Hello all,
As far as I see it through my tests part G did work to do the job that was invisioned quite well. Although not the way MM first sugested (in the wiring) as I reported quite awhile ago.
This really did give a new insight to the way this machine could operate so was good to persue.
However I was unable to get efficiencies needed, I am sure there is still more about the machine that is not known in its overall makeup.
I have not played around with it for quite some time now but still have ideas for more tests.
I think it will take quite a bit of work to understand this machine in full.
I was really gettin upset that MM never seemed to have a machine built and didn't appear to be testing anything and relaying any results. This is a big problem when you are supposed to be heading a build.
I also told him my feelings about this infamous Doug, and that How is he any different from anyone in the past suppressing information? if he understands this machine and doesn't relay the information some way. And thats a big IF he understands it. Proof is Proof there is nothing else with these machines and Doug type of tales.
Overall my testing to date the best efficiencies I found was pulsing the primaries (one on, the other off and so on) with norths facing each other.
I moved the secondary around and got really efficient results but no overunity. I did this just to try it out but don't consider it the true make up of the way this machine should operate.
The north to north primary set up works well in producing results in the secondarys.
The G core needs more work and understanding with what can be done.
The overall wiring may need more understanding aswell.
Anyway this is what I have found up to now.
