Originally posted by citfta
BEMF current reversal.
Dieter
@Citfa,
Why not jump Dieter's bones over at Overunity where you act like a moderator?
"I think there is only a magnetic field and an electric field, but no electromagnetic field. There is electromagnetic interaction tho. The creation of a magnetic field around a conductor is a sideeffect that by its own is for free, but when this field induces current flow externally (be it eddy currents, a coil, any ring...), this current flow causes the secondary magnetic fields, basicly following Lenzes law and counterinducing an opposite current flow, partially neutralizing the primary field.
Eddy currents, being 1turn shortened coils, will basicly generate heat waste, as in induction cooking plates.
But iron, even tho passive, truely holds the key to various OU concepts, as it is a temporary magnet or magnetic vector deformer.
I myself use Iron to actually violate the law of conservation of energy. But you cannot simply plug a cord to it, it takes a bit more.
See my latest pdf in the files download section if you're interested in how I do that".
Allen
""I think there is only a magnetic field and an electric field, but no electromagnetic field. There is electromagnetic interaction tho. The creation of a magnetic field around a conductor is a sideeffect that by its own is for free, but when this field induces current flow externally (be it eddy currents, a coil, any ring...), this current flow causes the secondary magnetic fields, basicly following Lenzes law and counterinducing an opposite current flow, partially neutralizing the primary field."
I think you could have worded this better. Just saying.
@Doug1,Originally posted by Doug1 View PostAllen
That's a quote from a comment made by member Dieter at the Overunity site. I agree with you that it could been wored better, but on forgiving Dieter, it's only fair to point out that English is just his second language.
Pulsed "Negative D.C. Current".
I've finally arrived at a description of 'Flyback Current Reversal" that everyone should agree on.
Thanks to Lawrence Tseung for his advice:
A Reed switch pulse motor would first close the contacts and pulse the coil with "Positive D.C. Current". Next, the Reed contacts would open, interrupting the current and causing the magnetic field to collapse. A "Negative D.C. Pulse" would then exit the coil in the same direction the "Positive Current" traveled. Connecting a reverse biased LED between the two coil electrodes would illuminate the LED flickeringly.
Tinselkoala's " Coil Current Direction when Power is Interrupted (2)" video contains the following "Slight of Hand" remark from TK in the video comment section:
"The fact that the Blue LED flashes, indicates that the current continues in the same direction through the coil as was flowing when powered. The fact that the Green LED does _not_ flash indicates that there is no reversed current hiding in there somewhere".
Naturally, everyone can see how the truth has once again been sneakily distorted by TK.Last edited by Allen Burgess; 04-16-2017, 12:05 AM.
Here he is again restating the preposterous claim that Inverse is not Negative:
Quote from: TinselKoala on April 19, 2017, 06:11:56 PM
Nelson, I'm glad we agree on this basic algebra.
And now we are beginning to see where synchro has gone off the rails. He clearly doesn't get that the Inverse is not the Negative. X-1 is equal to 1/X, not some negative value. And the H (scalar unit of induction) of the Henry is not the same as the H (vector quantity)of the magnetizing field strength. He apparently has confused these two very different things in his mind, because of the use of the same letter for both. But the H of the field strength is a letter chosen at random by Lord Kelvin in 1850, and has nothing to do with the assignment of the name Henry and the letter H as abbreviation for the unit of inductance.
For Synchro: When letters are Bolded like that it is not done for emphasis. It is a common way to indicate that the quantity referred to is a _vector_ not a scalar. But I don't expect you to understand the difference, since the math is obviously over your head. You should however be capable of clearly understanding that the "H" of inductance is not the same thing as the "H" of magnetic field strength. Or am I giving you too much credit?
@Tinselkoala,
"A negative correlation means that there is an inverse relationship between two variables".
A quote from TK:
"has nothing to do with the assignment of the name Henry and the letter H as abbreviation for the unit of inductance"/
Definition from "Magnetic Reluctance":
"It's an SI derived unit it's the henry (the same as the unit of inductance), although the two concepts are distinct)".
I told him the negative Henry was a measure of a magnetic field, now he's trying to teach me my lesson back.Last edited by Allen Burgess; 04-20-2017, 10:04 AM.
Fake Deaf Sign Interrpreter.
Tinselkoala, the real Thamsanka:
Energy in an Inductor
"When power flows into an inductor, energy is stored in its magnetic field. When the current flowing through the inductor is increasing and di/dt becomes greater than zero, the instantaneous power in the circuit must also be greater than zero, ( P > 0 ) ie, positive which means that energy is being stored in the inductor.
Likewinse, if the current through the inductor is decreasing and di/dt is less than zero then the instantaneous power must also be less than zero, ( P < 0 ) ie, negative which means that the inductor is returning energy back into the circuit. Then by integrating the equation for power above, the total magnetic energy which is always positive, being stored in the inductor is therefore given as":
Energy stored by an Inductor:Last edited by Allen Burgess; 05-18-2017, 07:08 PM.
A Pint is a pound the World around.
No it isn't! Some impudent smug snorts. No two things can be the same. We're constantly bombarded by such preposterous inanities.
A pint is equal to a pound in weight. 1 Coulomb is equal to 1 Gauss of magnetic force.
Negative values such as Henries of inductance or current in Ampere's have negative values on our measuring instruments we're forced to assign values to.
A negative Henry is a measure of magnetic force. Negative current is measured as equal to positive current simply moving backwards. These are positive values expressed in the negative range; Not imaginary terms.
@Tinselkoala,
Note the graphic below. Nowhere is a "negative number" used or implied. Negative correlation means as one variable increases the other decreases, and positive correlation means as one variable increases, the other does as well, and when one variable decreases the other variable decreases too. It has nothing to do with negative values of the variables. The _slope_ of the regression line is either positive (positive correlation) or negative (negative correlation).
You really must stop posting your basic math errors and misconceptions.
Here's the comment of mine he's referring to as basic math errors and misconceptions:
Slip knot loop hole.
TK lynches himself again by yet another one of his notorious "Slip knot Loopholes".
Tinselkoala , Milehigh , Citfa and a pack of running Jackals over on the OU site conspiratorially and pathologically conceal the value of two gain factors: The "Negative Henry" and "Negative Current". They are miscreants and should be punished for their deceptions.Last edited by Allen Burgess; 04-20-2017, 01:41 PM.
Lenz's Law.
Lenz's Law
"When a bar magnet is pushed into a coil connected to an ammeter the meter deflects. Pulled out of the coil the meter deflects in the opposite direction".
Good video on "Magnetic Reluctance":
"Magnetic Reluctance Formula".
We see the "Negative Henry" value on the bottom left, and the customary resistance formula on the right. The "Reluctance" is directly proportional the intensity of the magnetic field on the left, just like the "Resistance" in the formula on the right is directly proportional to the Ohmic resistance.
Everyone knows that the presence of a magnetic field in an inductor opposes change to an electrical current. These formulas are very simple to understand once the "Cuttlefish" ink's washed away.
One "Negative Henry" equals one "Tesla" of magnetic force.Last edited by Allen Burgess; 05-19-2017, 01:28 PM.
Inverse vs negative
Originally posted by Allen Burgess View PostWe see the "Negative Henry" value on the bottom left, and the customary resistance formula on the right. The "Reluctance" is directly proportional the intensity of the magnetic field on the left, just like the "Resistance" in the formula on the right is directly proportional to the Ohmic resistance.
That is not "Negative Henry". It is inverse henry.
That is a fundamental difference.
Also, you continue to confuse the variables (symbols representing the physical quantities) with the units (used to define the measurement system).
