Some things which are not "loyal" to Part G config...plus.
Hello Cadman,
Yeah, Cornboy IS a great builder!
Now about your set up, I see a couple of main things which would not give you results as expected...
First, a Car Battery will literally dump full amperage just because resistance is almost non existing in our high gauge winds.
Second, by splitting the Toroid Core in Four Quadrants it will completely brake apart the Inductance effect which is supposed to develop within a full, closed core...it would be resetting then restarting again...so the signal will be interrupted constantly plus inductance will not restrict currents on the lower path (Retracting Field).
However, even with the couple of things above, which does not adhere to replication spec's...your results were very similar to mine...Resuming, I have not being able to show any, but even minimal possibilities of reaching OU.
And what I see here is that by using such low resistance, amperage will have a very nice expressway to fully develop, and so, low number of turns will not allow higher voltage...so, we are into a "Dead End street" until we solve some of these problems.
IMHO, there is absolutely no need to use that much amperage nor wattage on the exciting system...if there is at least a suitable resistance which regulates amperage and so number of turns enough to operate at a higher voltage.
The only way that I see this system working...is by allowing Inductance to run -non stopping- so it can fully develop without absolutely any "jumps" (meaning interruptions) which comes with the taps design at certain distances/ number of turns...this splits inductance into fragments, so it can not become compact and continuous at the full ferromagnetic core...the way I see it would do with taps...is that Inductance "stretches" then loosing compactness till it reaches next tap in line...
Like I wrote before and many times on this Forum...I am developing other machines as well as this design with Part G...and actually I will keep using the same rotary switch to test them as well...and so, whichever machine that works out better than the other...would be leading my full development.
So far I am not able to build a fully wound toroid with resin and machined in order that brush runs on each turn like Doug did and brought him to success...
