  • #31
    Here is a Patent document that speaks about wire type
    and the timing issue for tuning. If you are not using
    "Type II superconducting High temp wire" for building
    coils, you have missed the entire experiment.
    Infinity Generator
    Canadian Patent # 2,437,745
    ( 15 Feb 2005 )
    Description of Operation
    List of Components ( Figure 1.0 [ Not vailable ] )
    4 Permanent magnets; M1, M2, M3, m4
    4 Type II High Temperature Superconducting WireBecause Type II High Temperature Superconducting Wire/Coils are employed there is no resistance in the wire and no loss of output due to the windings resistance in the exterior coils.
    • #32
      Images of double or Bi-Coil arrangement using type 2 HTS wire.
      http://lss.fnal.gov/archive/2009/pub...-09-537-td.pdf
      http://www.itep.kit.edu/hts4fusion20...nloads/1B2.pdf
      • #33
        I have not yet read all patents yet and reviewed all Thane
        Heins data but I have this. And alsoa common sense quote
        from the patent that calls for precise calculations in
        timing to assist rotor torque.
        Shade tree experiments are destine to fail, random tests
        without understanding coil calculation millisecond timing
        are futile.
        I have looked on many sites and NOBODY and I mean NOBODY
        is showing how they arrived at a timing calculation mathmatically
        to confirm that they are qualified to understand these systems.
        I will be back to address the similarities of the BiTT and ReGenX.
        Patent quotes in RED.
        • #34
          lets say we had the proper HTS magnet wire and the right
          core material for producing or replicating the AUL effect that
          lowers input power while assisting rotor torque.
          I didn't say just AUL I said AUL that LOWERS input power and
          assists rotor torque.
          I didn't say having just AUL or acceleration under load.
          This brings me back to the BiTT work that I did for understanding
          the ReGenX coil arrangements. Unless you can see the effect
          with the BiTT, I don't feel that you have started from the beginning.
          The BiTT operates at 60hz on a completely different type of
          core material than conventional cores use yet everyone insists
          on using just whatever they have kicking around wondering
          why their rig was a flop.
          The BiTT and ReGenX use a phase shifted voltage to current
          reactive power and the BiTT uses 3X-5X the number of turns
          on a core that requires this. WHY?
          The BiTT is an AC transformer so pole reversals are continuous.
          The ReGenX coils are AC and poles also constantly reverse yet
          special transformer core materials such as grain oriented are
          used to reduce heating, WHY?
          I have AC coils that magnetize any metal around it. WHY?
          WHY do conventional cores operating in AC still need special
          materials?
          If you have a set of 2 or 3 homemade motor coils for motoring
          running at .5 milliseconds at 3600 RPM'S which in some cases
          are where convention coils run, what coils calculation would
          you show to assist that timing?
          Multiple choice: @3600 RPM
          A: a coil that has a 10 millisecond TC
          B: a coil that has a 3 millisecond TC
          C: a coil that has a 5 millisecond TC
          At what phase angle would you want your assisting coil to
          engage?
          Would it be 45 degrees?
          Would it be 75 degrees?
          Would it be 90 degrees?
          Would it be 180 degrees?
          Depending on which value you have chosen will give the proper
          coil dimensions, number of turns, size and type of wire.
          If I have a coil and magnet interacting every .5 milliseconds
          somewhere in between the time it takes to get from point A to
          point B my calculation for assisting will be made.
          If I have a .5 millisecond motoring coil timing and I use a
          5 millisecond Regenerative coil in the experiment, at what
          phase angle will this 5 millisecond coil enter into the equation?
          Will it come into play 5-10 poles down the line?
          • #35
            In these pictures the rotor on the back is incomplete.
            The holes are drilled but the magnets are not yet installed.
            The rotor plate is also moves back so we can SEE.
            Thane is showing progress. But the important thing is that
            we envision the 24 magnetic pole alternating N to S on
            each side and the opposite ends of coils have the rotor 1
            magnet out of sinc with the other side.
            In other ways of stating this the opposite ends of all coils
            have an opposite pole magnet passing by it to produce an
            AC wave. Yet the coils do not operate all by themselves.
            The coils are a set of two as shown in the patent. Not
            one coil passing over one magnet, no, that is not how it is.
            Each thing we talk about is based on some past innovation
            in motor design and what Thane has done is to combine as
            many of these improvements as possible into his systems.
            The patent declares that one or two is responsible for the
            higher result when the rest of the story remains to be scene
            only by those who are applying themselves in this work.
