I'm trying to understand why you think drawing less amps is a bad thing? I have seen speed up under load WITH lower amp draw so I know it is possible. Is there a reason I don't understand why I should WANT greater amp draw? I have an open mind to almost anything, and I am trying to understand, but you make statements like that with no explanation, and it is hard for me to understand. You may not particularly CARE whether I understand or not, but I thought we were all in this together.
I saw where you stated "In such a system, consumption must increase. The increase results in a stronger motor, higher generator action, higher recovery, higher self and when applicable, mutual induction." so I understand you believe there are positives, but I have not seen that with the systems I have built EXCEPT with the 3BGS, where a load across the battery was balanced with the load on the motor. It increased the motor speed and therefore the generating power.
To edit this, let me say I don't care if the motor speeds up, slows down, increases amp draw or the amp draw goes down. What I want is the MOST efficient production of usable power possible. If the amps go UP but the power production ALSO goes up, then that can be a good thing. It can also be a BAD thing if the power production did not go up enough in relation to the increase in power consumption.
I'm out!
, but for me its a simple transformer action taking place.
This is because we dont have any controls on it as yet. Whats the controls? pulses, on time and off time as well as frequency, and its self regulating with no electronics.
