ENLIGHTENED MAGNETISM (The Full Proof of Ken Wheeler's Theories)
  • The chains of ferro particles and filtering spectra toward redshift is thought to be tightening of layers. The dielectric sandwiched not discussed unfortuneately
    When H=0 the particles go random, frequency shift not sure possibly thickness.
    The data points for scattering are not unique not conclusive. There may be other information.
    • "Basically we have created many millions of "slits" that have the freedom to self-align with the lowest potential of the field."
      I have great respect for Timm, he's a good researcher. Sometimes things discussed are not particularly from his point of view.
      The above quote is important because of the" self align with the lowest potential
      of the field" this is happening in 2d although it might appear as in a gas.
      We need to look at the field from any particular point in space, with a compass
      although the needle assumes the lowest possible state the pivot point is FIXED.
      The earth is in essence a magnet so show me how to view that field and get
      the results you get from a cell.
      NASA is studying magnetic reconnection, its very interesting and worth a look.
      John.
      • Originally posted by Iamnuts View Post
        of the field
        Hi Iamnuts,
        The fact that Ferrocells reacts, aligns their metallic nano particles with the lowest potential of the field is a great advantage...by this metallic particles aligning on the lower potential side, they will darken those lowest potential zones, then showing the HIGHER POTENTIAL SIDE by allowing light to pass through the lower saturated part of the ferrofluid.
        Think of it as the 35mm film...it contains some silver crystals which are sensitive to light, when light is processed through the camera and sent to film for fractions of seconds, those crystals which receive the strongest light become metals which obstruct light (become dark)...so we get a "negative image" which is basically lightening up all darker areas of the image while darkening all lightened areas.
        Ferrocell is more like a "positive image" rendering of magnetic fields, all particles aligning at lowest potential of spectrum, allowing light to pass through the HIGHEST potential side...and that is what we all see "illuminated" at the lens.
        Also the Ferrocell has the capacity (same as 35 mm Film) to show GRADIENTS (smooth degradation's) between Hi-Lo Zones, which render a smooth transition and a Higher Definition Image of the Magnetic Fields.
        Ferrocell takes a bit to process the image of the Field, similar to how a Polaroid Film does, except that it will clear back up again when field is not present, also in a slow process. One thing that must be careful with ferrocells...is NOT to leave them exposed for long times to a magnetic field, because it will "burn" the cell...darker blemishes will appear and that's it...not good anymore...sometimes after a few months, it may rearrange itself...but most of times is just trash.
        I agree with you in a 100%...that we should be able to see the field in a "spherical view" around it to perceive a full 3D Imaging...just like Ferrocell does.
        Ferrocell particles are free to "swim" inside the fluid and group at the field lowest potential...and that's the way to do it in order to observe a truly image of Magnetic Fields Higher Potential ILLUMINATED based on light filtering.
        John.
        I am pretty sure someone would come up with a far more complex type of technology which includes the ferrocell principle of operation...by "far more complex" I meant to have a hardware-software processing the images, just like a 35 mm camera does...but even better...like a DIGITAL Camera works...where we do not need to send it to a lab to be processed and printed.
        Cameras have a very complex and sensitive "Bulb" [imaging sensor] where images are captured then sent to the electronic processors...then sent to the LED Screen...same way we could have a "Ferrocell Bulb" which is directly connected to hardware-software processors for Instantaneous HD Viewing in every single 3D angle of the Field...and from any distance with Zoom, Focusing, shutter speed, light control sensitivity...etc,etc...just like any Digital Cam works...no big deal.
        • iamnuts,
          All these optical effects Rayleigh scattering and so on have little to unimportant role to play once the ferrocell is activated by an external magnetic field where refraction index of ferrocell is directly and almost exclusively overruled and controlled by the polarization of external magnetic field induced in the ferrocell.
          If you don't want to accept the real field flux geometry of dipole magnetism shown by a modern nanomagnetic single domain (go read about single domain to understand their importance) nanoparticles observation device and stick to the 200 years old grandpa iron filings showing just where the relative positions of the two poles are and really contribute nothing more to the knowledge on magnetic fields and their actual vortex structure shown correctly by the ferrocell and furthermore to understand that everything in nature and the cosmos spins and creates a vortex, that's fine with me and I respect that.