            Special wire (Superconductors Type) special cores but the
            delayed lenz to be calculated based on timing that will assist
            motor action.
            Without numbers we are building a radio without a tank circuit
            and trying to find a radio station we like.
            I am trying to think this through and will be back with some math.
            Thane specifically pointed out one of his devices operating at a
            78 degree phase shift delayed coil action.
            Another video Thane comes back and shows a great big ReGenX
            coil that he says is only 2 ohms and works well. Others are 3,4,5,6
            ohm coils but the timing is a relationship between motor coil
            timing and RegenX/Assisting coil timing to get that phase angle.
            Math.
            • #36
              Here is one important Patent for the ReGenX coils and
              acceleration Under Load. Here you will find the math needed
              to build your replication. Anyone who can run the math will
              be close enough to experiment.
              US Patent
              Application for Generator and Improved Coil Therefor Having
              Electrodynamic Properties Patent Application (Application
              #20140111054 issued April 24, 2014) - Justia Patents
              Search
              Some math highlights.
              • #37
                Stages of coil operation.
                First two Conventional stages then ReGenX have three stages.
                Patent US20140111054 - Generator and Improved Coil Therefor Having Electrodynamic Properties - Google Patents
                Conventional Generator Coil Operation, Stage 1 and Stage 2
                FIG. 9 shows what happens when a North Pole rotor magnet approaches
                a conventional coil which is connected to a load, current flows to the
                load and the coil produces both a repelling resistive electromagnetic
                force as seen by the approaching rotor magnet as well as an
                attractive resistive electromagnetic field as seen by the receding
                magnetic field. The net effect is more externally applied force must
                always be applied to the rotor magnets to keep them approaching
                the coil or they will decelerate and eventually stop if the load current
                is great enough. The higher the current magnitude flowing in the coil
                the stronger the coil's induced magnetic field and the more force must
                be applied to the rotor.
                When the North Pole rotor magnetic field begins to move away from the
                coil's core as shown in FIG. 10, the current flow direction changes
                direction as well and the coil's induced resistive magnetic field changes
                from a repelling magnetic field to an attracting magnetic field which
                resists the North Pole rotor's departure.
                ReGen-X Generator Coil Operation, Stage 1, Stage 2 and Stage 3
                In Stage 1 as shown in FIG. 11, when the rotor's magnet field
                approaches the ReGen-X coil above a certain critical minimum
                frequency the coil impedance delays current flow in the coil and
                it does not peak until the rotor magnet passes TDC. TDC is the
                point in time when the rotor magnet is neither approaching nor
                receding the coil and it is
                essentially stationary. FIG. 5 shows the current sine wave in the
                ReGenX coil (B) which is minimal prior to TDC and maximum
                after TDC. When the rotor magnetic field approaches a ReGenX
                coil above the coil's critical minimum frequency the current is
                delayed and the resultant repelling magnetic field is minimal as
                shown in the isolation
                diagram below FIG. 12.
                FIG. 12 shows the current sine wave for a conventional generator
                coil (A) which peaks at the 90 degree mark (TDC). The resistive
                repelling magnetic field produced by the coil increases in magnitude
                until it peaks at 90 degrees and then changes direction to a
                maximum magnitude resistive attracting magnetic field after the
                90 degree mark when the current flow in the coil also changes
                direction. The current flowing in the ReGenX generator coil on
                the other hand is small prior to the 90 degree mark and does not
                peak until after TDC or until the rotor magnet is already moving
                away from the coil's core. The NET result is the post
                90 degree (accelerative) repelling forces are greater than the
                pre 90 degree (decelerative) repelling forces exerted by the ReGenX
                coil's induced magnetic field on the rotor's rotating magnetic
                field and rotor acceleration occurs under load.
                FIG. 13 shows Stage 2 for the
                ReGenX generator coil when the rotor magnetic field is TDC,
                neither approaching nor receding from the coil's core.
                At TDC the impedance of the coil drops to the low DC resistance
                of the
                coil while the induced voltage in the coil is at a maximum. The
                maximum induced voltage can now be dissipated through the
                coil's low DC resistance which produces maximum current flow
                through the coil and to the load. The ReGenX coil's current flow
                is delayed by the coil's inductance rise time as shown in FIG. 2.
                and maximum current flow
                and corresponding maximum magnetic field produced around the
                coil does not fully manifest itself until 45 degrees post TDC. Once
                the rotor's magnetic field begins to move away from the coil's core
                at TDC the ReGenX coil's delayed and peaking magnetic field repels
                and accelerates the rotor magnetic field in the same direction as its
                original trajectory and accelerates its departure away from the coil
                at a faster rate than it otherwise would be.
