Pole reversal.
The test coil was wrapped bifilar and connected serially like Tesla's Pancake. The 3/4" Neo tube magnet diametrically polarized. This discovery was accidental. I planned to run the spinner with my inset spiral and SSG. The "Hot Wired" Reed switch was just a quick and dirty way to test my novel precision ceramic bearings. The switch touched the coil by accident. I was startled by the sudden burst of explosive speed. I don't know for sure what the coil polarity was originally. It would take very little to try it with an opposite coil polarity once set up and tested as I outlined. All you would risk is a $3.99 switch. A reversed coil polarity will either work as well, more poorly, fail to work, or fail to work and fry. A hot switch is a dead switch. Replace the switch and reverse the battery electrodes if it heats up and fails, and stand by for "Blastoff".
The spinner has two poles. So basically it should make no difference which pole faces the magnet rotor from the coil end, right?
Imagine a N pole on the coil end. This may result in a "push pull" repulsion attraction motor. This is the only other possible way it may have worked.
The south pole would close the switch, energizing the coil and causing either an attraction to the pole or a repulsion to the following north pole. At the same time the coil's north pole would quickly close the switch a second time, perhaps attracting the south pole of the magnet and so on. I'll be Frank in admitting; I'm really unsure of which way it worked. It's possible that it may work equally well either way, one way better then the other or one way not at all. The other issue is that it's possible that the bifilar coil produces two poles on the end. There's one way it works for sure!
What I can accurately report is that there's an instantaneous doubling of speed from around 25k to 50k R.P.M. that may involve a double turn of the magnet spinner. This, I believe is an "Overunity Event" that merits further experimentation and testing. Special high quality, near to frictionless bearings are a requirement to witness this "Quantum Jump" in speed.
