Splitting The Positive
  • @ Turion-Man
    My coils were made up of #29 awg wire so it's output was such a high
    voltage I would have to step it down to get the right proportions of amps
    to voltage then watts. I think converters are great but as you pointed
    out before in the past that it is better to use a bit bigger wire.
    My coil was wound 24 strand at 170 feet each. One strand broke inside
    but before I go on let me state that my goal was reached. I used second
    hand wire pulled out of old motors and so one did break. Anyway at the
    6th strand put in series the magic begins on that coil. It does not speed up
    and it puts out real power. It does not slow down but puts out real power.
    Amazing, at that point I was flabbergasted. What that meant to me was
    more than any experiment I ever did. Tesla told us in his patent that he
    used series connected strand to produce, what was it, self induction?
    Or something like that, I am just a lowly mechanic so the terms are all
    foreign to me. I read the books and went to college but was a C+ student
    only. Not very good grades.
    However the honor roll was fun as other subjects drove my grades up
    in high school. By the skin of my teeth. I tried so hard while others hardly
    worked in Chemistry, Physics and so on.
    I have done lots of tests and this I can say, Tesla was right about the
    self canceling induction coils. So at your lead I hooked up the 17 or 18
    strands in series and was only getting 50ma at 220vac but I only
    had one diode on it so that is an unfair result. No fast diodes, no bridge
    nothing.
    I was getting a reading of over 800 volts and the other side was giving
    me 400 vac straight off the windings. I should have done more and will
    but that was not my goal at the time. My goal was to see if i could get
    my coil to produce without dragging down the motor and it did.
    Then as i went to more and more strands in series I got the drive motor
    to drop by 400ma at 88 vac while my coil was lighting up 100v led bulbs.
    I didn't do proper measurements. Sorry.
    The rotor was 10" dia well the magnets placed at about 9" dia using
    20 of them 1/2" cylinders 1" long.
    • Originally posted by Turion
      By the way, I have a whole spool of met glass. It is too wide for my bobbins so I tried cutting it into strips to wind on some small bobbins for a prototype motor Matt sent me. It was like grabbing a handful of razor blades. There was blood everywhere before I was done, so that stuff is nothing to fool with. At low rpm's the output from the met glass was no better than the ferrite for generator coils. Citifa tested it for us. I wanted to make some coils for my big genet of that, and I have just enough to do it.Gotta get some good gloves first. It cuts easily with scissors, but the edges will slice you up.
      Metglas 2605sa1 is said to have been out on the market since 2006.
      Can you remember the number of your Metglas?
      The latest is nanocrystalline it takes the place and far better than the
      old versions. Either one should be as good as ferrite. Also is depends
      on the dimensions of the core build but it could work if done right.
      That way each core would be out of the same material with no changes
      in characteristics.
      • Here is why I need metglas tape to get my shape for a core.
        Or make a two piece "C" with a chip out of it so I can gap the
        halves together for more experiments. Maybe later.
        http://flyer.thenetteam.net/3batterygen/shoecore.jpg
        • Turion post collection/Archive
          It's about time you stood up for yourselves and kicked some ass.
          Guys like him only want to make trouble, but I love your analysis and
          the synopsis is some awesome dude. Keep up the defense.
          Don't make me come out of the woodwork swinging.
          • Yes that was just plan, to have Jordan learn these basic cogging
            ideas thru experimentation like we did with the Mad Mack wheel.
            I've still got the big wheel and the square magnets. My daughter
            gets when I show her stuff, she doesn't have a clouded of thought
            process.
            I think magnet cancellation is one of the coolest test I ever made.
            Here is a simple thought for the indoctrinated. About minute 3 shows
            how opposing magnets can easy the burden on the drive motor.
            Anyone having trouble seeing how magnets can eliminate cogging
            needs to quite their day job and stick with me. I'll learn ya dern ya.
            One of the magnet could just as easily be a coil magnet that produces
            real power. This demonstrates more than one idea but cogging is there.
            [VIDEO]https://www.youtube.com/watch?v=dQn9koeshws[/VIDEO]
            • After over a week of school time runs the 3 battery system voltage
              would not decline so I asked Jordan if he thought it would ever go
              down. He didn't know so I suggest he connect them one at a time
              right to ground and sure enough in about an hour the voltage went
              belly up.
              Jordan ran the 3 battery generator for over a week and the batteries stay
              up great. 7 hrs of runs the batteries stay up around 12.35v average, run it normal and it kills a battery in an hour or so.
              [VIDEO]https://www.youtube.com/watch?v=HPMbiu41MDc&feature=youtu.be[/VIDEO]
              • Like I said, Jordan (my school boy) had run these two motors for
                1 week (this week and some last) and the 3 batteries are not going
                down to a point where they are suffering the need for a charge.
                Batteries need to go down all the way to 12v or 12.10 before they
                SHOULD be charged. Now connecting the battery right to the motor
                does that, it goes right on down to where they MUST be charged.
