The v gate motor could be converted to this ..thats a version of the magnetic Wankel... There's another video https://youtu.be/ahL6VWFhtas. How about a .0009 watt motor .
Magnet motor revelation
OK here's a new thought this tordial core being turned off has no attraction .and a magnet passes by .but a donut type core is to shallow to use the other side for a second magnet attraction motor .two feeding off the same core really can't be done well because of the closeness of the two big neos .they would either lock or replus each other when the cores turned on and off .but a pipe shouldn't do that being longer giving greater separation of the magnets....might work .doubling your output power.
Very nice motor, I like these.Originally posted by jim glinski View PostThe v gate motor could be converted to this ..thats a version of the magnetic Wankel... There's another video https://youtu.be/ahL6VWFhtas. How about a .0009 watt motor .
https://www.youtube.com/watch?v=ahL6VWFhtas
if I'm remembering right he says that the extra cores didn't add much or anything to the power input .?.if true then why not more ?.and bigger .it could make a nice desk top fan but needs a larger blade .notice there's no recycling of back emf or spikes might be room for cap charging and increased run time then there's the three battery or cap system .he's this good and without the advanced add ons.
Hi guys I woke up this morning and realized that the guy running this motor ISN'T USING THE RETURN ENERGY !! THAT NEON IS TURING ON AROUND 100 VOLTS AND THE MOTOR RUNS ON 2.7 VOLTS !!! he is not recycling the energy . and in another of his videos he runs a 9 volt battery for 12 hours ? And at another point said at the end 40 hours ? Hard to hear him .he said rotation was still happing at .5 volts. .hers the point on the original school girl motor of bedini the science teacher at the show calculated that her motor would stop in four hours but it didn't that's what drove them crazy. It ran for two months !! This motor of his isn't recycling that energy at all he's dumpling to ground at least 100 volts or much more .could their be enough energy there to run a whole another motor ?? And that motor another motor ??. And were not even using the rotational energy yet .
Here is one that takes ZERO to run.but sad to say it won't power the barn lights so the chickens can get around at night.Originally posted by jim glinski View PostHere's that video you can see the neon flashing to ground it tirigers at around 100 volts but it could be 400 volts over all who knows ?.
I have come up with a new idea its a bedini split ring wankel I chose bedini because it can be used as a magnetic switch and charges five or more butteries at once that's close to free .the coil is a horse shoe type using both poles to drive the unit doubling machinal out put . per pluse .there's one at 12 o'clock and one at 6 o'clock it uses neos or ferrite magnets and double magnet rotor wheels and double split rings . it should run like a bat out of hell .orbo ran around 4,000 rpm but weak .this is driven by the neos attraction to the split rings then at lock up the bedini coils frees it to continue .if this isn't over unity I don't know what is .I'll post a diagram of a two coil unit .it should be self explanatory .
