
                  wouldn't your analysis of this experiment be reflected in the flow gauges ??
                  It does NOT seem to be the case ??
                  the vid https://www.youtube.com/watch?v=0fQkEp0iDGo
                  @All ,thanks for looking and commenting.
                  Chet K
                  BE that change !!
                    Thanks for the video with the flow meters. Yes, this video is more convincing. More accurate flow measurements are required as I am not sure if those flow meters are accurate under pressure, perhaps some tiny hot wire anemometer in the pressurised pipe. If he can keep the the hot wire at the same current for venturi on and off, then he has improved the efficiency for sure! Someone has to also determine the theoretical maximum efficiency for such a system and see if this system overcomes that. Its a good , simple experiment, well done.
                      thank you
                      Pomodoro
                      Your input and ideas are greatly appreciated .
                      respectfully
                      Chet K
                      BE that change !!
                        yes timan is a very good experimenter
                        but this one is really amazing
                        big bravo
                        i will test it anyway
                        too good
                        thank's tinman for sharing and chet for bringing the idea in this forum
                        laurent
                          Working away from Home
                          Laurent
                          The TinMan left on a work trip yesterday, he'll be gone a few days.
                          Thanks for looking in and commenting.
                          respectfully
                          Chet K
                          BE that change !!