          Also NOT comprehending as shown by your previous reply to me, that ferrocell is totally transparent to magnetic flux coming from both poles of a magnet , therefore 3D Euclidean field of magnet is projected on the 2D surface of ferrocell and therefore flux lines appearing as interlaced at the 2D surface however actually overlapping in 3D space,
          with other words don't believing that the image we get from the nanomagnetic ferrocell is due magnetism but rather due some light interference phenomena, that's fine with me and I don't really care to convince you otherwise,
          However, name calling a person you don't really anything about in your first reply to me without anything done from my part to provoke you and actually kindly greeting you at the end of my post,
          and insulting me... this I DON'T TOLERATE AND ALLOW and I don't respect you.
          NEXT TIME iamnuts I WILL NOT BE SO KIND WITH YOU!
          take care,
          EM
          MSc. Electronic and Computer Engineering, TUC, Greece
          • As I. suspected Markoul, you're a wimp.
            Ken called Einstein an "idiot" and referred to Quantum
            as "bull****".
            I'm expecting to see a Nobel prize soon.
            John.
            • Help understanding your logic
              ... by allowing light to pass through the lower saturated part of the ferrofluid.
              Hi Ufo,
              In your first paragraph, a couple things need further explanation in my opinion. Many ferrocells use edge lighting with opaque backing. How is light passing through?
              Are you speaking about magnetic saturation? Of the ferrofluid in the cell? Can nanoparticles saturate? Aren't all the dipoles in the particle already aligned? Or are you speaking of the combination of particles, in which case, wouldn't saturation just be alignment?
              Lower saturated? I don't understand. Saturated means full. If it is less full, then it isn't full.
              • Ferrocell particles are free to "swim" inside the fluid and group at the field lowest potential...and that's the way to do it in order to observe a truly image of Magnetic Fields Higher Potential ILLUMINATED based on light filtering.
                Dear Ufopolitics,
                I couldn't agree more with you on that and you said it wonderfully . However I must say this "lowest potential" term brings confusion. In the ferrocell but as well CRT the flux trajectories closer to the body of the magnet are actually the highest potential of the field (it is well known fact in physics that the strongest field vectors are the shortest in distance from the source). As you go further in distance from the magnet, flux lines shown represent lower potentials of the magnetic dipole field. The magnetic field strength as you know for the far field is diminishing with distance with the inverse cube law for a dipole magnet.
                Unerstand, that field of magnet consists of many of these layers or shells of flux like an onion filling completely the 3D space around a magnet and its radius of influence.
                Ferrocell is not showing lowest or highest potential shells of magnetic field but because it is a single 2D surface in space every time depending its distance from the magnet, one slice only or shell of the 3D magnetic field is magnetically projected on the 2D surface of the ferrocell. And by meaning surface of the ferrocell I am not referring to the glass but to the the microns thin film of ferrofluid encapsulated inside the ferrolens (i.e. two glasses of ferrocell).
                Hope, this clarifies things.
                Kind Regards,
                EM
                • What is not discussed here is the Aetheric realm.
                  An element's unique aetheric field geometry.
                  The two types of magnetic energies.
                  Conditions needed to form a charge separating mechanism.
                  The application of expansive and contractive properties.
                  Those that uses this animated icon might be a clown
                  did I ever use this ? what about being nasty then saying regards
                  just political correctness and outrage over nothing.
                  • Apply light and magnetism to either glass surface. Polarization of the applied magnetic field
                    will determine the "angle of incidence" light experiences as it exits the cell.
                    Using a permanent magnet is the easiest way to apply a polar field and see how a
                    Ferrocell will change the path of light and also appear as a holographic image to the viewer.
                    The center point between poles of the viewed image represents the Null Zone or more
                    generally, the Bloch Wall. (Not field lines like iron filings show).
                    Each point of light will follow a path in relation to its position in
                    space around the magnetic field and change its dimensional shape
                    depending on our point of view.
                    These 'paths' can be twisted, bent, made thicker or thinner, joined or repelled,
                    added to or subtracted from by the polar influence of two or more magnetic fields.
                    To make this event visible to the naked eye, a large surface area and strong magnetic fields are required.
