Splitting The Positive
  • Originally posted by blackchisel97 View Post
    Hi Ron,
    Just watched your YT videos and I admire your craftsmanship
    I have couple MY1016 24V 280W and could send you one. The centre part (stator without end plates is about 2-1/4". You may want to replace bearings with better ones but it will give you something to experiment with. It took some time to find them at reasonable price. They can be found very cheap in the US but not here and shipping often costs more than used motor.
    V
    Sounds good, will be in touch
    Ron
      [FONT="Comic Sans MS"][COLOR="Red"]Thanks .
      Making lots and lots of coils experiments. Wind them up quite long and
      begin removing a 10 foot section of wire and retest. So you see Dave
      has already made the common deduction and has stated for the record
      as any experiment should well know that each setup will require a
      different coil.
      Just for the record... Thane's requirement of a high impedance coil is false, as Erfinder has said for years, Just to confirm Erfinder here is a 11 mH, 1.2 ohm coil accelerating under load... just about any coil will.
      https://youtu.be/Z_cHxFwqy4M
      Ron
      • Originally posted by i_ron View Post
        Ron
        Thanks Ron, keep it coming, great video's, good pointers. ER did say
        something any that but I forget fast. I really like your stuff because
        you don't hide what you know.
        • Originally posted by Turion
          I_ron,
          YOU are correct. A high impedance coil is NOT necessary. It's just the easy way out. We were told THAT over 120 years ago, and I don't think erfinder is that old. LOL. My coils are NOT high impedance either. That kind of coil puts out voltage but NO amps. Not really what you want for a generator. And by the way, Thane does NOT say that ONLY high impedance coils will work. But he does say that high impedance coils WILL work. He has coils that are NOT high impedance that will work too. There are several factors to consider when you want coils to speed up under load. I tried to start a thread on that, but people who contributed had their own agenda, so I gave it up. Now I'm just doing my own thing and building my own stuff, and eventually I will probably post some things here when I have everything done the way I want it.
          Awesome Dave, where the hell have you been?
          I missed you while you were gone. Vacation hey? Well it
          must be nice doing something new for a change, hope you enjoyed
          your once in a lifetime get away.
          Here is what I would like to add to your comment as everything you
          said is right on as always. Here is my comment:
          "HIGH IMPEDANCE" relative to what? Look at this chart
          This is one of those slow moving (1100rpm) box fans. Now if I do an
          ohm check on my scooter motor with a 100 turns (6" per turn Approx?)
          of 20awg magnetwire is like 9 ohms per 1000.
          Comes out to a half of ohm, so a 1.5 ohm coil is triple or a very
          high impedance coil to my small motor. In the case of the bench
          grinder motor Thane is using I think is 1 ohm? Something like this
          a very low impedance.
          I saw Thane do a video calling a 3-4 ohm coil a regenx coil and said
          it wasn't a high impedance coil by many standards, however still many
          multiples higher than the grinder motor.
          Running at 3600 rpm's not 1/3rd this or less at the 1100 rpm figure
          very significant.
          • To understand the relationship of resistance and inductance
            at a certain frequency to find the impedance values we must
            cover a few thoughts on conventional designs.
            In a synchronous motor, the rotors rotate at a speed similar to the speed of a magnetic field, or stator field, while asynchronous motors have the rotor running at a slightly slower speed than that of the induced magnetic field. Synchronous motors can be found in dryers, fans and the axles of off-road vehicles.
            https://en.wikipedia.org/wiki/Induction_motor
            Slip
            Slip, s s, is defined as the difference between synchronous speed and operating speed, at the same frequency, expressed in rpm or in percent or ratio of synchronous speed. Thus
            In our case number of magnets and magnet to coil core material gap
            answer a lot of questions on what impedance may be needed.
            A good way to address coil impedance is to look at contactor cores
            vs motor coil core impedance. A contactor (LARGE RELAY) will have
            a very high resistance and at the inductive value at that frequency
            will be a high impedance also. Some at 50 ohms.
            When the coil of a contactor is switched on if the wire is not long
            enough at that voltage it over heats and burns out.
            In the case of a motor there is some slippage between fields that
            translates into mechanical movement allowing for a much shorter
            coil wind. Unlike a solenoid, relay or contactor the energy is not
            trapped in one small area.
            In the motor coil the slip between the rotating gap energy escapes
            into rotational force and the current does not burn out the coil even
            thought it may be only 2 ohms and operate at 1 amp.
            In our case we are gapping the rotor and core material at say 3/8'
            or .333 thousandths of an inch while the common motor has only a
            .010-.020 thousandths of an inch gap.
            Tesla and others have shown how extending the core material way
            beyond the coil causes a delay as well as the larger gaps.
            So so many variables. Number of magnets, size of magnets, proximity
            of magnets passing core material. Coil stored energy magnetically
            stored energy electrostatically.
            The delay on the scope is what we are looking for. Like Dave said
            if the wire is to long and to thin the output is small as it can also
            only provide a set amount of rotor assistance.
