I'm starting this new thread because the "Plasma Vortex Motor" concept folded out of the "Oscillating Reed switch motor" thread, but no longer involves a "Reed switch".
Proto G has 50amps going into his electrode with an output in excess of 12,000 volts:
"The magnetic field from this neodymium ring magnet is massive compared to the ceramic ring magnet. 13,200 Gauss of the neodymium compared to about 2,000 Gauss of the ceramic ring magnet. You might notice that the arc is bulging out the front quite a bit. Not only do we have the Lorentz force acting on the moving charges particles, but the magnetic field is strong enough to interact with the magnetic field created by the current flowing through the arc. The magnetic field of the ceramic ring magnet does exert a force on the arc but it isn't strong enough to make it bulge. Of you watch the end of the first vortex video where I used the neon sign transformer, you'll see that the arc is also bulging but it's bulging because there is such a stronger magnetic field being created from the higher current that it starts interacting with the weaker magnetic field of the ceramic magnet".
The spinning magnetic flux in Teslas, generated in this video, should be dense enough to generate close to one horse power with over 600 watts of input. Proto G is using his "Dynamo" as an audio speaker, apparently oblivious to it's awesome magnetic field power, which is invisible an undetectable. The intention of this thread is to modify and adapt Proto G's "Lorentz Force Plasma Vortex Generator" into an electric motor. This motor should run at 100% efficiency with no BEMF.
My youtube comment to Proto G:
"I initiated a thread on "Energetic Forum" entitled (Plasma Vortex Motor) as Allen Burgess. I plan to modify and adapt your design to power an electric motor. Awesome work! You're invited to participate in the discussion".