                FIGS. 14 & 15 show Stage 3 for the ReGenX coil operation where the
                rotor's rotating magnetic field has moved past the coils core at TDC.
                When the ReGen-X coil discharges its delayed magnetic field which is
                the same polarity as the receding rotor magnet it accelerates the
                magnet's departure at a faster rate while simultaneously attracting
                the opposite pole on the rotor which is now moving into position. The
                net effect is less externally applied force can be applied to the rotor
                magnets to keep them approaching the coil as opposed to a
                conventional generator coil which requires an increase in eternally
                applied force. The higher the current magnitude flowing in the
                ReGen-X coil the stronger the coil's induced magnetic field and the
                less force is required to keep the rotor rotating and the generator
                producing electrical energy.
                • #38
                  Back around 2000 Thane was working on this stuff and here
                  is one of his first entries in 2003 that is easy to read. Very short
                  and to the point.
                  http://www.freeenergynews.com/Direct...eia_patent.pdf
                  Here is an 8 year old entry stating that Thane Heins has nothing.
                  Or have I read this wrong. You see our problem here? If statements
                  like this are to be retracted then why hasn't the retraction come?
                  I guess now we can see why Thane no longer comes here.
                  No Useful Output
                  On Feb. 6, 2008, Peter Lindemann, DSc, writes:
                  I have reviewed all seven video links. In all fairness, I would like to
                  say that Thane has built some nice demonstrations and spent a lot
                  of time running experiments. That said, the films show nothing
                  important. First of all, the films do not show enough detailed
                  information to evaluate the demonstrations. Second, no free
                  energy is shown. In fact, the generators are never shown
                  producing any useful outputs. They are either shown
                  producing voltage in "open circuit" mode, or they are shown in
                  "short circuit" mode, where the generated voltage drops below
                  one volt. So, ZERO WATTS are produced in either case.
                  The changes in mechanical drag are due to changes in inductance
                  and hysteresis. Back in the 1980's, both John Bedini and I
                  independently worked with "variable reluctance" generators.
                  We both saw that these designs work like an inverse to a
                  standard induction generator. That is, they produce maximum
                  drag in "open circuit" mode, and minimum drag in "short circuit"
                  mode. John found that the point of maximum benefit in this situation
                  is to charge a battery, where the impedance of the generator
                  "sees" the battery as a "near short circuit". Under these
                  circumstances, the generator free-wheels and the battery
                  charges quickly.
                  Unfortunately, Thane is not showing any useful benefits from
                  the generator output. So, there is no "efficiency" to calculate
                  because there is no output!
                  The real problem with these demonstrations has to do with his motor
                  drive. The motor driving his system is a single phase induction motor.
                  This type of motor has almost zero starting torque, and only
                  produces its rated power at rated speed. So, the rated speed of
                  his motor is
                  probably in the neighborhood of 1725 RPM. Running this motor in
                  the 100 RPM range converts 98% of the input electric power to HEAT.
                  He says he has a capacitor in the input circuit to the motor, but
                  this is never shown in schematic, so we don't know how it is hooked
                  up. If the capacitor is connected in SERIES with the motor winding,
                  it will act as a current limiter, and skew the power factor of the
                  motor towards reactive power. This is fine, IF you want to limit
                  the mechanical power of the motor as well. If the capacitor is
                  connected in PARALLEL with the motor winding, it will act to
                  produce reactive power for the motor locally, and reduce the
                  amount of power it draws from the wall. But again, this would
                  only be significant at rated speed.
                  The effect he shows when a magnetic field is applied to the motor
                  shaft would be undetectable if he was operating the motor correctly.
                  It is a very weak effect. It is probably caused by the external
                  magnetic field interfering with the induced magnetic field of the
                  rotor. This would not happen if the motor coils were not being
                  severely current limited and the rotor was not "slipping" severely
                  in the rotating magnetic field of the stator.
                  My GUESS is that the capacitor is in SERIES with the motor winding.
                  This will limit the current to the motor to a specific maximum. At the
                  speeds he is running these motors, the only other mechanism to hold
                  back the input current would be the resistance of the wire in the
                  motor coils. If that is all he had, the motor would quickly over-heat
                  and melt the insulation right off the wire. The fact that the motor
                  is running hot is proved in the seventh film where a large black fan
                  is shown blowing on the motor!