            A balance must be found by each individual's design. One coil can only
            offer so much rotor assisting force so coils must be wound and re-wound
            to find the optimum output electrically vs foreword stored energy
            thrust propelling the rotor.
            This is the goal.
            • Splitting the positive using a 3 battery differential powering
              connection for the prime mover and THEN add a rotor to that
              prime mover motor that has magnets to collect what would
              otherwise be wasted mechanical. Following the work of THANE HEINS
              coils can be wound to help the rotor action relieving the burden
              on the input while producing usable power.
              This is done with a Bifilar Coil. Here is a video explaining the
              standard VS Bilfilar coils capacitance, inductance changes.
              16 - 40 times the value change for the same mass of wire.
              https://www.youtube.com/watch?v=uNAZ6heorEc
              • First let me say thank you to the guys in the other thread on
                BIFILAR COILS.
                Here is another example of using a BIFILAR COIL to speed up the drive
                motor and at the same time delivering power. This is the basic setup.
                https://www.youtube.com/watch?v=vAXQBpuLu68
                • Thank you for the info and links BroMikey!
                  "Rebellion to tyrants is obedience to God." - Benjamin Franklin + Thomas Jefferson
                  • Thanks ET
                    Has anyone really seen any elephant tracks lately?
                    Bifilar experiment here on earth.
                    https://www.youtube.com/watch?v=PxcS0oYsBG4
                    • Let's review the Bifilar but first the inventor, then some math.
                      http://www.rmcybernetics.com/science/physics/electromagnetism2_coils.htm
                      Very very old engineering math dug up from the dungeons of 1940.
                      Seems like a huge shock to our generation of plug and play software.
                      Must be another world.
                      Radio used bifilars early on. Have a look.
                      http://nvlpubs.nist.gov/nistpubs/jres/24/jresv24n6p597_A1b.pdf
                      • Experiment shows how a standard transformers impedance
                        will disappear when connected BIFILAR and tuned. Listen to him
                        say he opened the conventional transformer and separated the
                        standard winding on the low side. Alter yours today, no
                        waiting.
                        No speculation just hard data, no free energy lesson just
                        raw data for those who can wrap their minds around.
                        Bifilars connect in series change everything. A real test so
                        we are not sitting on our hands in a hypnotic state.
                        https://www.youtube.com/watch?v=h11XJwx_ac4
                        • Part 2 with schematic ENJOY
                          https://www.youtube.com/watch?v=Qb_F9ponvqU
                            Videos of people building coils that speed up under load are popping up on the internet like popcorn, yet no one has shown the modified motor running on the 3 battery circuit turning a rotor past some coils (that speed up under load) to produce MORE energy than is used. Is it because we have no builders here, just talkers? YOU HAVE NO EXCUSES!!! Everything you need to know is out there.
                            Amen Hallelujah
                            Did you know all of this? I didn't. Wow there is so much to go over.
                            My project is evolving. I have mounts left to do then the fun begins.
                            Many coils are speeding up under a load on youtube.
                            Soon this will be the new Bedini rave.
                            First, let us review the bifilar diagrams and remember that the gain
                            for a standard solenoid coil VS the same coil mass wound bifilar is
                            way low. Capacitance 16 times lower, and inductance 100X lower
                            the list goes on.
                            Unless these ideas are noticed it is my belief others won't take this
                            seriously. Look at this guy going slow and teaching in a manner that
                            is effective.
                            We all have our individual gifts.
                            You see prior to this week I was under a false impression that Bifilars
                            had maybe 1.5 times value shift data but now i see the possible wide
                            range of tuning possible making the coil it's own cap for any desired
                            RPM or frequency.
                            https://www.youtube.com/watch?v=xHDrmGPY-78
                            • The New Bedini Rave is here
                              If you are going to build a generator coil that "N" and "S" alternating
                              magnets are passing by, consider this data. If you do not see the
                              significance of the changing coil perimeters between regular coils
                              and bifilar coils I feel sorry for you.
                              Talk about tuning inductance to capacitance looking at these
                              formations and what do you see? Or are you all blind men?
                              With this page you should now be able to understand that a coil of
                              wire wound multi-layers can be done that lowers impedance, increases
                              voltage with lower frequencies and much more.
                              Look at this page "look hard" then comment. Can you see how a 100
                              times change to the various will effect the math?
                              This page corresponds to the video below for those who can not
                              understand what was said. Now, what do you think?
                              I know what I think, I think multi-layers and multi- strands just
                              like John bedini taught us. Although John used his Bifilars different
                              he was right on for using them.
                              • permission to ask a question here
                                Mikey
                                I cannot watch videos too easily ,but I have a question
                                if both coils have a total 100 feet of wire ,one single wrap another Bifiler
                                are you stating that DC resistance will be half in the 100 feet of Bifiler
                                as apposed to the 100 feet in a mono wound coil
                                same length of wire ...half the DC resistance ??
                                I will delete this comment if I misunderstood
                                or at your request
                                respectfully
                                Chet K
                                BE that change !!
