Anti-gravity
  • Originally posted by aljhoa View Post
    What is absolute water pressure 10 meters below sea level?
    Equivocation fallacy.
    My question was relating to air pressure, not water pressure.
    What is absolute air pressure at sea level and 2.4 miles deep gold mine?
    Where is this gold mine that is 2.4 miles deep? What is its exact location? If you can't give me its exact location, then it appears that you are committing a red herring fallacy.
    What phenomena is responsible for the hydrostatic pressure..
    Are you claiming that hydrostatic pressure is a phenomena in nature?
    Where do you observe hydrostatic pressure in nature?
    And how is hydrostatic pressure a phenomena in nature?
    If you are making that claim, how are you demonstrating it?
    ..of the atmosphere and hydrosphere?
    at what altitude?
    at what depth?
    What phenomena keeps the atmosphere and hydrosphere on the Earth?
    Can you have gas pressure existing next to a vacuum without a barrier separating the two?
    Without a barrier to separate gas pressure from a vacuum, the gas pressure would fill the area containing the vacuum.
    Is there any evidence for gas pressure existing without the necessary antecedent of a container for the gas pressure to press on?
    VIDBID
    • What phenomena keeps you VIDBID on the Earth?
      Al
        What phenomena keeps you.. ..on the Earth?
        Do you mean force?
        That would be the same force that keeps you on Earth.
        Remember that Einstein said that gravity is not a force.
        Remember that Einsteinian gravity theory has superseded Newtonian gravity theory.
        You have to stick with Einsteinian gravity theory now.
        So, you can't say that gravity is a force.
        Both theories are wrong, of course.
        But you have to stick with Einsteinian gravity theory.
        Are you referring to relative density equilibrium and disequilibrium?
        By the way, relative density disequilibrium is a force until equilibrium is achieved.
        I already explained it in a previous post.
        The image is of a 5-Tube Galileo Thermometer
        You have a certain amount of a liquid sealed in a vile within a tube filled with liquid.
        You can not increase the amount of liquid sealed in a vile.
        What then causes the vile to rise or lower?
        How does an increase in temperature affect the liquid in the vile?
        Does not the relative density of each vile changes with temperature?
        What comprises the mass, density and volume of each vile?
        1. Glass vile.
        2. Liquid in glass vile.
        3. Gas in glass vile.
        4. Metal temperature tag, which displays the current air temperature.
        which is density-relative to
        the liquid that the vile is in.
        The temperature is the independent variable.
        How do you control temperature?
        Easy. Turn on a space heater, for one.
        Relative Density Equilibrium
        How does temperature affect the relative density of an ampoule and cause it to be in either in a state of relative density equilibrium while the ampoule is stationary or to be in a state of relative density disequilibrium while the ampoule is either moving up or down?
        VIDBID
          VIDBID, answer the above question.
          Al
            Already answered.
            VIDBID
            • Time To Stop Being Brainwashed
              How to undo brainwashing.
              You undo brainwashing by questioning everything, including what you believe and why you believe it.
              Learn to think critically.
              Watch Robert Kiyosaki.
              1. Money
              2. Debt
              3. Taxes
              [VIDEO]https://www.youtube.com/watch?v=it4TpPbf78U[/VIDEO]
              [4K] - How does money make you poor | Interview with Robert Kiyosaki - YouTube
              Code:
              Money is debt.
              Rich people don't work for money.
              The rich don't pay taxes.
              Originally posted by Kiyosaki
              If you can't think (think critically), then I can't help you.
              That applies in all areas.
              Question everything.
              VIDBID
              • Increase Your Financial IQ
                [VIDEO]https://www.youtube.com/watch?v=YZHBxpAFmLw[/VIDEO]
                Increase your financial IQ Audiobook - YouTube
                Code:
                VIDBID
                • I'm not a fully fledged flat earther myself, but I do luv the way you guys take the mickey out of modern theioreical science. And as far as I have seen the only refutation to some pretty fundamental questions involves insults and name calling.
                  cheers
                  • Originally posted by lotec View Post
                    cheers
                    Ad hominem and name-calling are the lowest levels of disagreement. An emotional arguments can never overcome a truly objective argument.
                    Most, if not all, baller arguments are based on logical fallacies.
                    VIDBID
                    • Comment
                      • Turion's playbook
                        Hi Turion,
                        Nevermind.
                        Thanks vidbid.
                        • I pretty much gave up
                          here is something fun on topic.
                          I don't usually watch movies, but this one is good.
                          what gets me is that in the math they end up looking at the 8th dimension as the key.
                          this matches what others like wilbert smith talked about.
                          and if you look at the lower dimensions that they don't cover in this movie, like the 6th dimension that is curled up on itself, they just don't get that this is magnetism, and the 5th is what we see as electricity.
                          they figured it all out in the math, but have yet to relate it back to what we see in our world.
                          to bad they will likely never have this idea told to them.
                          • Originally posted by spacecase0 View Post
                            Destructive Interference
                            A pair of light or sound waves will experience interference when they pass through each other. The individual waves will add together (superposition) so that a new wavefront is created.
                            Destructive interference occurs when the maxima of two waves are 180 degrees out of phase: a positive displacement of one wave is cancelled exactly by a negative displacement of the other wave. The amplitude of the resulting wave is zero.
                            Destructive Interference | COSMOS
                            Al
                            • Comment