                  From the data presented, my best estimate of the efficiency
                  of the demonstrations is that over 90% of the energy going into
                  the motor is converted to heat. The changes in drag of the
                  generators is standard behavior for variable reluctance topologies,
                  so accelerations or decelerations of the motor DO NOT represent
                  energy production, just changes in HYSTERESIS DRAG. Since no
                  output energies are ever measured, the input to output efficiency
                  ratio is ZERO.
                  Thane Heins may have more important discoveries in his lab,
                  but they are not demonstrated in these videos.
                  I'm really sorry to have to comment negatively on Thane's work.
                  He is exploring a new effect, and he is pretty brave to put out his
                  data. It took John and I years to figure out what these kinds of
                  generators were really doing and why. It is not obvious, and it
                  takes a lot of experimenting and thinking to work it out.
                  Thane really needs to show the complete schematic of his test
                  apparatus, including the strength and orientation of the magnets
                  on his generator wheel, as well as the specifications on his drive
                  motor. There is a lot of important data missing from the demos.
                  • #39
                    next is a world renowned entry right after Peter's (Dr. Peter L.)
                    This entry reinforces the assumption that Thane Heins has made
                    a mistake in his experiments and is not infact getting any excess
                    power. In other words Thane is fooling himself.
                    Calling him an incapable EE. Now who is the fool?
                    Nothing more than a hysteresis brake
                    • On Feb. 6, 2008, DMBoss wrote:
                    • Quote from: blindsangamon on Today at 02:45:23 AM
                    • It appears that the Perepiteia Motor is nothing more than a
                      hysteresis brake. Placing the steel rods (wound by coils) near the
                      spinning magnets induces alternating magnetic flux within the
                      rods, the resulting magnetic hysteresis causes drag on the rotating
                      disk, and heat losses within the steel rods. Shorting out the coils
                      effectively shields the steel rods from the disk's magnetic field,
                      eliminating the hysteresis drag. This causes the motor to speed
                      up - but not as much as it would if the steel rods were removed
                      completely.
                    • BUSTED!
                    • Hi:
                    • blindsangamon is correct. This is a common phenomenon
                      regards "generators", but one often not commonly known about
                      if you are not working with AC motors and generators all the
                      time. So the professor at MIT may not have this practical
                      engineering savvy to identify the issues at first glance.
                    • An hysteresis brake is one way to describe the apparently
                      anomalous increase in speed when you short the generator coils.
                      What EVERY ferromagnetic core does when exposed to varying
                      magnetic fields is to have it's domains rock or flip direction in
                      accord with the magnetic field changes impinging on them.
                    • This consumes power in the "friction" between domains as they
                      sort of scrape past each other. It results in the material heating
                      up. In addition to this hystersis "loss" is an eddy current effect
                      within bulk steel from the very same time varying magnetic fields,
                      also making heating of the core. These two effects combined are
                      commonly termed "core loss".
                    • Core loss produces a reaction torque in a generator, in that the
                      domain "friction" resists their aligning with the external field - causing
                      more drag torque. Eddy currents make magnetic fields which oppose
                      the fields making the eddy currents too, making more drag torque.
                    • Now "core loss" in any ferromagnetic core material is directly
                      proportional to the induction, B. Put another way the higher the
                      delta flux density, the more core loss you get. (it is also
                      proportional to the frequency, but let's assume a constant freq
                      here, even though it is not at a constant one - it speeds up and
                      slows down, again a neophyte mistake - you must measure things
                      here at common speeds/freqs to make comparisons accurately)
                    • And the induction, B is then what produces the coil voltage
                      via Faraday/Lenz laws. That is voltage is the time derivative of
                      delta flux. So people, when you short a generator coil and it's
                      voltage drops to near zero, you can be certain that the delta B
                      within the coil's core is also near zero!
                    • So if you started with a delta B of say 1,000 gauss at no load
                      on the coils, and your core material produces say 15 watts of core
                      loss per pound of core (solid steel is in this ballpark, which is why
                      we laminate special steels for transformers which takes the core
                      loss down to about 2 watts per pound) then you'd have some
                      serious drag torque experienced by the drive motor with coils
                      open circuit.
                    • Now if you short the coils and drop the delta B down to say
                      10 gauss, you have REDUCED the core loss by a factor of
                      1000/10=100 times less core loss when shorted than when
                      open circuited!
                    • This means 100 times less drag torque felt by the drive motor!