                Anyone doing this experiment can early see the benefits. Let the
                rest play keyboard games.
                • Yes I think resting helps. Even 10 minutes or 15 minutes, this is what
                  my Son Jordan is doing, he is waiting for the charged battery to settle
                  in at one voltage before he reads it, then records it.
                  Sometimes he has to wait longer because a battery will just keep
                  climbing up, and other times is stops sooner.
                  • Split Positive Pulse motor fun.
                    [VIDEO]https://www.youtube.com/watch?v=DwWvTd8Ni1M[/VIDEO]
                    I need bigger brushes.
                    [VIDEO]https://www.youtube.com/watch?v=HT09vkfJQc4[/VIDEO]
                    • School hours Jordan is now running this quick setup.
                      He bought an inverter and found an LED bulb that runs at the
                      same amp draw as his motor. .8amp or 800ma.
                      • New battery switching board from energybat labs 2018
                        Hi To ALL
                        My name is Geoffrey Miller I have a lab called Energybat Labs, see link below
                        I have followed you Dave & Matt from the being Great work !!!.
                        The people the don't understand the tec shown on this website have not built anything.
                        http://energybat.com
                        I have a new product that you guys might like, it is a BATTERY SWITCHING BOARD.
                        This circuit board was designed by Energy Batlabs & Magnetic Impulse Tech Group LLC to allow for the switching of battery banks in your DIY energy project. This board provides the logic to be used with relays which will allow you to charge one battery bank while utilizing another during continuous operation.
                        Please go to my website for all the info. See pic below
                        Have fun
                        Geoffrey at EBL
                        • I and many others have followed your amazing work for years Sir.
                          Thank you for your awesome offering in the form of a switcher
                          board. I like you work on magnets as well.
                          Seems like a great way to switch batteries around.
                          Originally posted by energybat View Post
                          Hi To ALL
                          Have fun
                          Geoffrey at EBL
                          • Serious builders only, most are not, just wall flowers waiting for a
                            break thru, that's fine. Anyway Jordan's inverter is running everyday
                            at school doing the same thing as the motors do.
                            The nano material can be had cheap and some suppliers will sell 1 kilo.
                            200khz max just like Permalloy of the past at a fraction.
                            CuFeNiSiB
                            https://simide.en.alibaba.com/product/60563560682-803992035/CuFeNiSiB_Nanocrystalline_Alloy_Ribbon_for_Transfo rmer_Cores.html?spm=a2700.icbuShop.prewdfa4cf.50.5 9335ca2CXD5Mk"]https://simide.en.alibaba.com/product/60563560682-803992035/CuFeNiSiB_Nanocrystalline_Alloy_Ribbon_for_Transfo rmer_Cores.html?spm=a2700.icbuShop.prewdfa4cf.50.5 9335ca2CXD5Mk[/URL]
                            • Look at the comparison chart below.
                              https://www.alibaba.com/product-detail/CuFeNiSiB-Nanocrystalline-Alloy-Ribbon-for-Transformer_60563560682.html
                              Look at the Ferrite compared to Nanocrystalline material. Wake up
                              call, the tech train is about to run over us all. Nano material is a high
                              density formation, of course you know that, because you know everything.
                              How about doing? Knowing is easy.
                              Here is something you may not know PoinZee. Most of the lesser
                              expensive ribbons are good to 5khz using Fe (iron) Si (silicone) B (Boron)
                              This material has no nickel and is like transformer steel only much much
                              better. Keep in mind that just about all epoxy glass binders use Si and B.
                              CuFeNiSiB
                              This link provides you with a high permeability version of nano. Consider
                              the composition. Cu (copper) Fe (iron) Ni (nickel) Si and B are substrate
                              or a bed to lay metal dust. Sprayed on at high temps and magnetically
                              forced in one direction as it cools. Annealing.
                              This is the true metglas replacement using nano.
                              [VIDEO]https://www.youtube.com/watch?v=8vton4nBLrU[/VIDEO]
                              • Cogging it when 1 magnetic pole passes another magnetic pole. If
                                the poles slow down as they are passing each other lock will occur
                                and all movement stops. Once the magnetic lock is broken on start up
                                cogging does return. At 1 rpm cogging is more noticeable to the naked
                                eye. At 1000 rpm's your eye can not see anything but a person can
                                measure this cogging drag in current form.
                                The poles in our present day electric motors have magnetic poles passing
                                one another. As 1 pole draws near to a pole they resist each other and as
                                the poles reach TDC then moving beyond the pole try to pull themselves
                                back together thus resisting it's departure.
                                All forms of modern motors and generators operate in this way. Everything
                                is burnt complete up and cast out of the systems circuit.
                                To eliminate cogging, counteractive design strategy should be implemented.
                                See Thane Heins instructional video's.
                                [VIDEO]https://www.youtube.com/watch?v=5osYN5f35Bc[/VIDEO]