                    Unlike most passive optical devices, a Ferrocell will exhibit the same results with polarized or non-polarized light.
                    There are other minor functions that happen in the cell, too. The layer of particles act like a filter for higher visible
                    frequencies (blue, violet) similar to the Christiansen Effect while enhancing lower frequencies (red, IR).
                    Light experiences Rayleigh & Mie Scattering, plus the Faraday Effect and other Magneto-optic phenomenon.
                    For more detailed informat
                    This is what ferrocell himself says so someone's peddling crap.
                    • I think Markoul shot himself in the foot here
                      "Also NOT comprehending as shown by your previous reply to me, that ferrocell is totally transparent to magnetic flux coming from both poles of a magnet , therefore 3D Euclidean field of magnet is projected on the 2D surface of ferrocell "
                      If the cell is totally transparent then nothing at all would happen!!!
                      John.
                      • no, transparent meaning showing both fields of the two poles of the magnet simultaneously, projected on the 2D surface of the ferrocell as an interlaced image of the two different pole fields but which of course are overlapping in 3D space.
                        Also Timm, inventor of ferrocell from his site you got the above quote, talks here how the image we get is the actual magnetic field projected on the ferrocell.
                        I don't see anything suspicious here that is negating any part of what is told in this thread here by me and Ufopolitics, about the operation of the ferrocell when activated by a magnet placed on it.
                        I think you are deluded on that...
                        All the other optical effects he is referring at the end are minor effects which have little to none influence to the image outcome of the field we get on the ferrocell of a magnet placed on it. As I said before magnetic polarization of the ferrocell by the magnet overrules any other light interference effects which are negligible to the end result.
                        He states all these optical phenomena because ferrocell except of study of external magnetic fields can also be used in research for inactivated magnetic thin films photonic properties.
                        • You can get loads of different patterns.
                          I need dialectic on the dielectric.
                          • I think the idea of field lines is total rubbish anyway.
                            The best guess I have is that the field strength would
                            act in accordance with the inverse square law so
                            tbe ferrocell images are useless.
                            John.
                            • Saturation
                              Hi Ufo,
                              Hello Bistander,
                              Light propagation is Radial, spherical in 3D (unless we add conical reflectors to force it directional, NOT the case of LED), the LED's are located around the Ferrocell, however, that does not void light from going everywhere, and also to the magnet, no matter if magnet is above or below...it will be illuminated as well.
                              Nope, I am NOT talking about Magnetic Saturation.
                              Saturation as in Chemical Saturation.
                              Exactly, saturated means "full"...but not exactly that term "full" applies when we are talking about a whole compound of liquid and ferromagnetic nano particles, compressed to the extent to act-behave as a Gas.
                              Ferromagnetic Particles concentrate at the Magnetic Field areas of lower potential.
                              Higher Concentration of Particles on Lower Magnetic Potential= Higher Saturated areas on Lower Magnetic Potential.
                              Then, the "Lower Saturated Areas" (or lower concentration of nano particles) are where the Higher Potential Forces are present.
                              Lower Saturated Areas ALLOW LIGHT TO PASS through, while lower potential areas, with higher concentration (Saturated) of particles BLOCK LIGHT.
                              But this is not all about this arrangement.
                              The space between two high potential area is also a low potential side, hence particles group there as well...this defines the illuminated "curved lines" with darker areas in between...achieving a much better resolution, bringing up these higher potentials lighter to the viewer.
                              Besides, due to such small size of these nano particles, floating in a gas-like environment, they offer very neat LIGHT GRADIENTS between Hi-Lo Zones.
                              And of course, whenever we use the RGB Colors as illumination, we get different levels of 3D Gradients according the each color light wave propagation in the whole Magnetic Field Spectrum...
                              Hope you understand it better now...
                                https://youtu.be/rUZsojDdEbE
                                NOPE, WRONG...You do NOT get "loads of DIFFERENT Patterns"...NEGATIVE!
                                You just need a GOOD BRAIN, which could PROCESS every single pattern into a SINGLE TRIDIMENSIONAL SPATIAL MODEL.
                                And here I understand that not all Brains can process all this patterns to see the FULL PICTURE.