                      (therefore the common shaft speeds up when coils are shorted,
                      duhhhh)
                      [*]This is amateur hour gone mad - both in the videos and mostly
                      in these lists! Which does nothing but hurt the cause of getting
                      O/U to the masses in my view, as it simply reinforces to the
                      powers that be in the scientific community that it is a bunch
                      of flakes and idiots making these claims!
                    • Now I will also say, that heavily loading certain geometry of
                      generator, can produce some gain. I have several examples on the
                      bench which do. But they are proprietary and I don't care to share
                      this with lists. BUT you have to do proper energy/power balances to
                      measure this gain. And you have to endeavor to reduce core losses
                      to a minimum and account for core loss change when you heavily load
                      the coils too.
                    • I have one which gets a gain in excess of the entire core loss value,
                      both eddy and hysteresis - therefore the gain cannot be from this
                      artifact that plagues all coil/core systems. But it is a modest gain,
                      and yes the rotor does want to speed up. But you have to manage
                      this speed, and measure the loaded and unloaded condition at the
                      same shaft speed, because friction and windage change too when
                      speed changes.
                    • Then you have to measure True power at the shaft input via
                      torque sensing and speed, against True output power, including friction,
                      core loss, coil heating and direct electrical output for a complete
                      energy/power
                      balance. In fact there is an IEEE protocol for doing
                      a complete power balance on motors and generators, which includes
                      all these things.
                      [*]This person did few if none of these things properly and is
                      delusional about the apparent speed increasing meaning it is O/U.
                      There could be a small amount of gain in his sloppy and amateurish
                      system, but it is completely overriden by mundane, conventional
                      effects as "blindsangamon" correctly points out.
                    • Sorry for being so terse with you folks, but it is very annoying to
                      watch so many people do harm to the cause by spouting off without
                      really having a grasp of conventional ElectroMagnetics. Both amateur's
                      like in these videos, and indeed a large percentage of the armchair
                      critics populating these lists! Do your homework before putting foot
                      in mouth!
                    • There's a few rational voices out there, blindsangamon being one,
                      and most of you then deride these voices with nonsense and blind
                      faith!
                    • here's a simplified protocol for measuring a generator's complete
                      power balance:
                    • Pick or know the optimal final speed of the system. Use only this
                      shaft speed for all measurements.
                    • 1 Measure all parameters in a generator "no load" condition
                      including: 2 Friction alone, meaning with no magnets or mag fields
                      acting on the cores. 3 Then include the mag fields and measure the
                      input drag power (torque times angular velocity).
                    • The difference between 3 minus 2 is the core loss at no load.
                    • 4 Measure the DC resistance of all coils as they would be connected
                      in a loaded condition (i.e. series or parallel).
                    • 5 Load the generator at the same speed as the no load tests.
                    • 6 measure input power via torque times speed.
                      (Newton-meters times RPM times 0.1047 = shaft power in
                      watts)
                    • 7 measure True output electrical power. Not with
                      DMM's. but with appropriate True Power meters or analyzers.
                    • 8 measure coil current, and calculate coil's "Joule heating"
                      via I^2R.
                    • 9 measure and compare coil voltage compared to no load
                      voltage for a ratio with which to discount core loss.
                    • Then take the loaded input shaft power in watts as INPUT
                      to system.
                    • Against this Input, you add the following:
                    • a electrical output in watts
                    • b friction in watts
                    • c core loss via no load core loss times the voltage drop ratio
                      (so if no load core loss were 37 watts, and no load voltage was
                      125V and loaded voltage is 83V, then the ratio is 0.664. Multiply
                      0.664 times no load core loss of 37 watts to equal 24.57 watts
                      output core loss)
                    • d coil heating via I^2R
                    • Add up item a through d for the total system OUTPUT.
                    • Now divide Output by Input for your COP. (Coefficient of
                      Performance)
                    • Note friction, core loss and coil heat are legitimate outputs....
                      they heat the room! Useful output is an arbitrary distinction based
                      on subjective criteria. If you want shaft power then heat is not
                      useful. If however you want a heater, then shaft power is not
                      useful! So to know in the absolute sense if a thing is over unity
                      or not, you have to account for ALL outputs in a balance sheet.
                    • That's another pet peeve of mine - those who dismiss everything
                      they deem as "not useful"! Now suppose you had a system which
                      routinely produces 200% more heat output in coil heating and core
                      heating while it turns a shaft as in some newfangled motor. The
                      shaft power COP is only 35%, but overall the system is 200% gainful.
                      These persons I refer to would dismiss this as not being useful
                      because the shaft power is under unity!
                    • When in fact a home heating system would require a heat
                      exchange mechanism to get heat from your machine to the air,
                      thus it requires a pump - moving air or water or both. So you could
                      make "use" of both the excess heating and the shaft power from
                      said system!
                    • My point is at these early stages it is imperative that you
                      measure all aspects even if you may "think" they aren't useful.
                      For complete energy balances and because overunity may not
                      come in the form you wish it to!
                    • #40
                      In Thane Heins Patents he cites prior art and also uses the
                      name of a device that was another man's name for using
                      lenz law to assist rotor torque.
                      "THE INFINITY MOTOR" remember?
                      Again a motor that AUL Accelerates Under Load.
                      His name is Mark Wesling Mark: [email protected]
                      [VIDEO]https://www.youtube.com/watch?v=V-jI8ecXniE[/VIDEO]
                      [VIDEO]https://www.youtube.com/watch?v=vAXQBpuLu68[/VIDEO]
                      [VIDEO]https://www.youtube.com/watch?v=zrbEtXCsXiw[/VIDEO]
                      • #41
                        Testing for ReGenerative (ReGenX) acceleration using a wood
                        rotor.
                        [VIDEO]https://www.youtube.com/watch?v=d5cdhOmwofI[/VIDEO]
                        • #42
                          Here is another example of AUL Acceleration Under Load
                          using a monopole Motor and high impedance Generator
                          coils. Whenever we have made Bedini coils following
                          instructions we use a set length of 130 feet of twisted
                          wire and if the generator coil length instruction is
                          followed, you end up with a much bigger coil. It dawned
                          on me that John bedini has been Accelerating his monopoles
                          under loaded conditions using the high impedance generator
                          coils, just like we see with the Thane Heins approach.
                          It is my belief that John Bedini explains things differently
                          than does Thane Heins but both are operating the same
                          principle to extra energy.
                          If anyone remembers how that the generator coils were
                          much longer and thinner wire. This means that the more
                          power that is extracted (To a Point) from the generator coils
                          the more the rotor accelerates and the more energy is
                          generated for output. It's been right under our noses
                          all of the time and because very few people followed through
                          with adding generator coils, little information is available
                          on the similar effects Thane is reporting.
                          Notice the 3 generator coils in the video.
                          [VIDEO]https://www.youtube.com/watch?v=GOoKoKqeJsM[/VIDEO]
                          • #43
                            7 years ago Thane did these tests and these video's are
                            no longer present on his channel.
                            [VIDEO]https://www.youtube.com/watch?v=ogLeKTlLy5E[/VIDEO]
                            [VIDEO]https://www.youtube.com/watch?v=1vX8Cxkrpqs[/VIDEO]
                            [VIDEO]https://www.youtube.com/watch?v=jpIdu1lWVW0[/VIDEO]
                            [VIDEO]https://www.youtube.com/watch?v=Q18eSaiKMyc[/VIDEO]
                            [VIDEO]https://www.youtube.com/watch?v=3WrzCRimtHc[/VIDEO]
                            • #44
                              Thanks Christian
                              Originally posted by lorinrandone View Post
                              hello everyone
                              my name is Cristian Alba, and I'm the same of the thread >>Magnet Motor revelation< <. Today I bring my research on the effect commented on this thread. Few expenses, with common materials by hand of any people
                              here:https://www.youtube.com/watch?v=rjoav6SwFvg and here:https://www.youtube.com/watch?v=j0_Z...ature=youtu.be
                              please comment.
                              Best regard.
                              [VIDEO]https://www.youtube.com/watch?v=rjoav6SwFvg[/VIDEO]
                              • #45
                                I would like to point out that I am a beginner in the
                                regenx work of Thane Heins. Also that no one has ever
                                pointed out an important detail needed to replicate
                                Thanes coils.
                                This shows me how little effort has been put forth
                                by what we call serious experimenters.
                                First a picture of type 2 HTS wire called for by the
                                construction details and secondly the words from the patent.
                                Hopefully this can show us why all of the test data offered
                                by those who claim adept status in the art continue to
                                confirm only failing results.
                                This information is critical and equal to the type of core
                                materials used to produce the effects.
                                If anyone has a source for 2G HTS wire we could all get
                                to work with the proper stuff. Bifilars wound parallel
                                connected series is no problem but let's use the right wire.
